Question about Garden
Have a victa lawnmower 4 stroke engine when i started it recently it spits out oil and overheats pretty quickly its only 6 months old. checked oil it was full but i tried to turn it on again the same thing happened oil is spitting out and the machine is overheating and smoking.
  • 2,510 Answers
Check that the oil level is not too high, further than that do not do anything. As far as I can remember, Victas have a one year guarantee. Rather than try to repair it or look into it, call the dealer or take it back to him as you will invalidate your warranty if you do anything to the unit, and that is not worth it. Let the dealer worry about it.
Posted on Apr 07, 2011
I have recently been given a Victa Catch and Release Lawnmower,but no manual. How much oil do I put in before commencing use. And How do I drain dirty oil?
Victa catch and mulsh ?
search pops these up as 4 strokes
which model and a internet search gets you its user manual
start with 600 ml oil and top up as required
try not to over fill
look for drain plug up under blades or on the side of motor
Nov 06, 2016 | Garden
What is the victa lawn mower 35 classic a two stroke or a four stroke please.
search on a victa 35 classic makes it 4 stroke
its a brigs and stratton 3.5 engine on aluminum frame + plastic rear catcher
Sep 03, 2016 | Garden
Lawnmower manual FOR A VICTA TWO STROKE
With a Victa lawnmower you must be an Aussie!! Try Retrevo Manuals.com A bita dicken around but shift hot for all sorts of directions
Jan 04, 2014 | Sewing Machines
Do i put 2 stroke or 4 stroke in a 148cc engine
does the engine take oil? if it does then it is a 4 stroke and does not require mixed gas. if it doesn't have its own oil then it is a 2 stroke and requires mixed
Sep 25, 2013 | Briggs & Stratton Briggs Stratton...
Stupid question I know but is it 4 strock or 2 strock oil for a victa 450 148cc
If there is a place for motor oil on the engine, its a 4 stroke, and use 10w-30. If not, use a 40:1 mixture (gas to 2-stroke oil ratio). Not a stupid question... only stupid if you didn't ask, and did the wrong thing without asking first! Hope this helps!
Oct 20, 2011 | Briggs & Stratton Garden
I have a Poulan 625 push mower. What type of oil should I use in it? I can't find my manual.
If it has a 4 stroke engine, as most lawnmowers do, then you just car engine oil. Very occasionally you come across 2 stroke mowers.
The way to know if it's a 4 stroke or 2 stroke engine is, if it has an oil tank it's a 4 stroke engine. If there's only the one tank, i.e. you mix the oil with the petrol then it's a 2 stroke engine.
If it's a 2 stroke engine you mix petrol and 2 stroke oil at a ratio of 40:1
Jul 12, 2011 | Poulan Garden
How to fix a 3.5 lawn mower?
HELLO,
You can fix these yourself, all you have to do is to follow the instructions below,
1 Remove the spark plug lead from the spark plug and move away from cylinder head. Always do this before attempting any repairs to a lawnmower.
2 If your lawnmower is a "four stroke" mower (separate gasoline and oil), tip the mower so that the spark plug is pointing skyward. Never tip it on its side with the spark plug to the ground.
3 If your lawnmower is "2 stroke" (oil and gasoline mixed) turn off fuel tap. You can tip a two stroke mower any way that is suitable to you.
4 To change a blade, or blade disc, it is often easier to remove the spark plug and feed a length of string into the cylinder head to 'lock' the piston while trying to un-do the blade bolt(s).
5 Check the motor's "air filter" while doing this sort of maintenance as a dirty or clogged air filter will affect engine performance and increase fuel consumption of your mower. Symptoms of a clogged air filter include inability to start, starting and quickly stopping after several sputters, or a weak idle. You may also see oily or smoky exhaust.
6 If your mower is a "four stroke" model, change the oil at least once a year. When it is tipped over with the spark plug in the air, is a good time to remove the "oil fill" plug and drain oil into an old ice-cream container for recycling.
I hope this will help to solve the problem.....
May 31, 2011 | Craftsman Garden
Is a Victa Sunbeam 160 Special a 2 stroke or 4 stroke? Wondering what additive to use with fuel. Thanks so much for your help.
hi there tanyajames88
your victa is a 2 stroke vc160 these units sare stated to run 25:1 fuel / oil ratio
that is 40 mils of 2 stroke for every 1.0 litre of petrol that mix
so if mixing 2 litres - 1st put in 80 mils of good quality 2 stroke oil then put in 2 litres of petrol , give good shake and fill up your mower tank
2 stroke oil that you would use for sthil chainsaw would be ok its hi quality
you could use some fuel stabilizer additive to hekp stop mix from going stale too soon
if wish but most times just mix enoyugh mix to het job done , then mix more if need it
that way mix is always fresh
vheers pauly46
May 29, 2011 | Garden
My 4 stroke victa will not start. I have removed the spark plug and checked for a spark, there is no spark. What should I be looking at now?
Check on any safety interlocks.
Is there oil in the engine? Some engines have low oil interlocks.
Are there any other safeties?
Is there a key or on/off button?
Stick a phillips screwdriver in the spark plug connector, hold the screwdriver close to the engine, spin the engine, is there spark at the gap?
If so, try a new plug.
Dec 22, 2010 | Garden
How do i tell a victa 2 stroke from a 4 stroke?
two stroke mowers will have a picture of a oil can on the fuel cap,if it doesn't it is most likely a four stroke.
four stroke mowers will have a fuel cap and a oil cap as well.
Dec 12, 2010 | Honda Garden
Garden Logo
232 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
