Question about GE Zoneline AZ38H12DAD Split System Air Conditioner
GE Zoneline PTAC Leaking
My a/c is dripping water out the front... I pulled it out from the wall and it looks like the drain pan towards the outside is completely dry and all the water is pooling under the front of the unit and then dripping out onto the floor. Can anyone tell me if this sounds like it is the problem and if so, how do I fix it? I can see what looks like a little passage for the water in the styrofoam towards the left side and I guess it might be blocked? If so, how do I get to it to clean it out or do I have to call someone?
thanks
Julie
  • julie08168 Aug 06, 2008
    Thanks so much for your response. It's actually been installed for about 5 years with no problem till now. I pulled it out again, farther this time and was able to get some gunk out of the passageway between the two pans and so far no more dripping... I'm not sure how long it would take the water to fill back up but I'm hopeful!
    thanks again!
    Julie
    Problem Solver:
  • 8 Answers
Hi Julie,
Is this a newly installed unit? The problem sounds like the sleeve is improperly installed. The sleeve should slope approximately 1/4 inch downward from inside to outside. This way the water will run to the back of the pan where it will be picked up by the slinger fan, or drain to the outside. Most likely this is the cause, not the styrofoam pan. If you need further info, you can contact me at greg.mcnary(at)airdistributors.com (replace (at) with @) and I can get you detailed installation instructions.
Greg McNary
Air Distributors Company, Inc.
Distributors of GE Zoneline PTAC Units and
McQuay PTAC Units
Posted on Aug 06, 2008
My lennox elite series cb29m-41-1p is leaking alot of water in the house with the air conditioner on. drain line to outside is clear
The condensation pan in the unit must have no cracks our brakes, and needs to be tilt down toward the condensation drain line, algae builds up clogs and must be cleared of clogs periodicaly
Aug 05, 2017 | Heating & Cooling
LG ptac MODEL : LP153HD3A collecting condensation water in bottom but not going to outside drain pan.
there is probably a blocked pipe or filter it will need cleaning, you may need a pump to remove the water first to get to the pipe to clean it out.
Jun 19, 2017 | LG Heating & Cooling
Stat issues with GE Zoneline
Your coils on the outside unit may need cleaning.When they get dirty, air cannot flow through them to remove heat from the refrigerant. When this happens pressure increases until it trips a safety and shuts the unit down.
It won't run again until the pressure drops to a safe level. Also check your drain line..Make sure it's dripping.If not it's clogged and that will trip the safety switch not allowing water to back up
Sep 17, 2017 | GE Heating & Cooling
BTU is leaking water from the inside.
Take the cover off the inside unit and look for the drip pan under the evaporator coil. It should have either one drain in the middle of the pan or a series of smaller drains along the back of the pan. The drain(s) is probably clogged up and causing the pan to overflow into your home. Also check the drain line on the outside wall where the refrigerant lines come through the wall for a blockage.
Jun 14, 2011 | Sanyo 09KHS51 Ductless Mini Split Air...
We have a window unit model ash08fas1 and it is leaking water into the window to our carpet. Does this model come with a drip pan or plug that needs to be moved? And how do we access it?
Look at your unit from outside the house. The back of the air conditioner should be slightly lower than the front. If it is level or the front of the air conditioner is lower it will drip into the house. Some window units have a drain for the water outside and some don't. Look for a hole in the bottom of the unit outside and if you find one make sure it is not plugged. Also dirty coils can cause a frost buildup on the inside of the unit. This will drip also. If this is the case you should see the ice buildup by removing the front cover or removing the front filter.
Jul 04, 2010 | GE ASL05LA Air Conditioner
TCL model tac 24chs/k air conditioner is leaking from the
You will want to remove the panel in front of the air handler, usually a few 5/16 screws.
Once open then with a flashlight look down inside where the water collects in the condensate drain pan.
Verify that the pan is not full of water or algae build up.
If it is, then attach a wet vac to your drain outside and while it is pulling on the drain line spray some water inside till it is fully clean.
If it is not full of water then check the pvc pipes that are attached to the drain pan, they may have came loose and may need to be teflon taped and reconnected to the pan. Also verify there are no cracks in the pan.
Lastly inspect the bottom of the evaporator coil (Not the top) pull out the filter and make sure the coil is clean or water could drip down past the pan into your dwelling. Make sure as well that the insulation on your panel that covers the unit is intact and not worn away.
Good Luck!
Nov 14, 2009 | Heating & Cooling
I have a zoneline ptac unit. The water keeps
They used to use a black rubber hose to run from the front to the back of the unit on the very bottom of the unit. You may also look for a styrofoam chute . Make sure the unit is sloped to the rear slightly.
Aug 18, 2009 | General Electric Zoneline® Deluxe Series...
Ptec allways draines water back in to room pisspoor design
This is most likely due to the installation. The unit should have at least 1/4 inch slope towards the outside to provide for proper drainage. If it is sloped towards the inside, that's where the water will go. To check, take the unit out of the sleeve and place a level on the inside bottom of the sleeve, and check the slope. If its flat or sloping towards the inside, the sleeve will need to be removed and re-installed.
PTAC Dude
GE Zoneline Specialist
Oct 29, 2008 | GE Zoneline AZ55H07D Air Conditioner
Zoneline Airconditioning - Winterizing and drain line
Yes this will recycle the room and can be cover outside if it is not a heat pump and will use elec heat strips to heat. As long as it is tilled toward the back the water will run out the back without a drain kit there should also be a drain hole in the bottom.
Oct 06, 2008 | GE Heating & Cooling
Water is filling up in drain pain
My suggestion is to NOT pull the plug on the drain that should be covered with a sign that says...do not remove plug. Water is supposed to be kept in the pan. The interior wheel then helps the water keep the condenser cool....Ron
Sep 22, 2007 | Amana PTH123B25AJ Heat Pump Air...
GE Zoneline AZ38H12DAD Split System Air Conditioner Logo
1,838 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
