No video playback on divx - Computers & Internet
    Problem Solver:
  • 12 Answers
Try to install/reinstall Divx codecs using :
http://www.divx.com/
or
http://www.xpcodecpack.com/
In both cases before you install any of those codecs deinstall existing codec software.
regards,
Konstantin
Posted on Aug 06, 2008
Why denon s-102 do not read divx files ?
For DVD ROM discs, data files in DivX 3.11 / 4.x / 5.x / 6 format can be played. If it's not playing, then there's a custom codec the video must have been created in, and the player won't be able to playback
Jun 09, 2014 | Sony DAV-DZ100 System
Tip
Successful VBR audio conversion for AVI's with Standalone DVD DivX Players
PROBLEMS FOR STANDALONE DVD PLAYBACK OF AVI and DIVX
  • Variable Bitrate Audio (CBR is the standard for standalone DVD AVI's in VBR will cause progressive audio lag errors)
  • Audio Split across Interleaves (Aligned with Interleaves is standard and no known playback errors will occur)
  • Non-AVI v2.0 container (MP4 and MKV containers are too new for most players)
  • Framerate 25fps for PAL(UK) OR 23.97fps for NTSC(USA) if in the UK you need to re-encode to 25 frames per second to ensure correct playback
  • FOURCC not DX50 or DIVX (XVID will work but maybe jumpy)
  • Packed Video Bitstream ** (see N-VOP below this may need to be unpacked) the easiest way to unpack this without re-encoding is to use MPEG4 Modifier from Moitah that will do it in about 30s you can also change the DAR and PAR as shown below
  • Third party software known to interfere with the normal use of DivX for Windows Software.
    Some sections contain options for removing many filters that have the *potential* to interfere with the good operation of DivX for Windows. download the DivX All in One Fix HERE it is a good starting point if you know you have installed codec packs that might interfere with your DivX encoding.
These normally use for AVI's that are enocoded for PC playback only and are NOTsupported on Standalone DVD players so should be removed using VirtualDub or one of the other applications mentioned below.
  • B-VOP's (Bidirectional Video Object Frames, which improves the playback quality)
  • P-VOP's(Predictive Video Object Frames)
  • N-VOP's (can be Zero Time as in a packed bitstream** OR non-Zero Time)
  • QPel (Quarter Pixel Encoding used to improve MPG4-ASP compression over the standard Half-Pixel or normal MPG4)
  • GMC (Global Motion Compensation, will improve scenes where there is lots of motion)
The first job is to change the VBR audio to a CBR there are only a few sucessful ways to do this use VirtualDub or VirtualDubMod with the LAME or Fraunhofer ACM, its easier to do this with Avery Lee's version the Mod version requires lots of de-muxing converting and re-muxing
If you have DivX Pro Convertor licenced with the Professional v6.9.1 of the codec the Video will be fine however the audio with remain at the VBR and will cause you playback audio errors the FOURCC codec will be changed and the aspect ratio for Home Theater will change to the video will be fine, notice that GSpot displays only the DivX503b2851p metadata and no ISFT tag while the VDub twins show the metadata as DivX503b2816p a lower build number than for the Pro Convertor.
Its also a good idea to change the Codec to DivX if you leave it at XVid it will play but it will skip and become annoying well it is a free libavcodec and way and is great to use on just your PC the example above shows what will happen after a successful DivX Convertor change notice the audio MP3 remains at VBR, this will cause audio sync errors even if the audio frames are aligned with Interleaves
The above example shows what will happen if you use VirtualDubMod and VirtualDub both with give you CBR audio so will work on your DivX enabled DVD player however the VDubMod version will keep the Audio frames aligned with Interleaves which is a more successful method especially with AC3 audio VDubMod is good at this see my tip HERE.
SPLIT ACROSS vs ALIGNED WITH INTERLEAVES
Gspot tells us that "Split" means that some audio frames are split across interleaves, i.e. part of the audio frame resides in one chunk and the remainder of it is in another, with a video chunk in between. On v2.5 beta the wording is "audio split across interleaves" or "audio aligned on interleaves", which should help to make it clearer. I'm not making any claims about the relative merit of one scheme vs. the other, but it does seem important enough to report.
  • Nandub splits AC3 audio, BUT not MP3 in CBR nor VBR
  • VirtualDub always seems to Split across interleaves even when the LAME ACM is used.
  • VirtualDubMod splits AC3, but does not split CBR MP3. however it will split VBR MP3 if you answer "YES" to the question about allowing it to "rewrite the header" Otherwise it Aligns.
  • AVIDemux will Split as default however it will Align with if the reservoir is check on the MP3(lame) conversion.
  • AVI ReComp will Align as it uses a bundled version of VirtualDubMod that will allow you to edit the AVS Script if you know how to di this, very advanced stuff.
  • AVIMuxGUI never splits anything always Aligns.
THE VERDICT:
VirtualDub's method is very simple and uses the LAME MP3 ACM to perform the task in 1/4 of the time it takes with the VirtualDubMod version and I have had no playback audio errors with either version have a look at my tips and exactly how to best perform these two methods HERE
FINAL THOUGHT:
You might like to tryout AVI ReComp v1.5.0 (that uses VirtualDubMod v1.5.10.2) that will keep the video in the libavcodec XVID FOURCC (the DivX codec is not yet supported) format BUT will skip when played back on a Standalone Player the audio conversion however is very easy as shown below
If you choose to use another alternative AVIDemux v2.5 even when a VBR timemap is created to keep the Audio and Video in Sync
The Video codec is still XVID so will give you a few skip errors. The Audio conversion is best done using the MP3 (lame) which is the same used in VirtualDub if you disable reservoir in the LAME config then it will become Aligned in the same way VirtualDubMod operates.
Here are the results for the alternative conversions but only the audio is changed as they can't change to DivX note that AVIDemux Splits across Interleaves like VirtualDub (unless de-reservoir is used) and AVI ReComp uses VirtualDubMod and so it remains Aligned,
FOOTNOTE:
It is also worth mentioning that it you want to convert your AVI's into DVD format VSO's ConvertXtoDVD will handle any Video codec and Audio codec bitrate even a variable bitrate (VBR) and create DVD Video's with no audio sync problems, by default all DVD Video VOB's audio are at a constant bitrate (CBR) it also has the added option to resize and pad to give you the DAR that you require for you TV.
On the flip side the one and only way to convert a DVD format into an AVI is to use AutoGordianKnot by len0x (based on VirtualDubMod with AVISynth) which will encode a an AVI with the FOURCC of DX50 with either CBR AC3,DTS or MP3 with flawless results everytime with the Audio Aligned on Interleaves for best playback.
It also has the option to encode into XviD with a VBR MP3 audio but this will give audio lag when played on standalone DVD players with often jerky video, so stay away from this unless you plan only to watch the conversion on a PC.
EXTRA NOTE:
It must also be added that even the DivX Convertor Plus v8.0 latest bundle codec v6.9.2 that includes the DivX HD format using the MKV container as opposed to the usual AVI container will not convert a VBR video stream to CBR but create excellent H.264 files with AAC audio streams.
These screen dumps from G-spot clearly show that the AVI v2.0 container for the original VBR XVID codec converted using VirtualDubMod v1.5.10.2 has been converted to DivX using the 720x576 Home Theater format with audio frames still aligned on interleaves but has kept the troublesome VBR (variable bitrate video) this will cause your standalone DVD player with DivX progressive audio errors. You must still convert to CBR first using one of the methods above to ensure non-failure.
Come on guys at DivX lets have the Home Theatre format convert VBR to CBR as standard ....
on Feb 26, 2010 | Philips DivX DVD Player
Tip
How to convert XVID VBR MP3 and DIVX CBR MP3 using ConvertXtoDVD
Most Philips DVD players with DivX will play Stage 6 or VOD MP4 Video files if the FOURCC is set to DX50 or DIVX and the MP3 or AC3 audio is at a constant bitrate CBR of at least 192kbps, this is also the DVD Video audio standard in AC3, DTS or LPCM.
However with either DivX OR XviD video with VBR MP3 audio you will experience audio lag on playback the trick is to get the audio track in to a constant bitrate CBR and if possible with the audio frames Aligned on the interleaves as opposed to Split across interleaves.
If you plan on keeping the video in MP4 AVI v2.0 format then you MUST convert the audio to a CBR in either MP3 or AC3 format using one of the methods shown HERE.
If you plan on converting the MP4 video into DVD format you can first try to use the excellent ConvertXtoDVD this will attempt to convert the audio track into 192kbps CBR dolby digital AC3 audio whatever the source AVI audio.
If this fails to give you DVD Video without audio sync problems then you must convert the MP4 to a CBR audio and a FOURCC of DX50 to ensure Home Theatre compatibility.
on Feb 11, 2010 | Philips DivX DVD Player
My LG DP122 will play some AVI files from a USB device but not others.
figured this out, lg dp122 uses DivX Home Theater profile, so the technical specs of the video must match that.
Those specs can be found here: http://www.divx.com/files/DivX-Profiles_Tech-Specs.pdf
Jan 23, 2013 | LG DP122 DVD Player, Multi Format...
Which DVDs do I need to use with the Toshiba DVR19DTKB2 I have DVD+R Will these record from VHS
Compatibility Recording - DVD-R, DVD-RW, DVD+R, DVD=RW, VHS
Compatibility Playback - CD-Audio, CD-DA, CD-R, CD-RW, SVCD, Video CD, DivX version 6, DVD-R, DVD-RAM, DVD-RW, DVD Video, DVD+R, DVD+RW, JPEG Viewer, MP3, NTSC Playback (VHS), USB 2.0
Mar 07, 2011 | Televison & Video
How to watch movies on LG optimus
Most important is to get information from your service provider to confirm if the network supports streaming video. The phone by itself supports all the following streams as you can download and watch on this Android phone.
The supported features/tech specs are as follows;
Audio codec
MP3, AMR, AAC, AAC+, WAV, WMA
Video codec
(Video Recording / Video Playback)
Recording: MPEG4 @VGA15fps
Playback: MPEG4, H263@VGA30fps, WMV, DivX, Xvid
Main Camera
3Mega pixels AF
Dec 11, 2010 | Cell Phones
I cant watch anything that is a video. or any video playback! how can i solve this?
1 you might need a dvix codec. www.divx.com
2 depending on what video format it is, flash avi wmv or what ever needs certan type player.
3. if its a dvd you need some thing like power dvd.
but the first thing you need is a divx codec to watch normal avi videos . download the divx player free and install codecs from it., hope this helps in some way.
Dec 01, 2009 | Cars & Trucks
I have a LG RC897T DVD recroder combo. Any one know how to unlock it so it plays DVD from any region in the world.
Same code as the RC797T, except without the Divx support. Option 5 is the one you are after:
Click the HOME button on the remote with the unit in 480i resolution
Click the setup page
Click Start
Click TV Aspect
highlight the 16x9 wide aspect ratio
enter on remote control this coded sequence:
1397139
Edit specific "Options"
Option 2: 35 (enables Divx/Xvid playback)
Option 4: ff (enables Vcd and SVCD playback)
Option 5: ff (enables region free playback (region 0) DVD playback)
Option 6: ce (enables Insignia brand startup logo on boot)
Option 6: c0 (enables LG brand startup logo on boot)
Mar 30, 2009 | Sharp DVMX1U DVD Player
Play divx movies
Usually, DVD players that play DIVX are very specific on which version it will play; you might want to check this link out: https://vod.divx.com/how/
Oddly enough the P350H manual says nothing about DIVX playback.
Nov 10, 2007 | Televison & Video
How do I play MPEG recordings?
Using Windows Media Player You need Microsoft Windows Media Player Version 9 or higher and Sharp G.726 Audio Codec in order to play MPEG4 files from the Memory Stick on your PC. If you are not currently using Microsoft Windows Media Player Version 9 or higher. Important: The Sharp G.726 Audio Codec needed to play MPEG4 files is no longer signed by Microsoft. If Sharp G.726 Audio Codec is not properly installed on your PC, it will not play MPEG4 Audio. Using DivX® You can also download a free DivX® Player and codec to play your MPEG and other video format files. DivX® for Windows is a free codec built to play every version of DivX content. The DivX codec also plugs into your existing video software so you can view and create high-quality DivX videos at a fraction of the original size. The DivX codec also adds DivX video playback support to most popular media players.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Computers & Internet Logo
David Payne
David Payne
