Question about Acer Computers & Internet
Hello,please my acer aspire 5310 suddenly goes off by itself without giving any notification even when it's plugged to the ac adaptor,i even formatted it and installed a new OS,the problem still persists and I kinda noticed it gets really hot,dont know what to do
  • 4 more comments
  • t2sogsog Apr 07, 2011
    yeah,I did,but they could not get it done
    yep,they couldnt get it done
    still not working sir
    yeah,they couldnt get it done
    still not working
  • 1,719 Answers
First, I appreciate the details provided in your question.
Laptop heating issue generally occurs due to fan failure, which may damage the system, if not checked properly. Another cause of overheating is the dust present inside the laptop, which clogs the fan and heatsink.
1. Make sure the fan is running. (if not it needs replacement)
2. Clean the fan and heat sink (thermal module). Click here for laptop disassembly instructions and refer to
Removing the System Fan/Thermal Module after removing the outer cover. Take out the fan and heat sink. clean them with the help of tooth brush and put it back. Also, Acer 5310 Repair Manual can be downloaded/ referred.
The procedure is very simple, but if you are not comfortable with working inside electronics, I suggest that you should get you laptop checked by a professional for servicing (if required). I believe immediate action is required to prevent any damage to your machine and data.
Hope it Helps! Let me know if i could be of any further assistance.
CreativeTECH
Posted on Apr 07, 2011
  • 69 Answers
Have you considered taking it to a computer repair shop try it it might be technical problem
Acer aspire e1-532 battery led off when plug the ac adapter and does not power up
It is beyond what I can diagnose remotely, as it fails to power up even on just the AC adaptor, without the battery.
It needs a professional repair, which means opening it up to find out why it fails to start or even show a screen, which means no software fix can be done.
Feb 05, 2015 | Acer Computers & Internet
I have a Acer Aspire 7736ZG that won't boot anymore
Hello, on ACER 7736zg motherboard, the mosfet U58 of type si4812BDY fails very often, which causes the symptoms you describe. Tutorials are available on youtube for changing this chip yourself (<1$)
JP
Apr 10, 2012 | Apevia Computers & Internet
Hello my acer aspire 5310 still keeps going off itself without any notification,i even installed a new copy of oS,the problem wont jst go,i took it to engineers,they couldnt get it done and i've been...
Your description indicates it may be overheating.
If you wish to continue using laptop, suggest you raise/elevate the laptop to allow more air flow for cooling.
You could purchase a laptop stand, made of mesh material an place a small desk fan behind the stand. This would generate additional air flow to cool the laptop.
Apr 07, 2011 | Acer Computers & Internet
I cannot get my acer aspire 4315 to AC power up. new batteries are ok. i have changed the power jack but no difference. please help
Check the light on the AC adaptor when plugged in to the laptop. If it is flashing, it indicates that the power is being "spat back". That is, not completing the circuit. Means that you have a fault in the charging circuit. I'd check for burning around the contacts where the DC port was soldered onto the board / or if the plug type, check the socket on the mobo is not damaged and is firmly soldered on.
After that, (if not already done) check the output voltage of the adaptor with a multimeter, might be a simple failure of the ac adaptor, even though it looks ok
Mar 20, 2011 | Acer Aspire 4315 Notebook
My Acer Aspire 9805 battery was replaced. For
It could be an AC adaptor issue.
It should boot when connected directly to the power outlet through the laptop adaptor. If it is not boot, then the adaptor might not be supplying the needed power to boot it up.
If it is possible, try to isolate the issue. Charge your new battery using another laptop. Then plug it in your laptop to see if it works. If it will work, then it is the AC adaptor of your laptop that is defective. If the charged battery still won't make the laptop boot, then there is something wrong with your laptop hardware. If could be a motherboard issue of your laptop.
Feb 23, 2010 | Acer Aspire 9805WKHi Notebook
Pop-up acer edata security management each time open laptop
I would go to the program file itself (it might be on the desktop, might be in the start menu, or might be in a folder in C:\Program Files) open up the acer e-manager and look for an option for settings.  You should be able to un-select options for security notifications and automatic updates.  I do not have the program on this computer, but I have seen it before on other laptops.  Most all programs like that will let you change the settings.  The security updates are not entirely necessary, so long as you have an anti-virus program installed on your computer.  So just turn off the auto-updates and the notifications through the program itself.
Mar 26, 2009 | Acer Aspire One PC Notebook
Pc is telling me to plug it in when the battery is at 90%
The battery needs to be conditioned. To condition a battery, plug in the AC adaptor and charge it to 100%. Unplug the AC adaptor and run the battery completely down to 0% or until the computer shuts itself down or goes into a hibernate mode. Once this occurs, plug the AC adaptor back in and fully re-charge the battery to 100% again. You should now be good to go.
Let me know what happens and if this has solved your problem. Thank you, Binary Bob
Dec 07, 2008 | Acer Aspire 3680 Laptop
Power Supply problems
hello :
Sir u are facing a probleme with your ac adaptor jack in your laptop maybe yo need to change it .
changing of a ac adaptor jack its not an easy task you will need a soldring kit & a new propre jack for u laptop
dont forget rating this post if this is not helping u tell me so i can help u further .
Aug 20, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 4520 display off suddenly without warning
please clarify this sequence of events: "on AC power,it seems to be working fine. But the problem occurs when I try restart it on the next morning"... was it restarted next morning on AC power or battery...which one?
Aug 26, 2007 | Acer Aspire 5100-5033 Notebook
Computers & Internet Logo
128 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
