Question about Zebra QL 320 Thermal Printer
Hi.. we have a ql320 printer that we using for labels. We using gap sense and the feed stops at the right place. However, when ever we print labels, we get a blank label printing after every label print. Is there something that we can do to sort out this issue? Your assistance will be greatly appreciated.
  • 45 Answers
SOURCE: extra feed
The label sensors might not be getting a strong signal as the labels pass between them.
Make sure the labels are loaded all the way to the left (as viewed fron the front) and make sure the label guide (near the back of the printer) is set to keep the labels from wandering away from the sensor.
There is a pair of infrared emiter and detector located above and below the label path. As label pass between, these measure the leading and trailing edges of each label.
If you haven't already done so, calibrate the printer, by using the "Online", "Calibrate", "Online" buttons. Hit the "Feed" button a few times to see if the labels feed consistantly. It might take to "Feeds" to get each out, if they stop at both the start of the printhead and again at the tear bar. Adjusting the labels and calibrating fixes most problems. If the "Feed" button still doesn't feed just one label and the printer still skips labels, you'll need to adjust the label gap sensors. This can be a bit tricky if your labels are very narrow.
There should be a small pcb on a shaft under the label path. Note its current location, then slide it left or right to get a better signal, and try the feed button again. On my Zebras, the sensor is not in the middle of the PCB. Look for a small metal "can" on the PCB and center that.
The upper sensor is more difficult to adjust, but if you manage to spot a very small PCB above the labels, it will be easier to line these up.
Posted on Sep 18, 2008
SOURCE: TLP 2844 skips 15-16 labels then prints intended label
It sounds like they may need to set their "Q" values for the labels they are using.   If that isn't it, we may need more info - are they using Zebra brand or custom labels?
To start with, I would ask them to try adding these "Q" value commands: q456 Q152,24
If that doesn't work, then maybe they can provide the other info mentioned above so we can understand the problem better.
Posted on Jan 05, 2009
  • 32 Answers
SOURCE: the Zebra 2443 printer is feeding out 13 to 14
It sounds like the printer is not calibrated. This procedure is in the users guide. Make sure both labels and ribbon are loaded correctly and then perform this procedure. If you do not have the manual or still have issues, email me at hilster1968@gmail.com for the procedure.
Posted on Oct 27, 2009
  • 4340 Answers
SOURCE: the printer will print one
This sounds like a size issue, meaning that your label has too many lines and that kicks to the "next page".
Look for too many line items on first label.
Posted on Oct 06, 2010
SOURCE: How can we change from black bar sensor printing
First you need to send below file to the printer via Vista Label
Printer >> 1 Send File
Save this file as gapsen.txt:
! DF CONFIG.SYS
! UTILITIES
GAP-SENSE
PRINT
To save this as default setting, send below script (save as setting.txt)
^XA ^JUS ^XZ
Posted on Dec 23, 2010
My Zebra ZDesigner LP2844 feeds a blank label after printing a label. How do I make it stop doing that?
Define your label size correctly. Measure your LABEL exactly, do not include the backing paper or the gap. Calibrate the printer. HOW?
Power off printer. Press and hold the green feed button down and power printer on. Count one, two and release green button. The printer will calibrate and move labels and then print some stuff on the label. Wait until it has comletely stopped. wait another few seconds and the press the feed key once. The printer will print "out of dump". You should now be ready to print again.
Aug 31, 2013 | Zebra LP 2844 Thermal Printer
Sato cl408e - printing over perforations. I tried turning the Pitch(all the way to the right) and Offset(all the way to the left), and this helped a little, but still not right. Because of this, when the...
Reset printer sensor threshold setting.
Turn on printer whilst holding down line key untill printer beeps.
Use feed key to step to Gap in display.
Load label plus backing under sensor and not volts reading.
remove labels and place backing only under sensor and note volts reading.
use following formula
High reading + Low reading / 0.5 = Value to use
e.g 2.8 + 1.4 / 0.5 = 2.1.
use result to change value of input using line key once set press feed key to set.
To change label start position use the pitch menu.
Jun 02, 2011 | SATO CL408e Thermal Printer
How to calibrate the label in QL320 plus zebra printer?How to make it only feed 1 label per print?
create a text file called Calibrate.txt and in the text file type this:
~JC
^XA
^JUS
^XZ
then send the file to the printer using label vista.
this will then print 3 - 4 labels and stop.
once u press the feed button it will only feed one label.
Dec 10, 2010 | Zebra QL 320 Thermal Printer
How can we change from black bar sensor printing to using the gap between labels on a Zebra QL320 plus?
! DF CONFIG.SYS
! UTILITIES
GAP-SENSE
PRINT
^XA ^JUS ^XZ
Nov 03, 2010 | Zebra QL 320 Thermal Printer
Hi I have a Zebra ql220 printer that prints about 4 or five blank labels in between barcodes. Is there a way to manually adjust this via the printer. I got a message on one printer about bar gap sense not...
Press and hold feed button for 2 -3 seconds and switch on printer.Printer will calibra and print test page .if problem is not solved Go to printer menu and select ribbon and media calibration.it will calibra te printer and problem will be solved
Aug 03, 2009 | Zebra Printer 140-751-00000
Zebra TLP 2844 Desktop Printer
make sure you have selected the correct media in the printer driver. The tracking mode has 3 options, (1) Web Sensing (Cut Labels), (2) Mark Sensing (Black marks on back of liner) and (3) Continuous . In your case select continuous. It sounds like the printer is in the wrong media mode and is feeding labels looking for a mark or gap and when it doesn't find one it flags a media error.
Aug 15, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Intermec PC4 label printer
Your printer is not sensing the gap between two labels.Please try calibrating the printer for the gap.
Switch ON the printer while holding FEED key down, on printer start feeding label realese the FEED Key.
Printer will stop feeding paper after printing SELF TEST, Once again press FEED key for 3 seconds. Printer will enter into normal Mode.
Check now.
Aug 14, 2008 | Intermec EasyCoder PC4 Label Printer
Zebra LP 2844 prints blanks
If the printer is printing nothing but blanks, try another roll of labels.
If the printer is printing blanks in between labels, it probably needs to be gap sensed. You can do this by:
1. turn the printer off.
2. hold the feed button down and then power the printer back on while still holding the feed button down.
3. release the feed button when the light flashes.
4. the printer will then regap itself
5. when the regapping is done, press the feed button once. It will print on the label that it is 'out of dump'
6. the printer should then be ready to go.
May 03, 2008 | Zebra LP 2844 Thermal Printer
Printing die cut labels on Zebra Z4Mplus?
Set the printer to transmissivefrom reflective gap sensing.
This will cause the printer to loog for the inter-label gap to tell it where the top of the label is at.
Steve Weinrich
LazerTek, LLC
Dec 15, 2007 | Zebra Z4Mplus Label Printer
Feeding
Hello Sarunas,The problem ultimately, might lie with label feeding,Try Printer feeding,when u give the feed button, the labels should automatically, stop at the gap position, try printer calibration settings.
Hope fully, this should solve your problem
If you Any other queries, Related to barcode printer - Sales and Services.
Contact , Trridev Labelss Mfg Co Leading Labels Convertors In Tamil nadu
For more information visit our web page.
Jun 26, 2007 | Argox R-400 Thermal Printer
Zebra QL 320 Thermal Printer Logo
159 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
