Question about Toshiba Computers & Internet
My Toshiba hard desk stopped working, when I connect it it does show the light that its connected but I cant open it or view data
  • Toshiba Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Apr 07, 2011
Please advice! I accidentally plug my Buffalo external drive of 100V to a 220V! Does this have an internal fuse? Kindly advice, my data stored are important. Thank you.
MY BUFFALO HARD DRIVE model hd-HC320U2-us WILL NOT LOAD WHEN CONNECTED TO MY LAP OR DESK TOP WILL I BE ABLE TO GET MY INFORMATION OFF THE HARD DRIVE, IS THE INFO GONE! WHAT COULD BE THE PROBLEM POWER LIGHT COMES ON BUT THE ACCESS LIGHT DOES NOT BLINK............ TO SHOW CONNECTION HAPPENING
Nov 30, 2010 | Buffalo Technology DriveStation ...
My Toshiba HDD2171 has stopped working. I have connected it to my Desktop PC with a IDE connector. It fails to be recognised. What can I try to retrive my data.
If you tried to setup the hard drive as a slave drive and it didn't work then you might try this, but I think it you will have much success.
Connect the hard drive to an USB hard drive adapter and then plug this into the USB port of a working computer. If this computer detects it as an external storage device and you can open the folders and files then you are in luck.
If not then there are companies that can recover data from faulty hard drives, BUT it will cost you an arm and a leg for their services.
Sep 27, 2010 | Toshiba (HDD2171) 40 GB Hard Drive
Hey.. I have a toshiba 160GB portable hard drive and its got very important data for my work.. a while back it used to just stop working when i view some old files and then all of a sudden it just...
give the hard drive a firm tap on side it sounds like a dirty hard drive the clicking sound is the reader arm scating across the platters once you get access to your hard drive then click start run type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive
good luck with this
Sep 03, 2010 | Toshiba 160GB EXT-USB 2.0 PRTBL SHOCK...
Hi, i have the noted type hard drive and i have just moved house. since then my hard drive wont connect to my pc. the light comes on and every thing looks ok but she wont connect. my other hard drive works...
does it just beep and is not reconized by your P.C.? if so continue to read,
If you get no joy using the Troubleshooting Guide then try this...
don't worry if you are a novice like me, the thread is very easy to follow.
Look inside your P.C. 1st to check SATA data connection type.
eSATA is a different connection from SATA so you might need an eSATA data lead if you follow the guide in the link, not sure if it just external connections only and plain SATA connection inside.
Google image 'eSATA' data lead/cable and you will see the difference between the eSATA and SATA connection if you don't already know.
My neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not reconized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t​=84 Thread can be found in 'Technical' under 'General Technical Issues'
Aug 18, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How do i fix an external hard drive (seagate freeagent) that makes a beeping sound and is not recognized by my system ?
My neighbour has the Seagate FreeAgent Desk 500GB (Externel HardDrive), and in under 2 weeks it started to beep and was not reconized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t​=84 Thread can be found in 'Technical' under 'General Technical Issues' Dont worry if your a novice like me with computers, the guide is quite easy to follow...
Aug 08, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have toshiba satellite L500D. I cant download any movies or tv shows and when i watch tv from yahoo 7 it stops and starts as does Youtube....PLEASE HELP!!
When downloading videos from sites such as You Tube, the download is known as "streaming video". It fills the buffers on your machine and then displays it on your screen. If your connection is not fast enough, the buffers will empty before the data stream can re-fill them. This produces the stop start situation. The best way to overcome this is to do something else while the video plays, then come back when it's finished and replay it...it will now play ok.
If your connection is slow, then it's likey its timing out during the download of movies or TV shows, stopping the data flow.
Mar 19, 2010 | Toshiba Computers & Internet
My seagate hard drive wont power on,it sounds like it trys to spin then stops then trys again,my computer wont read that its connected
Do you have an different power supply to try with the hard drive? I had the exact same problem with a WD MyBook and the power supply was weak. I had the drive for a little over a year when this happened. Thank goodness for multiple year warranties on the MyBook!
Mar 11, 2010 | Seagate FreeAgent Pro 1TB External USB...
External hard drive doesn't respond
Shut your computer down. Disconnect you external hardrive. Power up your computer again. Power up the Verbatim and then connect to a USB port. You should hear a very quiet 'ping'.
Go to My Computer, and the Verbatim should be showing as one of your drives (probably Drive D). You should be able to open it from there.
Make sure that you have a Desk Top Icon for opening the hardrive, it makes it so much easier. Hope this helps
Jan 25, 2009 | Verbatim 500GB USB Desktop 500 GB Hard...
WD Passport Drive Lights Up But Compu Does Not Find the Drive
Does your drive make any unusual sounds like any of these: http://datacent.com/hard_drive_sounds.php ?
If yes then you got a problem - it's something mechanical with the heads.
If it sounds normal or doesn't spin up at all - try to connect it to another computer and if still no go - remove the internal drive from enclosure and connect directly to PC via SATA port.
Sep 29, 2008 | Western Digital Caviar SE WD1600AAJS 160...
Computers & Internet Logo
63 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
