Question about GPS
Mitsubishi carisma central locking lock but doesn't unlock ,I use to unlock by usng door key. car made 1998. is in there central controller if yes where it is? also may i have a electric schema?
  • 3 Answers
SOURCE: 1999 Audi A3 1.8T Electric Windows and Central Locking Won't work
will your passenger door open with the key and is it just one side that your windows are not working or both. if its just one side it might be your regulator motor in the door thats not working if its both it might be your central locking pump usually in the boot. however if both of them are working fine it could be that your key needs reprogrammed however i think the 1st 2 are more likely to be the problem.
Posted on Jun 30, 2009
  • 4946 Answers
SOURCE: ford fiesta ghia 1998 model central locking key
This is a common problem after changing the Key Fob battery.
The solution is to remove the fuse feeding the Cental Locking for 10 minute...Replace then all should work fine
Posted on Sep 12, 2009
  • 149 Answers
SOURCE: land rover discovery central locking.
No, likely to be caused by the actuators in the lock mechanism failing usually causing the door to remain locked. The boor door can also fail this way, as do the front side doors. Replacement requires the whole lock unit to be replaced at a cost of roughly £60 a lock, and a hours work. Helps if you have small hands. Requires a full strip down of the door and you will need the lock unit, trim clips (a few quid) and a trim removal tool (tenner). You can bodge with a flat head screwdriver, but the tool does help prevent damage to the clips & trim panel.
Posted on Feb 22, 2010
  • 13 Answers
SOURCE: can not lock car by key remote . toyota rav 4 53 plate
If your car has an alarm with a separate remote, it is a separate system and it is probably self-arming. When you lock the doors with the key central lock, the alarm gets armed by the RAV4 being OFF and the door locking action. When you unlock the doors with the key, the alarm is still armed because the key is not comunicating with the alarm just the cars factory keyless system.
Posted on Apr 10, 2010
  • 4793 Answers
SOURCE: mk 4 golf, remote key not locking/unlokcikg doors?
unlock with key and hold key over for 30 secs(windows may go down)then lock with key and hold over for 30 secs(windows may go up)then press remote unlock button and hold for 30 secs,you have just reset system...the closer you have to get to the car for the remote to work the lower the battery power.sensor on top of dash(little black dimple)rarely,if at all, goes wrong.....
Posted on Jun 11, 2010
What would cause central locking to lock and unlock while driving along in a Gu 1998 St
Probably a bad input signal to the module that controls the lock & unlock , central locking system is controlled by smart entrance control unit .
You can watch this video , is an american vehicle with switch input to the BCM - electronic control unit .
Door Locks Go Crazy 1
Door Locks Go Crazy 2
Door Locks Go Crazy 3
Finding a repair manual an looking at wiring diagrams for the lock circuit an looking to see what all is involed an testing like the guy in the video .
Dec 12, 2017 | Cars & Trucks
Is there a reset for door locks
Have your central locking module checked by an auto electrician it could be fault or there might be a short circuit in the central locking circuit.
Mar 27, 2014 | 1998 Mazda 626
My Mitsubishi colt CZ1 (07 plate) has problem with cental locking. I can manually central lock but with the remote it locks/unlocks all the doors except the driver's door. Please help. Thanks
Central locking works by way of little electric motors that engages and disengages the door lock. The drivers door has an additional set of contacts in the actuator which signal the controller when it changes position. The controller activates the servo motors when a signal is received from the receiver or from the drivers door servo motor. So in your case I suspect the motor part of the drivers door actuator is done for.
To replace you will have to remove the inner driver's door panel to get at the actuator. The actuator itself cannot be repaired and needs to be replaced as a unit.
Apr 29, 2011 | 2006 Mitsubishi Colt
Where is the re-set button to program a remote door lock for my 2000 Subaru Forester?
Obtain all keys/remote controls. Remove driver's side kick panel/lower 'A' pillar trim. Connect central locking registration connectors (white) - black wire and black/blue wire Fig. 2 . Unlock the vehicle using the key. Program first key/remote control as follows: Press unlock button Fig. 1 [1], then lock button [2]. The door lock should lock and unlock in sequence confirming programming of first key/remote control. Repeat programming procedure for remaining key(s)/remote control(s). Once the last key/remote control is programmed disconnect central locking registration connectors. Check operation of all programmed keys/remote controls.
Sep 03, 2010 | 2000 Subaru Forester
Rear door hatch won't unlock at all the remote unlocks all doors except the hatch. Once in awhile it might open
some cars are fitted with a valet key/lock 3 keys supplied new 2 normal 1 with a flute running down the middle.key with flute will not unlock the tailgate/glove box.tailgate has 2 positions key upright=locks with central locking.key turned to the left,(or right,cant remember which)then released to upright,locked,needs key to access.independant of central locking.
Jun 24, 2010 | 2004 Mitsubishi Endeavor
The doors do not open by remote control key(BMW 740il 1996 model)
Programming
When
Key batteries completely discharged. Key batteries not replaced within 60 seconds. Key added or replaced. DO NOT press remote control buttons during battery replacement.
How
Unlock vehicle. Enter vehicle. Close driver's door. Switch ignition ON and OFF. Remove ignition key. Press and hold unlock button Fig. 1 [1]. Press lock button Fig. 1 [2] briefly 3 times within 10 seconds keeping unlock button [1] depressed. Release unlock button Fig. 1 [1]. Some models: LED Fig. 1 [3] flashes slowly for 10 seconds. Some models: Central locking system locks and unlocks rapidly to indicate correct programming. Some models: Repeat above procedure if central locking system does not work and LED does not flash or LED flashes continuously
To change batteries remove panel back of key then screws on plastic bar
Batteries are available from your local motor factor shop
You might not need new batteries try re programing as described above
Apr 24, 2010 | 1998 BMW 7 Series
1998 Toyota Corolla Electric Door Lock Problem
You'll need to replace the solenoid (motor) that doesn't work. Not hard once you get the door panel off. I suggest you buy the correct part, not a universal one.
Jun 12, 2009 | 1998 Mitsubishi Eclipse
Programming Key Fob
how to reset key fob after changing battery on a mitsubishi carisma
Jan 02, 2009 | 2002 Mitsubishi Montero Sport
What is the switch by handbrake picture of key inside a window
it is an anti theft device use to lock the shifter.
Dec 21, 2008 | 1998 Mitsubishi Galant
Ford fiesta ghia 1998 model central locking key
Nov 30, 2008 | Code-Alarm Code Alarm Transponder
GPS Logo
90 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
