Question about OCE Office Equipment & Supplies
DOCUMENT COMES OUT BLACK
NEED TO KNOW IF LAMP IS GONE OUT ON MY NEW IM5530 OCE COPY MACHINE
    Renaissance:
    An user who is expert in 3 categories / brands.
  • OCE Master
  • 1,362 Answers
If solid black page comes out then 95% it's the scan lamp
Posted on Aug 07, 2008
I have an Oce 7051 printer which I have had from new but which has not been used for about 5 or 6 years. When I tried to use it there are no lines at all on the copy sheet. I put a new genuine toner
If you have left the ink cartridges in the printer unused for 6 years then the ink has dried in the printer heads and these need to be cleaned or replaced,
Aug 29, 2014 | Office Equipment & Supplies
When copying a document the copy comes out all black, what is the poblem??
do you have the users manual??? if not get one at this address
http://www.muratec.com/new/support/manuals-for_muratec0o34534021023994938849.asp then try printing out a list or report of some kind...see if its still all black. If pages printed from memory are ok does the lamp undert the glass come on when you make a copy.???
Sep 14, 2010 | Muratec - MFX-1300 Copier
Xerox 3050 service manual
sir,
i want get solution for my 3050 xerox machine. while taking the copy the background coming black, idon't know the reason, i changed explosure lamp, primary corona end block, tonner, but till the problem is background black, if one copy comes clear another copy will be black. if know the solution kindly pass the message to my cell no.7760191629.
thankyou,
regards,
prabhu
Sep 11, 2010 | Xerox Office Equipment & Supplies
My mfc240c says to replace the yellow ink cartridge but I don't want to spend money on that if the 'light bulb' is ruined. When I turn on the machine, I don't see any light for scanning or copying. ...
By the "light bulb," do you mean the scanner lamp? That lamp should only turn on when you are actually scanning, faxing, or copying a document. You should be able to still use the machine to scan and fax, even with the yellow ink empty. Try scanning a document to see if the scanner lamp comes on.
As far as printing or copying goes, you won't be able to print or copy anything until you replace the yellow ink, even if you try printing in black and white only.
Apr 19, 2010 | Brother Multi-Function Center MFC-240C...
Hello, I work with Osceola County, FL Habitat
Sir the AFR-12 is the document feeder desiignation, the machine model number is located on the back of the machine or the right hand side of the machine (You saw the AFR-12 when you raised the document feeder correct?) As for copies being black the drum/cleaning blade mite need replacing. Remove the orginal glass the big sheet of glass and clean the optics use no liquids just a clean paper towel, there are about four minors two the right side plus clean the expose lamp (Bright lite that lites up) to copy the orginal be gentill. remove the black cover on the right hand side two mirrors under there The model mite be a EP2010, 2030, 2080, and or 3000?
Aug 22, 2009 | Office Equipment & Supplies
Out going fax is coming black
FIRST test copying. if the copy come out completely black, then the exposure or scanner lamp or contact image sensor is dead,not lighting on. Now if the copy has black only black lines on it,then you can clean the place where the document passes thru where the light of the exposure lamp projects unto the text of the document being scan,which is the small glass on the left side of the platen glass when you open the auto document feeder.NOTE: Lay your document on top of the platen glass & make copy if the copy come out clean as you needed it,then the lamp is O.K. Then the small glass just need to be clean. If the copy is completely "BLACK", then the lamp is dead, or the circuit that control it. In thus case then you need a technician to do it
Jul 14, 2009 | Panasonic KX-MB781 All-In-One Laser...
Oce 3121 coping machine make random black line shadows
if you are getting copy quality issues on all aspects of the machine, IE, printing, copying, ADF, it looks like then you might need a new drum installed. please contact your local service department for service and make sure if you need supplies, to have those on hand before calling a tech to come service the machine. drums, developers, and toner are considered a supply item and are NOT carried by technicians unless otherwise stated in your local contract.
Jun 23, 2009 | OCE Office Equipment & Supplies
Canon B640 printing problem
The scanner lamp is not working. When making a copy, the lamp lights the source document, so if there is no light, the source document 'looks' black. Your machine will need to be serviced.
Jan 26, 2009 | Canon FAXPHONE B640 Plain Paper Bubblejet
Oce 3165 Copier makes black copy over text.
that is a very expensive and big machine. as an oce representative i suggest you call it in for service.
Oct 27, 2008 | OCE 3140 Copier
What is causing black streak
You should try changing the toner cartridges first. There may be something stuck in it causing the noise and streaking
Apr 14, 2008 | Canon imageCLASS D661 Digital Printer
98 people viewed this question
Top OCE Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
fares
Level 1 Expert
Are you an OCE Office Equipment and Supply Expert? Answer questions, earn points and help others
