Question about Acer Aspire M5100 AM5100-U5313A AMD Desktop PC - AMD Phenom X4 9500 Quad Core Processor 2.2GHz, 3GB
My tower beeps when i turn it on i have unplugged all the cords, transferred it to another power point and it continues to do this it beeps for 2 seconds and then beeps for 5 seconds and then pauses for a couple of seconds and just does this over and over again !
    Scholar:
  • 93 Answers
Try turning it off from the wall open the case and remove the ram (memory sticks ) from the mother board if there is one stick carefully clean the metal contacts with a new white eraser and reinstall it (if there are two sticks only replace one stick at a time ) if it boots with one stick then this was the problem if it doesnt boot and you have two memory sticks swap them and try again if it boots this time try shuting it back down and replace the second stic if it stops working again remove the faulty stick and replace it with a good one .(make sure you turn the computer of and unplug it every time you remove the memory .
I hope this helps Andrew a
Posted on Apr 07, 2011
Pet pulled out power supply cord and now tower won't work
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 04, 2012 | HP Computers & Internet
Hp officejet 6500 all lights are flashing and mechine says turn off and on . Please can someone Help??
: Check the power cord
1.
Turn on the product.
2.
Remove the power cord from the back of the product.
3.
Check the power cord for any physical damage. If the power cord is damaged, replace the power cord.
If these steps resolved the issue , you do not need to continue troubleshooting.
If the issue persists , continue to the next solution.
Turn the product off and then on again
1.
Press the Power button ( ) to turn the product off.
2.
Wait 60 seconds, and then press the Power button ( ) to turn the product back on.
3.
If the product does not turn off when the Power button ( ) is pressed, wait three minutes, and then proceed to the next solution.
Plug the product into a wall outlet
Follow these steps to make sure the product is plugged in correctly.
1.
Unplug the power cord from the back of the product.
2.
Unplug the power cord from any surge protectors or power strips.
3.
Select a wall outlet to plug the product into. Test the wall outlet by plugging another electric appliance, such as a lamp, into the wall outlet and turning it on. Unplug the test appliance.
4.
Plug the power cord into the back of the product.
5.
Plug the power cord into the wall outlet.
6.
Press the Power button ( ) to turn the product on.
Solution six: Reset the product
Follow these steps to reset the printer.
1.
2.
Unplug the power cord from the wall outlet.
3.
Wait 10 seconds, and then plug the power cord back into the wall outlet.
4.
NOTE: Many power cords have an LED light on the power module or on the end of the cord that plugs into the product. Make sure the LED light is lit and steady.
5.
6. Perform a partial reset of the product
  1. Disconnect the power cord from the product.
  2. Wait for 20 seconds.
  3. Press and hold # and 3 while reconnecting the power cord.
  4. When the product turns on, release both buttons.
  5. Try printing again.
IF still won't resolve it by following steps mentioned above then your printer needs replacement. Malfunctioning hardware.
Mar 28, 2011 | HP Officejet 6500 Wireless All-in-One...
The computer does not fully boot when turned on, and the tower makes a continuous beeping sound. The monitor works fine, the problem is the tower. The tower just keeps on beeping without turning on or...
Hello
That beep could mean alot of things, but probably a VIDEO CARD or RAM has become unseated.
If you feel comfortable with this, UNPLUG THE COMPUTER take off the case, remove and reinsert the ram chips, and the cards. You might need a screwdriver or two, and a LIGHT. The ram tabs are small.
Good Luck
Nov 25, 2010 | Microsoft Computers & Internet
It is stuck in power saver mode tried every thing can not get in come back up. Tried turning off and on, unpluged and pluged back in, put in cd, tried starting in safe mode with F8 key.
Possible that it's caused by a faulty hardware
1. Remove all the connection at the back of your computer
2. Power cycle your computer tower by pressing the power button for 15 seconds
3. Plug the power cord back in and monitor cable at the back of your computer tower (if it turned on, meaning that one of the device plugged at the back of your computer is the one's causing the problem, for you to pin point the problem, try plugging it one-by-one and turn on the computer each time you plug a device)
4. If it keeps on doing that, open up your computer tower (be careful to unplug the power cord and power cycle it to avoid static electricity)
5. Reseat the video card, turn on the computer again, if it's still occurring
6. Reseat the IDE/Sata cable of your hard drive and try to make sure it's properly plugged in, turn on the computer again, if it's still occurring
7. Reseat the memory, turn on the computer and test it again if the same thing
8. If you have 2 memory chip inserted in your computer tower memory slot, remove the other one and turn on the computer, do the same thing to other memory and each slot
9. Reseat the CPU and start the computer.
Jan 09, 2010 | Acer Aspire AM5641-U5520A PC Desktop
When I turn the printer power on, The lights are blinking.
  • Unplug Power Cord
  • Hold POWER and RESUME buttons
  • Plug in Power Cord
  • Release buttons after the printers starts up
  • Hold CARTRIDGE and RESUME
  • Press POWER
  • Release all buttons after the beeps
  • Press CARTRIDGE 16 times
  • Press RESUME
  • Unplug the Power cord
  • FINISH
  • Nov 12, 2009 | Canon BJC 55 InkJet Printer
    Sony VAIO RB30C (VGCRB30) PC Desktop Won't Turn On After reinstalling ram
    Unplug the tower
    Remove the ram and turn the tower on wait till it give you fast beeps. (telling you no RAM)
    once that happens shut the system down by unplugging it again
    Re-install your RAM and try to boot again
    May 26, 2009 | Sony VAIO RB30C (VGCRB30) PC Desktop
    My canon bjc 80 wont print and error light continually flashing
    Indicates Waste Ink Full error
    To repair follow the steps below
    1: Unplug Power Cord
    2: Hold POWER and RESUME buttons
    3: Plug in Power Cord
    4: Release buttons after the printers starts up
    5: Hold CARTRIDGE and RESUME
    6: Press POWER
    7: Release all buttons after the beeps
    8: Press CARTRIDGE 16 times
    9: Press RESUME
    10: Unplug the Power cord
    Mar 28, 2009 | Canon BJC 80 InkJet Printer
    Power light blinks
    The blinking button is an error code. You need to call HP and they will help you determine what the code means and how to fix the problem.
    Dec 20, 2008 | HP Pavilion a705w PC Desktop
    Printer won't print
    You should clean or replace the absorber pad at some point but most of the time you can get away with resetting the ink counter a few times before you need to clean or replace the pad.
    6: Press POWER
    9: Press RESUME
    Sep 07, 2007 | Canon BJC 85 InkJet Printer
    Troubl
    This is for when it beeps 8 times, but you might try this...
    6: Press POWER
    9: Press RESUME
    Aug 19, 2007 | Canon BJC 85 InkJet Printer
    Acer Aspire M5100 AM5100-U5313A AMD Desktop PC - AMD Phenom X4 9500 Quad Core Processor 2.2GHz, 3GB Logo
    117 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Steve Sweetleaf
    Steve Sweetleaf
