Question about Car Audio & Video
I need an install manual for the mtx rt xo1a crossover please or diagrams or something im mostly confussed with the low pass inputs . never seen that application before
2 Suggested Answers
  • 111 Answers
SOURCE: tryin to hook up a
Your basic crossover is going to have a power (+) and ground (-). Your power wire goes to the battery, and your ground goes to the frame. You will need to hook up your RCA or speaker wires to the input side. Then hook the other two RCA connections to your amp.
Posted on Apr 14, 2011
Their are 2 power wires,2 negative wires and 2 rem wires...how is this wired..im getting ready to get this put i
Some amps come with extra, power,rem,ground, so you can , power up another Amp Without runing to many wires. , or using a power block.like a parallel, being your 1st Amp your power block, and your remote, ground .
Apr 03, 2016 | Jensen JXA8BA2 Amplified Subwoofer, Max...
Can i hook up my MTX electronic crossover rt x01a to myvhome reciever
yes you can. you need a 12v power supply for you home. Purchase a 12v 5a supply and set it up like you would in a car.
Nov 10, 2013 | Car Audio & Video
Tryin to hook up a mtx electronic crossover rt-01a. i dont know how to hook it up
Apr 13, 2011 | MTX Car Audio & Video
Eq to receiver
Connect through the tape monitor jacks and if a tape deck is used connect it to the eq! Check your owners manual if you still have it or download one.
Apr 14, 2010 | Yamaha EQ-70 Home Equalizer
Is it bridgeable
yes you can bridge this amp to one channel
here are the specs for the amp
  • stereo or bridged mono output
  • Tri-way capable (Tri-Way crossover required)
  • 100 watts x 2 at 2 ohms
  • 200 watts x 1 in bridged mode
  • requires 10-gauge power and ground leads — wiring and hardware not included with amplifier
  • PWM MOSFET switching power supply
  • Intelligent Surface Mount Technology for cleaner sound and greater reliability
  • selectable 85 Hz high-pass/low-pass crossovers, 18 dB/octave
  • preamp outputs
  • speaker-level inputs with SmartEngage (turns the amp on when it detects signal from the receiver, eliminating the need for a separate turn-on lead from your receiver)
  • 9-3/4"W x 2-1/8"H x 9-3/4"D
  • Feb 06, 2010 | MTX Thunder 4202 Car Audio Amplifier
    I want to change the crossover unit in my mtx pro 2400's
    I would reccomend that you change out the drivers themselves that have a deepened low-end frequency resposnse. But, changing the crossover just might tweak the sound to your tastes better, and cheaper. Here is a link to a website that I often order from whenever I need something Audio/Video related. They have a reliable support staff, and usually products arrive a day or so sooner even with basic shipping. Prices are good too. Good luck,
    Hortona
    http://www.parts-express.com/
    Mar 25, 2009 | MTX 12" 2-Way Professional Loudspeaker...
    Dont know how to set my crossover! mtx rt-x03a
    This unit had a couple unique features: a center channel (summed) output and a differential output (right channel is subtracted from the left). Once you figured out you lows, mids, and highs. Center and rear. I recommend buying a cd to test out your sounds like your high, mids, and lows
    Mar 06, 2009 | Car Audio & Video
    Low pass crossover
    Low-pass crossover
    Both sets of inputs sum the left and right channels together and the
    resulting signal is passed through an adjustable low-pass crossover before
    being amplified. The crossover control allows you to adjust the upper limit
    of the subwoofer's frequency response from 40 to 120 Hz. The subwoofer's
    response will begin rolling off above the frequency you set this control to.
    You should set the crossover frequency to obtain a smooth and seamless
    transition from the subwoofer to the main speakers in your system. If your
    main speakers are smaller units with limited low frequency output, you
    may wish to choose a higher frequency (such as 100-120Hz) than you
    would with larger speakers which have greater low frequency output. With
    larger speakers, you might start with this control set lower, such as 80Hz.
    Jan 05, 2009 | Velodyne CHT-10 Subwoofer
    Do you have instructions for wiring install on volfenhag GX8200??
    Amplifier Class AB
    Number of Channels 2
    RMS Power (4 ohms) 120 watts x 2 channels
    RMS Power (2 ohms) 200 watts x 2 channels
    RMS Power (1 ohm) Not Stable
    Bridged RMS Power 400 watts x 1 channel
    Total RMS Power Output 400 watts
    Peak Power Output 1000 watts watts x 1 channel
    Minimum Impedance Unbridged 2 ohms
    Minimum Impedance Bridged 4 ohms
    THD at Rated RMS Power 0.1%
    Speaker Level Inputs No
    Preamp Outputs 1 pair
    Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
    High-Pass Crossover Frequency 40 - 250 Hz
    Low-Pass Crossover Frequency 40 - 250 Hz
    Subsonic Filter N/A
    Signal-to-Noise Ratio N/A
    Channel Separation N/A
    Bass Boost 0 - 18 dB
    Bass/Gain Remote Yes
    Fan Cooled Yes
    Fuse Rating 20A x 2
    Dec 24, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
    Car Audio & Video Logo
    248 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
