Question about Belling Microwave Ovens
Belling microwave M385 TCS. When I tried to operate the microwave shook for 5 seconds making a terrible noise and all power cut out. It has been doing this intermittantly for two months but when switched off at the wall and then left for a while when it was reconnected it worked again for a while.
  • rupert_sykes Apr 09, 2011
    Can it be fixed and is it worth fixing?
    Brigadier General:
  • 8,909 Answers
That could be caused by condensation, causing insulation failure on the high voltage winding of the magnetron power supply.
Posted on Apr 07, 2011
My belling BEL F-SE60DOMW microwave will not turn off
You might have a power relay with contacts stuck in the closed position. I'd also check the door switches to make sure both the primary and secondary are not stuck closed. It's an unlikely cause, but I'd check them anyway.
Dec 23, 2016 | Belling Microwave Ovens
How do I replace bulb in belling m385 tcs
any I have looked at the entire shell has to be removed
Feb 24, 2015 | Belling Microwave Ovens
Where can I get hold of a Belling BEL GT17SS microwave foot?
Temporarily, you can use a wine-bottle cork, cut to size. Mind your fingers!
Feb 13, 2015 | Belling Microwave Ovens
We have a GE profile microwave with inverter tech that will come on for about 5 seconds then shut off. Unplug it and plug it back in it does the same thing. It lets off a terrible smell almost like a...
Remove vent grille, then remove control panel. Check wire to cavity thermostat. Sometime wire bundle and small space causes poor terminal connections on this thermostat and will burn wire terminal. Cut off bad part of the wire, install a small terminal end, reconnect to thermostat. If thermostat is destroyed, also replace thermostat.
Aug 13, 2014 | GE Profile Spacemaker 1.8 Cu. Ft....
My microwave won't heat anything up. The light comes on, the plate turns round and it makes all the right noises but it doesn't heat anything up.
Since the light and fan work the main board or the processor is working .Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
As there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced.
See link: http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Thank You for using FIXYA.
Sep 17, 2011 | Belling Microwave Ovens
Belling BEL-CJ/SS25 microwave
My Belling BEL-CJ/SS25 Microwave / oven / grill has recently developed a problem. Every time I close the door the turntable starts rotating, even when I'm not using it. It doesn't make a noise, and doesn't seem to be going into any cooking setting, and the light doesn't come on, but it turns until I open the door, when the light comes on and the turntable stops turning. This has only recently started happening, and nothing else seems to be wrong with it, Is this safe or should I get rid of it and buy a new one. The guarantee has expired so repair may be cost prohibitive.
Sep 04, 2009 | Microwave Ovens
GE JVM1650 Microwave Making Loud Noise
hello Frank. Sorry to tell you that the magnetron is going bad and making that terrible noise. Since the inside of a microwave, even unplugged has up to 2000 residual and deadly volts of electricity I recommend either calling a pro or replacing the unit.
Jul 12, 2009 | Microwave Ovens
Microwave works, new noise
It could be a bad magnetron, or it may be mild arcing due to food particles or grease on or behind the waveguide cover.
No microwave should ever be left unattended while running.
Jun 24, 2008 | Microwave Ovens
Louder than normal noise when using and bad 'burning' smell
You need to stop using your microwave if it's burning. This is a common symptom of a blown magnetron. Using it in it's current condition is not only dangerous, but it will further damage other components in the high voltage circuit and/or waveguide. In many circumstances, damaging the waveguide renders a microwave non-repairable. A new magnetron will cost you around $100 if you wish to repair this yourself. NOTE: I would not recommend working in or around the high voltage circuitry unless you absolutely know what you are doing. Do not attempt to take any live voltage measurements or operate the oven with any of the protective covers removed or interlocks defeated. Voltage potentials of over 13,000 volts exist and are potentially dangerous. I hope this helps you.
Feb 20, 2008 | GE JVM1660 Microwave Oven
Cut out during heating
Possible causes include a blown fuse or high voltage diode. A bad magnetron or power transformer are also possible. I recommend taking the oven to a repair facility, or scrapping it & getting a new one. Do not attempt to repair this yourself, as microwave ovens have voltages present inside which are INSTANTLY LETHAL, & there are no user servicable parts inside.
Jul 16, 2007 | Belling BIM60 Microwave Oven
Microwave Ovens Logo
236 people viewed this question
Top Belling Microwave Ovens Experts
William Miller
William Miller
Tim Rickards
Tim Rickards
Are you a Belling Microwave Oven Expert? Answer questions, earn points and help others
