Question about Maxtor Hard Drive
WINDOWS SET UP FAILS TO LOCATE THE HARD DRIVE ACESS SEEMS TO BE DENIED
    Scholar:
  • 93 Answers
Mabee the hard drive has failed . try entering bios and see if the hard drive is recognised .If not try turning the computer off unplug it then reconnect the drive data cable and power cable
then re- start the computer and see if it is recognised. some models of older hard drives needed a driver installed during set up -- you usually have to put the driver on a floppy disc and hit the f6 button when prompted by windows set up to install third party drivers . I hope this helps
Andrew.A
Posted on Apr 07, 2011
Testimonial: "The solution is very helpful, thats great"
First you are checking the harddisk Cables.
Then you are doing instlling the os
Second you have checking your harddisk jumper
now you are doing jumper position will be correct
(jumper setting displaing on harddisk)
3rd you will doing incert the windows 98 cd and restart now you are going dos comment in win98 cd
you have select format than scandisk select that is all will finishing than you are trying install os.
  • 39 Answers
Posted on Apr 08, 2011
Problem on acess is denied when entered pendrive
you might not be the computers administrator or the usb drive is not set for sharing or.......
click start control panel user accounts on the users tab click the name of the computer administrator you must have full control
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts hope this helps
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
Aug 14, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Locked out of external hard drive!!!
Hi if you are locked out and cant acess any files then the chances are you have had a virus at some point as this can cause havoc with hd you could try a data recovery programme but if this dont help then the only thing you can do is format and start again
Jan 26, 2008 | SimpleTech SimpleDrive Portable USB 2.0...
I can't open pen drive and it shows access is denied,
It happened because your "pendrive" contains one kind of trojan horse. Please scan by some good antivirus.
If this answer helpful please vote me.
Good luck.
Thanks for using FixYa
Jan 17, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
WDBAAF0010HBK-01 DRIVE ACCESS IS DENIED BY LAPTOP
you have to save the files using a computer with the same os that u origanlly and then format the drive on the windows seven computer then move the files back on to the drive
another thing to try is to try and update the drivers on your win. 7 computer
the last thing is you have lost all ur data and you should just reformat it
May 08, 2010 | Western Digital External USB 2.0 80 GB...
When trying to delete something from hard drive i get an error message stating. Cannot delete Acess denied make sure disc is not full or write proteced and that the file is not currently in use. This...
The possible couse of that is your hard drive is infected of virus, try to scan of updated antivirus, if not try to back-up your hard drive, and format in desk management.
Apr 17, 2010 | Iomega (33652) 250 GB IDE Hard Drive
Could not open - acess denied
Carefully examine your Kingston for a tiny physical slide switch! You have probably accidentally moved that switch into the "LOCK" position!
Hope this helps!
Feb 24, 2009 | Kingston Technologies 512MB DataTraveler I...
Acess denied
You certainly have an autorun installed by a virus.
A solution is to go command line and delete autorun.inf in c:\ and d:\
Another solution is to right click and choose open in the menu instead of execute. If execute is default then your computer is infected. I suggest http://downloads.andymanchesta.com/RemovalTools/SDFix_ReadMe.htm
Feb 14, 2009 | Dell Computers & Internet
Can't acess hard disk and security options
You need to Login As an Adminstrator then change the sercurity settings
Oct 07, 2008 | Hitachi TravelStar 80GN 80 GB Hard Drive
Problem installing windows XP
This is going to be either a bad disc or a bad hard drive. Do a hard drive test in the bios, if any part of it fails, then you will need to replace the hard drive. If the hard drive passes, then try a different operating system disc.
Aug 13, 2008 | Dell Inspiron XPS M140 Notebook
Access denied
Using Admin logon, open mmc and go to disk management.
Right click on C: drive and click "Properties", select "security" tab and click "advanced" button, select "owner" tab.
Choose new owner and check the "replace owner" check box and "apply".
Dec 15, 2007 | Computers & Internet
Maxtor Hard Drive Logo
201 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
