Question about HP LaserJet M1522n MultiFunction Printer
I am having my printer installed on my pc but iam not able to scan any of my document. It attempts to check whether ny scanning software is properly installed or not. please help
    Scholar:
  • 83 Answers
How to clear scan data
Your machine will show 100% and that is correct. It doesn't mean memory full, but rather the amount of memory that is still available. Once you scan a document you will see the memory drop down to 99% or even lower depending on the size of the scan. If you don't see this happening than you are not scanning. Other than that your scan will either go to a folder on your PC or straight to your email. All you need to do is locate the folder it saves your scan in (usually created in your C: drive) or check your email folders including your Spam/Junk mail folders.
May 25, 2016 | Ricoh Office Equipment & Supplies
I cannot get the scanner option on my 5610 to work with my mac book pro. I've used the install cd for macs. Not sure what else to do.
This issue when we try to scan from the all-in-one, once try to scan from the all-in-one software, make sure that the software is inatlled properly because we can scan from the all-in-one only when the full feature software is installed in the computer. If we are able to scan properly from the computer then check whether digital imaging monitor is running or not in the taskbar. If it is not running reinstall the all-in-one software
If still can't get scan to work. Printer states "no scan options". If you have windows vista and it comes up with the "no scan options" don't press the button on the printer, go to "start" then "accessories" then "paint". This will open up the windows paint program. Go to "File" then click on "From scanner or printer". It will then scan the document.Thanks
Feb 01, 2011 | HP Officejet 5610 All-In-One InkJet...
How do I scan a document? I press scan and it asks me to wait and then nothing happens.
You didn't mention which machine is it for. Either way scanners need software listening on the computer side to accept scanned images.
So assuming that there are no hardware (including cables to PC) problems, you should check that proper driver and application software are installed. Re-installing is a good idea.
Good luck
pls. vote for better service... Thank you
Nov 20, 2010 | Office Equipment & Supplies
I need to scan a printed page into a txt file using Notepad. Gone through the Lexmark Imaging option and attempted to scan, Come up with a message about installing OCR software. I can't find original...
The Lexmark OCR scan software allows you to scan documents to your computer. It enables you to scan to PDF or scan a document and convert to text to edit. The Lexmark OCR scan software is only available in the install disk that came with your printer. Please contact Lexmark technical support for assistance. Thanks.
Nov 12, 2010 | Lexmark X2350 All-In-One InkJet Printer
I am trying to get my dell v305w printer to scan and it keeps telling me downloading application list and then it says after 2 mins unable to download apps
The printer is trying to connect to your pc to download a list of programs to send the scanned document and/or picture to when you use your scanner.
The printer will only scan to certain software and there are separate choices for handling pictures and text documents.
When it tries to communicate with your pc to find software that it can scan to, its not finding any installed that will work with your printer. Its telling you that it is unable to get the list of applications after attempting to connect with your pc.
So, what does that mean?
It means that either "bi directional support" is not enabled in your printing preference so your printer is limited to sending info one way oly (to the computer). If this is the case you can go to your control panel and then choose printers and check the preferences listed there.
OR
You don't have applications installed in your pc that your printer can send scanned documents to.
If this is the case then you need to install software that your printer will work with and then set the options on your printer to pick the default you want to use with both pictures and text documents.
Printers usually accept microsoft word, word pad, microsoft works and any other word processing software to scan text documents to.
Printers usually accept just about any picture editing software installed on your pc to send scanned pictures to.
You can avoid all of the above by checking to make sure that your printers software is 100% installed including the scanning features. Go to the Dell website and update the drivers on your printer to make sure you have the full version that is most current.
The printer will always use its own program to scan both documents and text to regardless of the other software applications you might have installed on your pc.
Sep 27, 2010 | Dell V305w All-In-One R840635AU InkJet...
Hello I have a hp printer and I am trying to scan a document to my pc.but i get this error msg 'scanning error'try scanning from pc or check documentation.
You must also install the scanner driver too, and also the scanner management software, if installed properly one can scan fro paint, Word, Publisher and the like, as well as the software that comes with the scanner. There are also other scanner programs on the net, Vuescan, doesn't even need a driver to work, there is scantopdf, and quite a number of others. So go to the HP website and download the scanning software and the scan manager and install them, then you will be able to use the scanner as it was intended.
Jul 12, 2010 | Office Equipment & Supplies
Scanning problem
You are using HP PSC 1610 and There is an easy option available for you to scan documents/pictures directly to Email since you are using Outlook.
for this, you will find need to check if HP Solution Center is installed in your pc ? if not, you need to install it to make things easier for you.
If you have not installed the complete software for your printer, you will not find HP Solution Center in your PC.
Download the Software from this link :
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=4062&lc=en&cc=us&dlc=en&sw_lang=&product=390315#N845
There is also a printing patch available incase you have upgraded your PC from Vista to Win 7
After you have installed the S/w, check for HP Solution Center on the Desktop.
Click on Scan Document and Click on DOCUMENT to EMAIL option and click Scan, The Scanned document will automatically get scanned and Attached to Blank Email.
Jun 24, 2010 | HP PSC 1610 All-In-One InkJet Printer
How can i use my xerox m15i to scan documents/
install software on the pc
place paper on the glass of the printer
on the software click scan
or on the printer scan
check in the pc
Oct 29, 2009 | Xerox WorkCentre M15i Laser Printer
HP 3310 will NOT scan
This issue occurs when the digital imaging monitor is not running or the software is not installed properly.
This issue has nothing to do with the cartridges.
If the printer in connected in wireless, once check the communication between the computer and the printer and then disable the firewall and antivirus and try to scan again from the all-in-one. Also try to scan even from the HP solution center.
If the printer is connected via USB then try to scan from the HP solution center and then check the result, if the issue persists check whether the digital imaging monitor is running or not, then try to scan from scanners and camera wizard.
Sep 17, 2008 | HP Photosmart 3310 Printer
HP OFFICEJET 5610V No scan options
If you get the error while trying to scan with your HP 5610v All-In-One, the easy way to scan from your printer is to click on start, go to Paint and then File, the option "From Scanner or Camera" will come up.. click there and poof - you can scan anything you want and save it where you want... Problem solved!! good luck!!!
May 24, 2008 | HP Officejet 5610 All-In-One InkJet...
HP LaserJet M1522n MultiFunction Printer Logo
27 people viewed this question
Seeker5211
Seeker5211
