Open remote case - Televison & Video
Installing digital transport adapter -
need remote code
These do not work(10054, 10037, 10690, 11483
Posted on Apr 07, 2011
How to open remote for Onkyo TX Sr304 AV receiver (surround sound)
Remote controls have snap-together cases that require careful handling to open. Some have a screw hidden under a label to make matters more difficult. The tedium of unsnapping the case will make you long for simply replacing the whole thing.
Apr 22, 2017 | Onkyo Televison & Video
How can I open my TARGA VISIONARY LT3220 remote control in order to clean its interior?
look for any small screws in the battery compartment
or on the back casing
other wise it is all plastic tags and clipped togeater
you may break the remote
with care prise the sides of the casing open
Sep 03, 2016 | Televison & Video
My remote control HTT10-CRP which does not function any more.
you can open the case of you remote maybe there is 1 screw inside the battery holder or if there is no screw its only at clip type you can open it with the help of flat screw or knife...and then clean it with alcohol both the board and the rubber..
Sep 12, 2015 | Televison & Video
How to install replacement battery on nevo q50 remote
Switch off with the main power switch. Remove the stylus. Remove the rubber feet. They prise out gently with a fine tipped flat blade screwdriver. Undo the two screws beneath. It should now be possible to use your nails to split the clamshell case. Start at the end that was screwed together. Work the case open as if it were hinged at the IR emitter end.
Sep 13, 2014 | HQRP Battery for NEVO Q50 Remote Control /...
Hi, My sony remote failed recently Model
There is some locks on its upper and lower case. You can locate it by its side slits.
Oct 06, 2013 | Televison & Video
My garage opener remote on my 2003 santa fe just stopped working. How can I fix it?
There is a battery in the remote.If the battery gets old the remote will stop working.Replace the battery and check.Also if your battery is new but still the problem is there then,try to open the garage door by keeping less distance between remote as well as the garage door.Also there is a sensor in the garage door.If that sensor is not functioning then this can be one issue.In some cases the internal remote circuit gets short,in that case the remote needs replacement.But does the garage door sensor light shows any sign of getting connection from remote when you press the remote button.Open the door and try to close the door with remote and check.As per the problem,in most cases its weak battery related problem,and replacing the battery solves the problem.You can try all the possibilities and see which one helps.Thanks.Helpmech.
Nov 12, 2010 | 2003 Hyundai Santa Fe
Need to change battery
Open the casing with a flathead screwdriver by orying open at the slot in the side. Completely remove the circuit board from both halves of the casing to access the battery.
Jun 13, 2010 | Genie Company IntelliCode GICT390-1BL...
I can't open the case so I can't change the batteries. how do i open the case?
Pull the front cover of the thermostat straight off the base.
Pull the front cover of the remote sensor straight off the base.
Oct 03, 2009 | White Rodgers White-Rodgers 1F85RF-275...
How to open remote control Sony RM-Y181
There should be small screws (usually phillips head) at either the top, bottom or both ends of the back of the remote. Unscrew those and pry loose. If not, they will be under the batteries, inside the battery cover.
I assume that's what you mean by open?
:D
Aug 10, 2009 | Televison & Video
Opening the case of a JVC Remote Control
Not having seen that particular one, remote cases usually have a couple screws under the battery to lock the case together and then a number of plastic tabs around the perimiter that hold the joint closed. find the screws (sometimes they hide them under labels) - I don't know what it is about screws that manufacturers don't like to show. Either think they are not cosmetic or don't want us take-it-apart maniacs to get in. Anyway, get the screws loose then (this is the hard part) carefully pry open the case joint, feeling where and how the tabs snap out and then be careful not to have everything inside go flying when the last one lets loose. Almost impossible to not leave little gouge marks in the joint.
Hope Ya Fis It!
Jan 08, 2008 | JVC AV-27230 27" TV
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Electro Med Services...
