Question about Lowrance LGC-12S GPS Receiver GPS Receiver
I have a Lowrance LGC-12S which is used to provide time and date to an Airtraffic Control voice recorder system. The time and other data in the NMEA $GPRMC sentence used is correct but the date is showing 2030/11/19. The date does increment daily and all other NMEA data sentences seem to be correct. Any ideas as to what is causing this problem and how it can be fixed? Thanks, Chris
2 Suggested Answers
  • 30 Answers
SOURCE: lcx-15ct (gps module not responding)
Before you give up on the LGC-12S you have now though, try plugging the LGC-12S right into the LCX-15CT without an extension cable. If the module not responding goes away...you just need a new extension (GPSX-25G p/n 99-46).
The power cable has a set of yellow, blue, orange, and bare data wires. If these wires short together, you can get the module not responding error.
If all that doesn't help...the LGC-12S is bad.
The LGC-12W p/n 112-06 will work with the LCX-15CT. You probably get this at many marine electronics dealers or go to lei-extras.com and buy it straight from Lowrance. They cost $229 so you might want to shop around putting that money into a whole new system altogether.
Make sure you have the latest software updates if you get the newer LGC-12W. These can be downloaded at http://www.lowrance.com/en/Downloads/Product-Software-Updates/
Let me know if you need more help.
Posted on Jul 11, 2009
What are the data cable 5 wire used for and where do they get hooked up
The additional wires are for NMEA data transfer to and from other devices and sensors like distance, speed, depth, temperature and NMEA 0183 sentences the unit will use when connected to a VHF radio or other NMEA 0183 device.
The manual link below.
http://www.lowrance.com/Root/Lowrance-Documents/US/ELITE-5_HDI_OM_EN_988-10518-001_w.pdf
Jun 11, 2014 | Lowrance Boating
My Lowrance unit gives me a message of
Hi check the receiver has 12 volts at the blue plug, if so the mushroom is most likely fried, regards Phil.
Jun 10, 2012 | Lowrance LGC-12S GPS Receiver GPS Receiver
Does it have achart plotter
Out of the box, no. To get GPS/Mapping/chartplotting features, you have to hook up a separate LGC-12S 12-parallel channel GPS receiver/antenna device which is sold separately.
Mar 11, 2011 | Lowrance LCX-15MT GPS Receiver
I have a lcx16 sounder gps with a lgc12s antenna receiver. The gps module is not responding Do I need a new antenna ?
more than likely you do or you have a bad connection. It's always best to take this sort of issue to a shop in the event something is wrong with the unit itself before buying the new gps.
Jan 19, 2010 | Lowrance LGC-12S GPS Receiver GPS Receiver
The GPS claims that the transponder is not communicating. All cabling looks fine and there is no apparent damage to the head.
Normally this error shows that something is wrong with the antenna itself. If the unit is old it's best to change it out. most gps antennas are only good for about 5-10 years. unless you have had a lightning strike close by then less. The other thing is to make sure that you don't have the internal gps selected in the menu and that you have both terminators on the nmea 2000 network that the LGC-2000 is connected to.
Oct 29, 2009 | Lowrance LGC-2000 GPS Unit GPS Receiver
Every time i turn on my lowrance 520c it says gps module not resp
I had the same problem. Sent my entire unit back to Lowrance, but they said it was fine. One year later, I find out that I did not receive or have the correct parts to hook up the GPS unit. I needed the NMEA 2000 T connector and terminator plugs. Look at your manual and hook it up the way the manual says. It will require a NMEA 2000 T and at least one 60 ohm terminator plug. Seems the GPS module sends back some kind of signal that if not absorbed by this thing will mess up your unit. Mine works since I got it hooked up correctly. HD
Jul 17, 2009 | Lowrance LGC-3000 GPS ANTENNA FOR UNITS...
Lcx-15ct (gps module not responding)
Jul 10, 2009 | Lowrance LGC-12S GPS Receiver GPS Receiver
I have a lowrance LMS 332C GPS. After 5 years I
The LGC-2000 is bad would be the most likely cause, but if this started right after you changed the cables, Try connecting the NMEA 2000 network to a different power source than the main power. If you still have the original cables, and you didn't have the problem before, try using those again to make sure there isn't anything wrong with any of the new cables.
But most likely, the LGC-2000 is toast and you will want to contact Lowrance support to see about getting it repaired/replaced.
Jul 04, 2009 | Lowrance LMS-332C GPS Receiver
I have a lowrance 3600c igps linked to a navman vhf 7100 but for some reason it has stoped giving information on my position to the radio. I have cheked all the wires are ok it was fine last week when i...
If your GPS was sending NMEA data and now is not, your NMEA configuration may have been inadvertently changed, either due to a user error, or possibly a software glitch.
You can configure the unit to use specific NMEA sentences.
1. Press MENU|MENU| then scroll down to SYSTEM SETUP and press |ENT.
2. Scroll down to COMMUNICATIONS PORT, then press ENT then scroll down to CONFIGURE NMEA and press ENT.
3. A menu appears showing the prefixes of the available NMEA sentences.
A check mark next to a prefix means the prefix is in use. Use the arrow keys (on the track pad) like a mouse to select a prefix, then press ENT to turn off the prefix. (Press
ENT again to check the box and turn a prefix on.)
I'm not exactly sure how the data is labeled on that model but you looking for a sentence that looks like an abbreviation for GPS Lat Lon (it may be something like GPLL). If you're not sure, turn them all on, the VHF will only use the sentences it recognizes.
4. When the desired prefixes are checked or unchecked, press
EXIT|EXIT|EXIT|EXIT to return to the previous page.
let me know if this worked for you, or if I may be of further assistance.
Aug 18, 2008 | Lowrance GPS
I just bought a lgc 2000 antenna for my lcx 20 lowrance. i haven't any manual but the seller said all i had to do was plug it in. well, all i get is" gps module not responding".is there something...
hi the lgc has to be powered also with the nmea cable,red to+,black and shield to-,you also need a 60ohm terminator atached to the short length coming from the y piece,the manual does not state this very clear and lowrance is not much help
Apr 28, 2008 | Lowrance GPS
GPS Logo
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
