Divx, doesn't play the video it only does the audio
  • 3,940 Answers
Download and install the K-lite codec pack
http://www.free-codecs.com/download/K_lite_codec_pack.htm
Posted on Aug 06, 2008
I have a **** Smith GE4203 DVD player, but none of the "MPEG4" files I plug in with a USB stick works. The machine recognises an AVI file, but doesn't play it. What settings should I use?...
Rip your DVD's using XviD format and not DivX and they should play just fine.
A good free software to try is "Winx Free DVD to XviD" but you'll have to have unprotected DVD's or rip them to the hard drive first using DVDFab to remove the protection or just have Slysoft AnyDVD running.
I set the video's audio to mp3 format (128Kbps 48000sample rate), and the video to 25fps(because in Australia we have PAL format), output profile to keep original size and aspect ratio, and video quality to about 1500kbps.
You won't get much benefit from a higher bit rate then that on a GE4203 screen and you could probably even go lower if you have speed or sync issues with the data rate. Even 1200 looks good.
May 28, 2011 | Televison & Video
Tip
How to convert XVID VBR MP3 and DIVX CBR MP3 using ConvertXtoDVD
Most Philips DVD players with DivX will play Stage 6 or VOD MP4 Video files if the FOURCC is set to DX50 or DIVX and the MP3 or AC3 audio is at a constant bitrate CBR of at least 192kbps, this is also the DVD Video audio standard in AC3, DTS or LPCM.
However with either DivX OR XviD video with VBR MP3 audio you will experience audio lag on playback the trick is to get the audio track in to a constant bitrate CBR and if possible with the audio frames Aligned on the interleaves as opposed to Split across interleaves.
If you plan on keeping the video in MP4 AVI v2.0 format then you MUST convert the audio to a CBR in either MP3 or AC3 format using one of the methods shown HERE.
If you plan on converting the MP4 video into DVD format you can first try to use the excellent ConvertXtoDVD this will attempt to convert the audio track into 192kbps CBR dolby digital AC3 audio whatever the source AVI audio.
If this fails to give you DVD Video without audio sync problems then you must convert the MP4 to a CBR audio and a FOURCC of DX50 to ensure Home Theatre compatibility.
on Feb 11, 2010 | Philips DivX DVD Player
HI My LG V181 DVD Player / VCR Combo will not play divx. What can I do? Can I upgrade the software? Mark
Divx compatibility with this player is limited as follows; available resolution size of Divx is under
720x576 pixel - file name Divx subtitle is avail by 56 characters - if number of the screen is over 30/sec the unit may not operate norm - playable Divx file avi,mpg. .mpeg - playable codec format
DIVX3.xx - DIVX4.xx - DIVX5xx -XDIV - MP43 - 31VX - if the video and audio structure of recorded
file is not interleaved, either video or audio is outputted.- if the fie is rec GMC the unit supports only
1 point of the record level - may be helpful!
Feb 06, 2011 | LG V181 DVD Player/VCR
I have a portable Kawasaki DVD player. It does not play AVI videos. Tellme what to do please.
This normally depends on what FOURCC the AVI has encoded inside the file.
Look here at my DivX Rox!! facebook group for the correct DivX FOURCC that will normally work on most standalone players on AVI with FOURCC =DIVX or DX50
Most DVD players that have DivX support require these two FOURCC tags, DIV3,DIV4,DIV5 and DIV6 wont always work but sometimes you can change this without re-encoding using a batch FOURCC changer.
As a general rule of thumb even when you change the FOURCC of the AVI you may experience audio lag on the file it is best to convert all AVI's to DivX using the DivX Convertor that is available with the DivX Professional codec costs $19.99 (£13.99) and is well work the money.
I have had some success with Xvid AVI's with FOURCC XVID but with audio lag and video jerks.
Jan 06, 2010 | Philips DivX DVD Player
Audio plays but no video
If you have catalyst control centre running go into the settings for basic video in it and make sure it's not set to custom
Aug 05, 2009 | Dell desktop and monitor -Inspiron...
Pioneer avh-p4100 plays my DIVX really slow
Its a media-snafu...DIVX isn't always readable my mobile electronic manufacturer equipment.
sorry :o(
Jun 15, 2009 | Car Audio & Video
Does not play divx/mpeg4 files on dvd disk!!
The player plays strictly DIVX files, but not variants like XVID (which today is more common since divx became not free).
Divx is actually the same than XVID. After spending days converting my files from xvid to divx, realized that changing only the FOURCC code of the files works.
Look for a program named videoinspector. It allows to edit the fourcc for a video file. for all xvid and variants change the fourcc of the files to DIVX. The change takes a second instead hours of conversion, and movies in xvid that used not to play on this device, now will be played without problems.
Apr 08, 2009 | Philips DCP851 Portable DVD Player
My yamaha dvd-s661 has usb connection but won't play the audio
Make sure in the setup of the DVD player that every type of audio is downconverted to 2 channel plain old analog stereo.
Mar 05, 2009 | Yamaha DVDS661 Player
AVI formatted files behave as audio only
It is likely that the files are encoded with DIVX, you can download the Divx plugin for windows Media playere here.
http://www.divx.com/divx/windows/
watch your options on the install to avoid those pesky toolbars
Dec 29, 2008 | VistaQuest DV-7 DV Camcorder
How do I play MPEG recordings?
Using Windows Media Player You need Microsoft Windows Media Player Version 9 or higher and Sharp G.726 Audio Codec in order to play MPEG4 files from the Memory Stick on your PC. If you are not currently using Microsoft Windows Media Player Version 9 or higher. Important: The Sharp G.726 Audio Codec needed to play MPEG4 files is no longer signed by Microsoft. If Sharp G.726 Audio Codec is not properly installed on your PC, it will not play MPEG4 Audio. Using DivX® You can also download a free DivX® Player and codec to play your MPEG and other video format files. DivX® for Windows is a free codec built to play every version of DivX content. The DivX codec also plugs into your existing video software so you can view and create high-quality DivX videos at a fraction of the original size. The DivX codec also adds DivX video playback support to most popular media players.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
