The machine comes up with remove tape.i have replaced the toner cartrige with a new one and the machine does the same thing.the black toner cartrige is being replaced.
    New Friend:
  • 140 Answers
You can reset install cartridge error. from service mode.
Posted on Apr 07, 2011
Samsung scx3405f compatible toner
hello . i have a samsung scx-3405f and i have been refil the cartrige ... after i refiled my multifunction machine say on the display "Not Compatible toner cartrige". i donn`t know what to do to him because i have buy a new cartrige and she tell me the same thing. please answer to filedoc2008@yahoo.com ... tks verry mutch
Feb 05, 2013 | Samsung SCX 3405FW - Multifunction fax /...
Brother HL-5250 printer toner Light on but Cartridge has Toner it
Try this....
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Mar 08, 2010 | Brother HL 5250DN Laser Printer
What does it mean when the printer says "prepare new k cart"
It means that the black ink cartridge is going to be used up soon so you would better get a replacement at hand to avoid interruptions.Probably REPLACE K CARTRIDGE will appear sometime later.
To replace cartridge do as follows:
Get a Black (EP-87) Toner Cartridge.
  1. Press <Menu>.
  2. Press <la.gif> or <ra.gif> to select [MAINTENANCE], then press <Set>.
  3. Press <la.gif> or <ra.gif> to select [CHANGE CARTRIDGE], then press <Set>.
  4. Press <la.gif> or <ra.gif> to select the cartridge to be replaced, then press <Set>.
    Select [BLACK]
  5. Lift the scanning platform and open the cartridge cover when the sound of machine operation stop.
  6. Make sure that the toner cartridge you want to replace is at the position for replacing.
    Ifthe spent toner cartridge is not in the replacement position, close thecover, then open it again when the sound of machine stops. Repeat thisprocess until the cartridge you want to replace is in the correctposition.
  7. Remove the toner cartridge from the machine.
    Hold the grip on the toner cartridge and lift it straight up.
  8. Confirm the color of the label on the toner cartridge holder,then take out a toner cartridge of the same color from the protectivebag.
    Open the protective bag with scissors, so as not to damage the cartridge.
    • Keepthe protective bag in which the cartridge came in. It may be requiredwhen taking out the toner cartridge for machine maintenance.
    • Becareful not to hold or touch the prohibited portions such as the sensoror electrical contacts. It may result in damage to the machine.
  9. Hold the toner cartridge as shown in the figure, shake it gently 5 or 6 times from side to side (1), then back and forth (2) to evenly distribute the toner inside.
    • Iftoner is not distributed evenly, it may result in a deterioration ofthe print quality. Be sure to carry out this procedure properly.
    • Be sure to shake the toner cartridge gently. Toner may spill if the cartridge is handled without caution.
  10. Remove the protective cover. Hold the protective cover and remove it as shown in the figure.
    It may be a little snug, but it will pull off.
    • Donot touch or hold the developing roller. The image quality maydeteriorate if you do. Do not apply shock to the toner cartridge memoryor bring it near magnetic waves as this may result in damage to themachine.
    • Keepthe protective cover with which the cartridge from removed. It may berequired when taking out the toner cartridge for machine maintenance.
  11. Place the toner cartridge on a flat surface, then pull out thesealing tape (Approx. 45 cm (17.72") in length) while supporting thetoner cartridge.
    Hold the tab on the sealing tape and pull it straight out.
    Ifthe sealing tape is pulled out forcefully or stopped at midpoint, tonermay spill. If toner gets into your eyes or mouth, wash it awayimmediately and consult a physician.
    • Donot pull the sealing tape diagonally, upwards, or downwards. If thetape is severed, it may become difficult to pull it out completely.
    • Pullout the sealing tape completely from the toner cartridge. If thesealing tape remains in the toner cartridge, it may result in adeterioration in print quality.
    • Dispose of the sealing tape according to local regulations.
  12. Hold the grip on the toner cartridge and install it in the machine.
    Position the triangular mark on the toner cartridge with the triangular mark on the machine and instlal the toner cartridge.
    Whenthe toner cartridge is installed properly, the label on the cartridgeand on the toner cartridge holder will be aligned as shown in thefigure.
  13. Close the cartridge cover and lower the scanning platform.
    The toner cartridge holder will rotate automatically.
Nov 27, 2009 | Canon imageCLASS MF8170C All-In-One Laser...
The cartrige sensor always alarm the toner is low and stop working while it is not, it keeps bothering us, and now it cannot start work. How can we deal with it?
Just cover the eye that you can see in the bottom of the machine after removing the imaging cartrige with a small piece of electrical tape. When your getting low on toner you'll notice it on the prints. Just remove the tape
Oct 21, 2009 | Brother HL-4070CDW Printer
Fairly new toner and display reads "Install black cardtricge"
I have just resolved the "Install black cartrige" issue on my printer I am not sure if it will solve everyone's problem but these are the steps I took to solve the problem.
1. removed the black cartrige.
2. removed all the paper from the tray and noticed that one of the pages was a little jammed.
3. I then turned the printer on and off again and still encountered the "Install black cartrige" error message.
4. I then put the black cartrige back in the the printer and restarted the printer.
5. When the printer restarted it started to initialize correctly and I perform some test prints to confirm that it was back up and running.
Apr 07, 2009 | HP LaserJet M1522nf Multifunction Printer...
How do I change the waste toner bottle?
The waist sump is in the Drum Unit.
If the messege says to replace sump unit, either the drum unit has to be replace(Copy Cartrige) or, if you wish to do this,
remove the copy cartridge and remove the front black cover with the small rectangular metal cover. I beleive they are 3 - 5.5 mm black bolts.
On the back there is a black knob that has to be rotated, to swing the drum out. On the front there is a brass spacer that has to be removed.
Pull it off and pull out the drum. the top of the drum has to come off and the bottle comes out. Vacume out the toner into a waist bag, or dump the toner in a plastic bag. its your choice.
If not buy a new drum unit.
The machine needs to be reset in the maintaince area of the menu.if you cannot find it, the machine will come up with the replace waist sump.
You will need to find this, or call Xerox to have a service repair person enter diagnostics to remove it from the machine.
Mar 05, 2009 | Xerox 5665 Copier
Changing toner cartriges
Check to see if you have removed the shipping strip. This alows the toner to be distributed. Make sure you get the whole thing out or you will have printing problems.
Oct 27, 2008 | HP Color LaserJet 2600n Printer
Lexmark C500 Error light showing,with New ink cartrige inserted showing toner low replace cartrige on machines display? Help!! thanks
Remove the cartridge, take a flashlight and check the right side inside the printer for a RED LED (in the place where the cartidge stays). Take a tape and patch that LED. That's all ! Enjoy
Jul 02, 2008 | Lexmark Office Equipment & Supplies
Printing Red not Black
remove the black cartrige, check if u removed the plastic protection tape then try to clean manually the print cart. with soft cloth when cleaning.. a black ink should apear on ur cloth if not change the black cartridge
Nov 16, 2007 | HP Officejet 7210 All-In-One InkJet...
jasbo
jasbo
