Question about ASUS Pentium 4 , Pentium 4, Pentium D, Celeron-D - Intel 945P - LGA775 Socket - 4GB DDR2... Motherboard
Dear sir, whenever the switch on the CPU its immediatly (With in 2 seconds)turn off, Power supply ok but CPU not booting. Thanks & Regards, shyam raj.
    Scholar:
  • 93 Answers
Hi Check that the power button is not stuck on or that the reset button is not stuck on as this will cause the machine to shut back down instantly i hope this helps
Andrew A
Posted on Apr 07, 2011
Hp pavilion modelp6510f press power switch on top of pc does not light computer fans blow but compute does not turn on
ok th p6000. complete range when they were made had to be recalled as they put the copper expansion pipes ran across the gpu & cpu hence a massive overheat problem. they put copper shims over the cpu & gpu but this worked for a short time but it was inevitable and both units ended up being cooked i had this problem with mine. so if you have tried external monitor with no images it would sound or more likely to be the gpu cooked sorry for the bad news.
Jan 28, 2014 | Computers & Internet
Dear sir SUB: my mother board problem (D945) whenever switch on the cpu its immediatly turn off. Thanks & Regards, Y.Shyam raj.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Apr 05, 2011 | Intel D945GCCR Motherboard
No video from motherboard even with new video card
Dear sir,
if this board has AGP slot, try to use AGP card inspite of PCI display card .. second thing when u power up the board . short its crystal oscillator for 2 second during switching on ..by screw drivers..if if it will not provide display .
then open fan & reinstall CPU .. if cpu is OK ( only can be tested on other board ) ..then something is wrong with Northbridge ../ or power supply mosfet of board if fan is not running ..
Regards
raj
Jan 26, 2011 | Asrock P4i65G Motherboard
Emachine t6216 will not boot, fans stay on high and thats it. I do not hear hard drive spinning. It shut down a couple times while in use before this and came back on. also, it did not boot before and did...
hi Rpbarnhart.
this could be a few things wrong here.
the first thing i would get checked is the power supply.
Most likely either Motherboard or the CPU. Does this have a graphics card or built-in.
Standard procedure is to:
Clear the CMOS - chk manual for procedure.
Disconnect all cables from all drives and test.
Pull RAM and try with one module at a time in slot 1. Then try 1 in what might be slot 3, the 1st slot of second pair of slots.
Before giving up, I'd pull all the drive cables at once. Even carefully mark the front case wiring and pull everything but power switch if you can. You really want to remove all complications that might be an issue. Take it down to PSU, motherboard power, cpu fan and RAM.
Ok, there is Good news, and bad news. FIRST the bad news. You are not getting any power to the CPU. Fans and lights indicate motherboard power, BUT, power supplies ALSO provide power straight to the CPU, and if the CPU is not getting powered properly, it will not function.
or you could check these links out if the above does not work for you.
https://it.toolbox.com/question/my-emachines-model-t6216-does-not-boot-into-bios-061810
Build PC Emachine will not boot up
https://forums.techguy.org/threads/emachine-wont-start-up.1198007
Dec 08, 2017 | Computers & Internet
It turns on then immediatly goes black
hi,
check the power supply to the monitor...
the problem here is a corrupted BIOS you can correct it by booting the system with default settings...
if you are not getting any display then you can try the following
it should be blinking, the lights on the monitor... the cpu is working (all fans running)
then switch off the system...
remove the cover of the CPU on the motherboard there is a small battery called CMOS battery take out the battery after a minute later put it back...
it should fix it....
please give a vote if it helps
Mar 13, 2010 | Computers & Internet
CPU fan turns for a few seconds and stops, pc will not turn on. Have tried a good PSU, same issue. Removed all connection to motherboard apart from 20 pin, 4 pin power + cpu fan and PW switch: same issue.
1. First of all Remove dust from your CPU fan and try again if issue has been not resolve
2. Second test your SMPS by the help of Green & Red wire. In case fan is turning properly it mines your SMPS is ok
3. Third & last kindly replace your SMPS For the same.
Nov 19, 2009 | HP Pavilion a1120n (PX759AA) PC Desktop
Monitor looks as if there is no CPU
If the power supply is coming to CPU before activation of CPU then it must be receiving current from UPS. Don't try unplugging, You may get shock. Thank you, Sir.
Sep 17, 2009 | Computers & Internet
Booting problem
try these two alternatives:
1.try to clean or change the slot of the memory
2. check on th power supply you put on your motherboard for the new board there are the socket for the power to be placed on the otherboard
Dec 22, 2007 | Biostar P4M890-M7 Motherboard
Onkyo SR502 Shuts off by itself
It is not a blown fuse. Your baby is in its ***** throes! It is fubar. You have either a damaged power supply or blown output stages (since sounds horrible it is probably this).
Sep 17, 2017 | Onkyo TX-SR502 Receiver
No power up
Here was the fix for me. The machine refuses to boot if the video card is not functioning. It should have one long beep however to tell you that there is a video problem. Someone hooked up our speaker incorrectly though! So we got no beeps. Once the speaker was hooked up and the video card was replaced, all is well!
Oct 23, 2006 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
ASUS Pentium 4 , Pentium 4, Pentium D, Celeron-D - Intel 945P - LGA775 Socket - 4GB DDR2... Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
