Question about Sony Cyber-shot DSC-W180 Digital Camera
My cam overheats after 10 secs. - Sony Cyber-shot DSC-W180 Digital Camera
  • 455 Answers
Please make sure that the battery which you're using in the Camera is compatible. The compatible battery pack and the supplied one is NPBK1. If you're using the supplied battery, then make sure that the terminals of the battery are clean. You can use a soft dry cloth to clean the terminals of the battery.
A normal heat will generate in the Camera while operating which is a normal operation. If the heat is high, then I suggest you to get in touch with a Sony Authorized Service center to resolve the issue.
Thanks for using FixYa!
Posted on Apr 07, 2011
My 2006 lio tv makes a whirring noise and won't turn on
The cooling fan is dirty or defective. Components will overheat and the TV won't turn on. Fix it and then hold down the power switch for 10 secs. while it unplugged. Clean the inside of the TV with a small vacuum. Use a very soft brush to loosen dirt the vacuum won't pick up.
Feb 15, 2015 | Televison & Video
SYSTEM POWER GETTING ON AND GET OFF BETWEEN 5-10 SEC
Generally, this is caused by one of three things:
  1. cpu overheat (check the CPU and see if the fan is properly mounted to it.). If the system detects a masive overheat, it will shut down in order to prevent damage to electronic components (and in some case, fire).
  2. bad CPU or motherboard short/overheat
  3. the Power Supply is bad.
Generally, in most of my cases with customers in real life- it's one of the three. Unfortunately, unless you have the skillset and some spare parts laying around to troubleshoot this sort of thing- I would suggest possibly bringing it in to a computer repair store for diagnosis.
Mar 24, 2012 | MSI 945GCM5 Motherboard
My viewsonic projector shows overheat after it's start. then go to sleep after 10 sec.
Are the air filters clean? It may have a faulty temperature sensor or indeed the temperature sensor may be disconnected.
Feb 12, 2011 | ViewSonic Office Equipment & Supplies
PUT A NEW CAM SENSOR IN IT ENGINE CODE CALLED FOR IT AND STILL DOES THE EXACT PROBLEM RUNS FOR A ABOUT 10 SEC AND STALLS 20001 MIT GALLANT
Check the crankshaft sensor, that may be your problem, if you would list the code you got i could help some more, just because you got a cam code doesnt mean the cam sensor is bad, check the wiring also from the sensor.
Sep 05, 2010 | Mitsubishi Galant Cars & Trucks
HOW DO i reset my camera when I get a "lens error" message?
If the camera is under guarantee take it back,
the lens error is that the lens isnt locking properly, to do this (and this is going to sound nuts) you must take the battery out wait 2-3 minutes then whack the camera (side) on a hard surface like a solid wood desk( not too hard), this will help unblock the lens to close/open correctly),
this is a fault with this particular model and its going to continue happening to you,
Jul 30, 2010 | Canon PowerShot SD1100 IS Digital Camera
Does not get cold anymore. When I plug it, I can hear the motor running for about 10 sec and then I hear a clic and everything stops
thats the Compressor overheat relay kicking in sygnifying a faulty compressor meaning a systems engineer is needed to replace if economically viable..
Dec 22, 2009 | Freezers
How to install a web cam for weindiow 98 sec
just plug youre webcam then the win98 sec will ask for the device driver if you still have the installation disk of web cam just put it in the cd or dvd rom and just follow the instruction, then check the cable of the web cam weather it is a usb or com cable
michael
Nov 18, 2009 | Computers & Internet
Cam works for a few seconds and shuts off
try to loose the static charge and reinstall proper driver from www.download.com
May 08, 2009 | Labtec 961307-0914 Webcam
When camera turns on, i see white screen with crack
the crack that you see is an internal crack. this may solve your problem. turn camera off, take out battery and memory card then after 10 secs replace battery with a fully charged one. do not insert memory card. turn cam on and check if you still have the internal crack, if it is not resolved, send cam in for repair
Dec 04, 2008 | Cameras
A drop image on screen
hi i have panasonic NV DS 65 initially when i power on the cam it started then after 5 to 10 sec the power light automatically flashes and the buttons on camera doesnt work any more. but now the problem has got worsend the powen light keeps on flashing and no buttons work moreover a drop image is flashed on the screen.
plz have me solve my problem
sam_rav
Jan 24, 2008 | Panasonic NV-DS65 Mini DV Digital...
Sony Cyber-shot DSC-W180 Digital Camera Logo
60 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
