Question about Nokia 6300 Cellular Phone
When i send video files via bluetooth from other mobiles to my nokia 6300, the message displays on the screen " file sending failed".Audio files received successfully but video files not. there is enough free memory in memory card. kindly give me some tips so i can resolve my problem. Best Regards, Iram Malik 0303-4508302
  • Nokia Master
  • 2,148 Answers
Generally video files are bigger in memory than audio files.So firstly you check the memory status of Phone memory not for the mmc memory.And Check that the memory Card which you are using is less than 1GB Coz more than 1GB mmc is not supported in this model.Even if the mmc has enough space of memory however the size of the mmc is more than 1GB we cannot do this thing sometimes.So try to do what if not.
Posted on Apr 07, 2011
How to send music in cellular phones via bluetooth
Hi.Make sure that the sets are currently active the bluetooth or not....and in the bluetooth setting Phone's visibility should be "Shown to All".Open the music file list and drag the key to the particular files you want to send after this press option and select Send Via bluetooth.Than you will be asked for selecting device "just press New Device".This are the procedures.Good luck
Oct 06, 2011 | Nokia 6300 Cell Phone
My nokia 6300 does not receive data via bluetooth it says operation failed but i can send data
nokia 6300 you have to reinstall the bluetooth device in the nokia servies center.and then you can receive dates from other phones.[or] copy the datas to pc and formet the memorycard........
Nov 19, 2010 | Nokia 6300 Cellular Phone
I cant recieve any music it keeps saying operation failed.
when i send music with my mobile via bluetooth on my phone it says "operation failed"..
Mar 16, 2010 | Nokia 6300 Cell Phone
Nokia 5200 Bluetooth problem
check your phone memory.That should be greater than the size of the file that you are trying to transfer..check which is your memory in use also.If memory is available check the phone visibility and try to pair the device and send..it will get clear....Hope this will help you...
Nov 21, 2009 | Nokia 5200 Cellular Phone
Not able to send anythin via bluetooth....!!!
I don't know whether its exactly the solution or not, but I had a similar problem transferring some mp3 files to any cell via bluetooth from my nokia 7210, I tried all combinations of bluetooth settings, but the same message kept appearing-"Sending failed", finally what I did was "Changing the name of the mp3 files" as all those I wanted to send had a bigger name, I cut the name short and there it worked. So, may be in any such case it's advisable to just try this out, it might just work.
Jul 17, 2009 | Sony Ericsson K790i Cellular Phone
Not able to receive .wmv files to my mobile throug bluetooth. Shows 'Operation failed'
hello friend through blue tooth u cant send big files its cant make it MWV files means big files like so check it .
Jul 14, 2009 | Nokia 6300 Cell Phone
Send file via blue tooth
Hi Friend,
Actually u can transfer directly from your Laptop to mobile around 10 mb.U can use the Nokia PC suite and transfer the files from PC to Laptop or Vice versa.
U can download the Nokia PC suite from the Below Link
http://www.nokia.co.in/get-support-and-software/download-software/nokia-pc-suites/compatibility-and-download#download
Copy and paste the link in the browser and scroll down u will be able to see your model(Nokia 6300) download it and install it in your Notebook.
Then u can access mobile from your notebook with the help of datacable or bluetooth
After installing u will be getting a in the desktop as nokia pc suite double click it and connect the mobile as per the steps given over there (its user friendly).
Then u can access the mobile from Notebook and transfer the files.
Kindly check it and revert back
Regards,
Ayyasam
Jun 25, 2009 | Nokia 6300 Cellular Phone
While recieving data from other mobile it shows a message as operation failed.
The memory in your phone or memory card may be full, hence you cannot receive any more data; either you or the other party may have accidentally cancelled the transfer of the data; or if they are sending a file (picture, song etc) via bluetooth and THEY have a password set on their phone and they do not put the password into YOUR phone to allow you to receive the data, then it will cancel the sending of the data. Hope that helps and/or makes sense :)
Feb 18, 2009 | Nokia 6300 Cellular Phone
PROTECTION CODE FOR NOKIA 6300
okay fernando here is how to do it okay
but when u fininsh rate my post dont forget all poeple forget!!
If you set up your own access code, you can recover the code by connecting to computer or using a file manager. You can download Fileman here.
After installing file manager
check the folder C:\System\mmcstore . Rename file mmcstore.txt and send it to another mobile or to your PC via bluetooth or USB, open it and there you will find the password.
Here is also a reset procedure that works on some Nokia, I do not know if it is good for 6300.
Beware, by using reset below you will delete all data stored in phone memory, even phone numbers if they are stored in phone memory:
Take the SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on.
Keep this two buttons pressed until the reset screen appears.
Wait some time to reset.
Switch phone back on.
rating dont forget give me the blue rate!!
Aug 25, 2008 | Nokia 6300 Cellular Phone
Nokia 6300 Cellular Phone Logo
109 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
