Question about Canon PIXMA MP160 All-In-One InkJet Printer
I keep getting this message from my computer when I turn on my Canon MP160 printer: Windows has stopped this device because it has reported problems. (Code 43). It was working perfectly a few days ago then it suddenly wasn't being recognized. I tried switching the usb port it was plugged into, unplugged the usb cable in the computer and printer, uninstalled the USB host controllers, and tried installing the print driver from the Canon website. None of this has changed the result. Windows tells me that if the driver doesn't work when reinstalled then to replace the device because it has malfunctioned. There has to be a better way then having to dump my printer. Please help me fix it.
  • Canon Master
  • 11,800 Answers
Code 43 is the death code - the unit that is generating it has stopped responding to the commands from the pc, it's dead and nothing will bring it back to life.
Nothing left to do but buying a new printer.
Posted on Apr 07, 2011
Testimonial: "i was hoping that wasn't the case. ugh. thanks though; at least i'm not wasting time trying to fix it anymore."
2 Suggested Answers
guide2u
  • 461 Answers
SOURCE: Problem detected with unknown device
try to reinstall the printer driver, if you don't have the driver you can get it from here
Posted on Oct 23, 2010
Mp160 driver is installed, yet it is not recognized by the computer. how do i fix this?
Which version of windows are you running? Make sure the device is showing up in the device manager. Also make wure the printer is plugged in and turned on.
Sep 14, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon pixma mp160 printing problem
Here is the straight scoop for fixing your problem from the Canon website:
Issue: Unable to print from the computer when an error message is displayed
1. Configure printer driver to correct port 2. Disconnect and reconnect the USB cable to ensure a secure connection 3. Disconnect other device and reboot computer 4. Remove [Other device] from Device Manager
Hope this helps.
halthefotoguy
Jan 18, 2009 | Canon PIXMA MP160 All-In-One InkJet...
E 2 and service error 5100 on Pixma mp160 printer
You can try to clean out the printer check to see if there is any paper jammed in it somewhere
Then realighn the printer cartridges and run a test page.
Make sure that the paper tray is not overloaded
Dec 24, 2008 | Canon PIXMA MP160 All-In-One Printer
Error message on Canon MP160 flashing E-2-2 error message 5100
The error code refers to Ink Cartridge
Issue: ERROR: Error code 5100 appears on the computer screen
Issue: ERROR LED: E, 2, 2
1. Disconnect and reconnect power cord to reset the device
2. Remove Packing Material MP160 / MP180 / MP460
3. Reseat ink cartridge (MP160 / MP180 / MP460)
Nov 15, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Problem installing printer on Windows 2000
ok..remove the old printer, then go here for up to date drivers(do NOT use the cd)
Mar 12, 2008 | Canon PIXMA MP160 All-In-One Printer
I can't get the scanner to work on my mp160. The printer and copier work fine.
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-13
Feb 25, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon mp160 printer E5 flashing error?
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button 4 times.
The above will get you to Service Mode (and clear the Waste Ink Counter if you wish) and is supposed to work for MP160 also.
Caution if your waste ink pad is full you could overflow if ignored.
Some of the new carts reportedly have fuses which blow if the ink gets too low, denying any further refilling.
To use refills, you will probably have to turn off your Status Monitor.
Go to your printer's Maintenance section.
Feb 23, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Scanner connection to the PC
i solved mine by replacing the usb cable with one that is 2.00 high speed and inti noise shelded benton-r
Nov 04, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
395 people viewed this question
old marine
old marine
