Question about GPS
During snow storm 1/2/11 car wont start engine went on was towed had new wires plugs car runs good no engine lite 4/2/11 went for imission inspection failed 4 monitors not ready tried driving like i was told dont work can i get it reset by a auto shop who does reseting?
    Brigadier General:
  • 7,191 Answers
You have posted the problem under "GPS Devices" section.
Kindly re-submit the question under cars section on the website by clicking this link so that the best car experts can view and post a solution to the problem.
On the page which opens, select the brand and model from the menu.
Thanks for using FixYa.
Posted on Apr 07, 2011
Geo storm wont start after putting in new battery,altornatior,plugs and wires,and cap and rotor
storms, those are very rare. and Isuzu is very dead here.USA.
which size engine?
wont crank/?
or cranks ok, but wont start.
its old.
1:check compression, yet, over 150PSI (w.o.t)
2: check for spark at all 4 cylinders?
3: try test fuel if spark is good (spray fuel)
watch scotty
http://www.youtube.com/watch?v=064Ilsz8Fzg&NR=1&feature=fvwp
tell us how far you get.......
btw , it really a:
manufactured by Isuzu and sold in the United States by General Motors from 1990 through 1993 as part of GM's Geo line
btw2
1.6L DOHC (Storm) Interference
both DOHC engins are interfernance
if you skip belt changes, the valve bend and bye-bye engine.
BOOM
and a new motor is more that car is worth.
Feb 18, 2014 | 1992 Geo Storm
Subaru rolling over, but won't fire
the mistake is washing the engine bay
water gets into every electronic connections and shorts out everything
use compressed air in all of the harness connections and use dewatering fluid ( wd-40 or the like )to remove the water
May 02, 2017 | Subaru Cars & Trucks
Electrical problem ??
Make sure the firing order is good these motors have a problem with the ignition coils you may have to replace it the tend to short when it is humid like when is snowing or raining.
Feb 01, 2014 | 1997 GMC Safari
Engines starts then stops running
might be time for new battery, they only last so long, usually 5 yrs is listed and that's if it's a good one to start with..more pricey. We just had the same thing happen to us. Turned out the alternator was junk, which wouldn't hold the charge from the battery and the battery was a 6yr battery, but we got 8 yrs out of it. Ended up replacing both alternator and battery in Advanced Auto's parking lot, during snow storm in NH!! They let us use their tools to replace both right there. They have tools and they checked both, no cost.
Apr 21, 2013 | 1995 Jeep Grand Cherokee
Ford 1981 f 150 not running changed Coil distributor cap Roar arm plug wires did not help started bur ran extremely rough then died
motors need 3 things to run properly. gas spark and compression. the starting point. also spark timing.
the motor you are dealing with is easy. i just rebult a 1978. anyways sounds like a timing problem . first i would check the distributer. if all is ok spay a squirt of starting fluid in the air filter, or even wd40.,,,,,,,see if it is gasoline problem. isolate where the problem is.
Aug 29, 2017 | Ford Cars & Trucks
Got stuck in snow storm left over night and engine compartment filled with snow tryed starting didnt start towed to heated garage for night and still wont start it smells like fuel in air box might be...
It probably is flooded from trying to start it.Originally the the air tube probably was packed with snow so the engine wasn't drawing air in. If you turn the key on and push the gas pedal to the floor this should activate what is called clear flood mode.If it will not still start would suggest removing all the sparkplugs and cleaning or replacing them also make sure that the air induction tube is clear and dry.
Mar 13, 2011 | Dodge Journey Cars & Trucks
Wont start .parked car before snow storm, now altho engine cranks battery good, car will not start
pour a little gas into the throttle bodie try startng if doesnt start hen do cap plugs and wires easy to change go throug wheel well
Feb 27, 2010 | 2000 Chevrolet Blazer
1999 ford Explorer 4.0 v6 4x4 will cranck but not start has spark
Honestly it's probably just dirty spark plugs. Did you pull any of the spark plugs and inspect the tips for build up? A couple things to remember:
1.) If the timing chain broke, the valves wouldn't be opening so you wouldn't have any air coming out of the exhaust during crank. You said it smells like you're getting fuel, so I'm assuming that means you're smelling the exhaust fumes, right?
2.) The crank sensor tells the ignition system when to send a spark to the plugs. If you're getting good spark, it's unlikely that the crank sensor is faulty.
If it's too soon for spark plugs to need replacing, check your sensors. A faulty oxygen sensor for example could cause your engine to run 'rich', resulting in faster crud build up on spark plug tips.
Feb 12, 2009 | 1999 Ford Explorer
GPS Logo
35 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
