Question about Vacuums
We have an American Home AH2O-550F water dispenser. The hot water valve is leaking water. Is the repair covered under warenty? Where do I bring for repair or how should I fix.
How do I replace the hoses on a Hoover Spin Scrub?
I'm guessing you have an F7000 series machine. You have a bad solenoid. When they go bad they don't close so all the water poors out. Take it to your local vac repair shop for the repair.
Sep 11, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Water not dispensing
Check the release valve on bottom of clean water reservoir unscrew if needed, once again if your not sure run hot water in the solution tank through the system to help remove old soap residue and always run hot water through to prevent future problems after cleaning carpet and storing.steve
Jun 06, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell ProHeat Rug and Floor cleaner. Won't
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
sf
Oct 20, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Water won't come out
Hi there SmartAlec from nelsonvacuums.com.au here. I think that the likely solution for the problem is that the water tank is slightly warped and so will not seal properly. Normally this is caused by using hot water in the tank. It should still be covered under warranty though just take it back to the dealer and get them to check it.
Aug 14, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
PROheat 2X won't dispense water
Make sure that the gasket is on the valve at the bottom of the tank. It has to be on the tank. That valve may be bad, or maybe the tank isn't sitting square on the base. But if less then 1 year old, then it is under warranty, take it in for warranty repair. You taking it apart voids the warranty.
May 31, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Will not dispense water or solution
On the bottom of the tank is a valve, push it in and see if water comes out Where the tank sits, there is a black round seal, is it in the proper place? The rod in the handle hits just under that seal, with the tank off, you can see if the rod is movin up and down when you depress the trigger. The resevior asm. may be bad, that is what the tank sits on.
Mar 10, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Detergent won't dispense
Check the valve at the bottom of the tank, does it push up then come back by itself (part #43513014)? If it is ok, then there may be a problem with the plate that the tank sits on or the plunger inside the handle isn't pushing to release the detergent.
Feb 08, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Tank Dispensing
Is the detergent tank cracked at the bottom, under the black seal? If so the whole tank asm. needs to be replaced. But if this is new, then it has a one years warranty on it and you can take in for warranty repair.
Oct 13, 2007 | Hoover F7222-900 SteamVac Upright Vacuum
Will not dispense soap from handle
The soap dispenser, on the side, make sure the seal is on the bottom of it and not in the hole. You may have to replace the valve asm for the dispenser part # 2101795
Sep 30, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Not dispensing water and no suction
I'm assuming the belts are OK.... Your heater is clogged. Unplug the machine and let it sit for 30 minutes. Take the handle apart, there will be a 4 inch by 8 inch metal box inside. This is the heater. Remember I said to let the machine sit for 30 minutes? If you didn't, the heater may be EXTREMELY hot!! Disconnect the two hoses going into it, and clean the metal pieces out (that the hoses connected to) with a needle or very small drill bit. You may want to remove the 6 or 8 screws holeding the heater together and remove the cover to clean it out. Reassemble and fill both tanks with VERY hot water ONLY and run the machine to rinse the entire system.
To prevent future reoccurences... use only Bissell extraction shampoos. Never put anything in the detergent tank except shampoo. (And only water in the water tank) Mixing chemicals with anything else turns the water/detergent mix to sludge. Also, when finished shampooing, put ONLY water in both tanks, and run the machine until one of the tanks run out of solution. Doing this rinses the hose lines out and prevents hardening of the solution in the heater ports.
I've fixed these machine for years. No dispensing is almost always the heater clogged.
Sep 29, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Vacuums Logo
23 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
