Question about Sewing Machines
I am having trouble with breaking stitches and need a manual to find the problem
  • Sewing Machines Master
  • 1,129 Answers
You don't say what make and model but you may find a manual on www.sewusa.com, www.sewingpartsonline.com or www.sewingmanuals.com .
Check your top tension dial, turn it to zero and clean between the discs with a selvage edge of clean cotton offcut. Also take off the needle plate and check it for any burrs or damage around the needle hole that could be catching the thread. I assume it is the top thread that is breaking? Check the threading path from the thread spool, down to the needle visually to see if there is something damaged or catching the thread. Does the machine have an aerial arm, and if is, is it lifted up? Also, the thread spools themselves sometimes have a little nick in the edge where the thread can catch, so use a spool cap over it or turn it up the other way to ensure this is not happening.
Good machine maintenance tips, troubleshooting and threading diagrams are at www.sewing.about.com.
Hope this helps a little.
Posted on Apr 11, 2011
Elna 2005 I don't have the manual. Which setting is for the stretch stitch?
A special stretch stitch is not required to sew stretchy fabric. All one needs is a zig-zag that is wide enough and close together enough to allow the fabric to stretch without breaking the stitching thread. (Test it on a piece of scrap fabric you are using, give it a good tug and see if the thread breaks.)
NOTE: be sure to use a ball-point needle. A sharp needle will tend to cut the fabric threads and your stretch fabric will eventually develop holes and runs commonly found in knits.
There doesn't appear to be a manual for your machine, however, you can usually find a manual close to your machine model and the instructions will be similar enough to suffice. Perhaps you will find one with instructions for sewing stretch fabric:
ELNA Other manuals
Jan 10, 2016 | Elna Sewing Machines
How do i get a straight stitch on my golden touch & sew model 640 machine
Check for diagrams on the selector wheel and then adjust your stitch length. Do not set to tight as your thread will break
Oct 02, 2014 | Singer Sewing Machines
Zig-zag settings
you probably shouldn't be using a zig zag for that application. But the multi-stitch zig zag.
Please look at page 40 of your manual for information.
As for needle breaking check to make sure your need is the correct one for the thread and fabric. Also make sure your pressure foot is the one recommended for the stitch. Consider this... most thicker fabrics require a longer stitch.
Aug 21, 2012 | Singer Confidence 7463 Computerized Sewing...
What would be a "stretch" stitch setting?
For a stretch stitch use a narrow zig zag stitch. Use a ball point needle with knit fabrics.
May 30, 2017 | Sewing Machines
Necchi 535FA--the tension seems to be off. The thread keeps breaking or pulling out of the needle. When i sew on cotton it was working then when I switched to a stretchy faux crushed velvet the tread...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | Sewing Machines
My machine skips stitches, and the thread wears at the needle, causing it to snarl and break. I've looked in the manual and tried everything they suggest.
This sounds like the thread is not in your take up lever, are you sure that it is threaded correctly? Maybe it is wrapping around one of the eyelets or the take up lever rather than just going through the eyelet. The fact that the thread is wearing at the needle is indicative that the thread is too tight when the needle goes downwards. Is your top tension set too high perhaps. The skipping stitches part is normally indicative of either a blunt needle, using a sharp needle on knit fabric, or the timing is out slightly.
You should be able to trouble shoot the first two options. For the timing, will it sew a zig zag stitch at all? If timing is out or you've tried all the other trouble shooting; I'd suggest a trip to the serviceman.
Oct 27, 2010 | Elna 3210 Mechanical Sewing Machine
I just took my 7400 confidence singer machine out of the box. After trouble threading it and breaking a needle, the bobbin case came out and I not only can not get it back in properly, but I never...
Where did you buy it? Didn't they give you a manual? You can look at your manual online for free at www.singerco.com and enlarge the diagrams to see how it is supposed to look. If, you still have trouble call Singer at 1-800-4singer. Good luck
Oct 23, 2010 | Singer Confidence 7467 Mechanical Sewing...
I can't find my Virtusoa 150 user manual. Need basic stitch setup
If you will send me your e-mail address privately, I will scan some pages from my manual and e-mail them to you.
Kathy
soot@iowatelecom.net
Jul 25, 2010 | Bernina Virtuosa 150
Thread breaks and skips stitches
Open the needle plate, remove the bobbin and bobbin case.....refer to your manual.
Clean away lint and threads.
Thread with the presser foot up.
If this continues, take the machine and samples of the mis-stitching in for service. It could be the timing needs to be adjusted by a professional.
Feb 20, 2010 | Husqvarna Viking 1
Free motion quilting skipped stitches, breaking threads
Might be that you need to lower the tensions quite a bit, you'll have to juggle with top and bottom tensions though, and experiment for just this operation with the Sensormatic.
Mar 27, 2017 | PfaFF Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
