My samsung washer WA80U3 will not hold water. it starts to drain the water as soon as i hit the power button.
SOURCE: Maytag legacy series washer not holding water
Same problem here. But according to Maytag Service, the draining pipe may be too deep inside the draining tube on the wall, thus creating a siphon effect and not allowing the tub to fill.
Their suggestion is to ckeck the pipe and make sure no more than 6-8 inches are inside the draining pipe. This should take care of the suction. We'll see, Imma do that when I get home.
Posted on Jan 15, 2009
rylee_smith
  • 8619 Answers
SOURCE: maytag neptune washer MAH-1 start button turns off, does not spin
Hi!
Is it pumping water? If not then pump is bad.
Is the door locking? If the door will not lock, the washer will not enter a spin mode. See if the lock light is lite on the console.
Check for continuity across the Door Lock, Spin Enable Switch when the switch actuator button is pressed in. If there is no continuity across the Door Lock, Spin Enable Switch, replace the Door Lock Switch Assembly.(Check for 120 vac across the Door Lock Wax Motor)
Please rate this solution and ask for further clarifications if needed.
Thanks
Rylee
Posted on Feb 13, 2009
  • 32 Answers
SOURCE: Duet Washer not starting
when you hit start button does your washer makes one beep and go off ? if yes i think it is your main control board need to be replace.
Posted on Jun 25, 2009
heatman101
  • 43501 Answers
SOURCE: my washer machine does not hold the water keeps draining
Here is a tip that I wrote about the problem you are having with your washing machine...
Water will not stay in Washing Machine
http://www.fixya.com/support/r4696322-water_will_not_stay_in_washing_machine
heatman101
Posted on May 07, 2010
SOURCE: Samsung Front Loader wf306law took off back panel
I found MayTag has a full report on this washer. https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8169153c018494398525729c0057a4d2/$FILE/Samsung_Frontier_Washer.pdf
The part number is DC97-10417A and can be ordered at samsungparts.com
http://www.samsungparts.com/Products/Parts_and_Accessories/PID-DC97-10417A.aspx
Posted on Jun 21, 2010
My samsung wasing mechine does not stop filling water. model wa80u3
it seems the washer's inlet solenoid isn't responding to the diagnostic computer on the washer and needs of replacement contact samsung to have it serviced
Feb 21, 2017 | Samsung Washing Machines
SOMETIMES THE MACHINE DO NOT RINSE OR SPIN? I EXPECT THAT THERE IS SOMETHING WRONG WITH THE SETTINGS?
I am seeing alot of these questions regarding samsung washers they are usually very good I am thinking there is too much weight in your washer, are you filling the washer too full, they can only handle so much weight before they just throw themselves into error codes. So if its clicking hit the power button does it drain the water, i am asking to see if the pump is working, if it drains , when its done unplug the unit wait ten minutes and plug it back in and turn power on, dont hit any other buttons what does it do?
May 02, 2016 | Samsung SW62ASP Top Load Washer
How do I replace the water pump
Not enough information, are you stating when you start the cycle no water enters the tub?
The normal operation at start the washer goes into drain first then starts the cycle.
Jan 07, 2015 | Samsung DMT300RFS Dishwashers : Built in...
Drain pump continuously running on Samsung Model WF448AAP/XAA
do pull the plug out first
not funny dancing with the machine
have you checked the pressure pipe for any cuts
look near the pressure switch area first
Feb 05, 2014 | Samsung Washing Machines
When I accidently push the start button when I mean to push the key button to open the door, the cycle will start again. Is there any way to stop it?
Push and hold down the start button again. The machine will stop. Turn to Spin (to drain the water that burped into the machine when you turned it on by accident). Hit start, let the drain and spin cycle complete. Hit the key button and you're all set.
Sep 24, 2011 | Asko W6021 Front Load Washer
LE code AGAIN! Washer serviced twice now- hall sensor and main control board already replaced. How do I get the water out so I can try the load again?
You will need to drain the water via tapping the power button, then press the spin speed button, and then hit start, the water should drain.
Sounds like it's going to be your Stator assembly, and not a Hall sensor problem.
Mar 07, 2011 | Washing Machines
Samsung vrt washer will begin cycle but get so far then just stop and wont spin or drain water. You can restart the load to get the washer to start again but will do the same thing again.
You might have an object jammed in the pump housing. First thing you must do is to unplug the machine from the power outlet.You will then need to remove the back panel of the washer to access the pump. Disconnect the wiring from the pump and remove the two hoses by compressing the two clamps. ( Be ready for water to pour out of the hoses) Remove the three mounting bolts that hold the pump to the frame of the washer and remove the pump assembly. It is easier to work on the pump if you remove it from the mounting plate. Remove the three screws that hold the impeller housing to the pump motor. Seperate the two parts being careful not to damage the rubber o-ring that seals the unit. Inspect the impeller housing for any debris. (I found a nickle blocking the outlet port in mine). Remove anything you may find and reassemble in reverse order. The machine should reset itself and run as normal.
Jan 08, 2010 | Samsung WF203ANW Front Load Washer
Smart Drive 601 does not drain
with the machine plugged in and turned on but not powered up this is what to do
press and hold down the start button, then press and hold down the power button (hold down for 5 seconds) the washer may beep up to 3 times during this process
next remove fingers from buttons, then turn off machine with the power button, then turn on again and only press the start button this will now reprogram the computer
let it run untill end of cycle and this should fix prob
Jun 11, 2009 | Washing Machines
LF Error Code
How is the water filling? Slower than it should?LF (long fill) Start by removing the hot & cold hoses off the back of washer ,now look inside the valve for clogged screens,if they are clogged ,clean them.If problem continues replace the water valve.
May 26, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
95 people viewed this question
Top Washing Machines Experts
