How can I clean the air filter on tv - Televison & Video
  • 12,061 Answers
Hi well in the shop I use a stuff called "Canned air" this is just a cheap spray can of compressed gas, (Nitrogen) and I use it to blast away, harmlessly, all the detritus. I also use a vacuum to immediately catch the stuff dislodged during cleaning as we don't want it getting into the internals.
Almost any Radio Shack or electronics, or electrical shop should have something similar.
Of course if you have a vacuum cleaner that one can reverse, to blow, then this too can be used, putting on a smaller directional nozzle is beneficial.
If they are the type that are removable then they can be taken out and cleaned, then of course do this, and use the air cleaner to clean it all out, and return to the housing.
Some have replaceable/removable "Elements" obviously then one would have to find replacements, or perhaps they too may respond to a good clean?
Posted on Apr 07, 2011
Tv is displaying to clean air filter, where is the air filter? How do you clean it? Does it have a reset?
Found on the net:
The Panasonic air filter is located BEHIND the removable Front Panel.....it pops off and you should see it located in a "screwed in" panel.
But, it MAY be located on the BACK or side.....LOOK for a Grille with a grey or black foam piece. IF you don't find it behind or beside the TV, then pull off the Front panel.
Now, those foam filters can be removed from the grille-plate to be washed......the best way to wash it is to PUSH the dust out of the filter by turning the Clean-side of the filter TOWARDs your water source (the faucet or the Much-preferred Kitchen Sprayer)....Now get that DUST OUT!
Once finished cleaning just shake all the water out of the foam panel. Snap it just like you're snapping somebody with a towel. Still Moist? Don't worry, the plenum on the TV is pretty long and "moisturized air" won't hurt the bulb......
Reassemble it......
And DO NOT let that filter go that long between Cleanings!! It EXTENDS the life of the bulb when maintained regularly.
Oct 12, 2010 | Panasonic PT-52LCX65 44" HDTV
The TV keeps shutting down due to over heating. Is there something that needs to be cleaned?
Yes you need to clean the AIR FILTER located in TV.
Please follow the steps below to clean it.
1. Turn the television off and unplug the AC cord.
2. Locate the dust filter on the left side panel of the TV.
3. Using a phillips screwdriver, remove the two screws that hold the dust filter cover in place.
4. Remove the filter cover, set it and the screws aside.
5. Carefully remove the filter from the TV.
6. Clean the filter material by dusting with a lint-free cloth.
7. If the filter is soiled, you can rinse it with water. Do not use detergents or soap on the filter.
8. Completely air dry the filter before placing it back into the TV.
9. Replace the filter cover and secure with the screws.
For showing location i have attached a image.
Thanx
Jul 25, 2010 | Mitsubishi WD-52525 52" Rear Projection...
A screen comes up and says time to clean air filter, Where is the air filter located?
I just experienced the exact same thing. The tv will shut off if it gets too hot, and a clogged air filter will make it too hot. My tv is still under warranty, but I watched the technician do it. He removed the front and back part of the tv. He got down to the bulb enclosure in the rear of the tv, which is where the filter is located. He used my dirt devil and a brush to clean out the filter and the whole general back of the exposed tv. The he put all the pieces back on the front and back of the tv. Hope that helps!
Feb 23, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
An OSD advising "AIR FILTER CLEANING" is displayed
You must remove the light engine then locate the filter by removing a black cowel looking device at top of engine held by 4 screws,then you will see the rectagular filter held with 4 screws you must pry out the filter it does not come out easy. Clean it with clear water and blow out with compressed air look at it through light to make sure it is clean. reassemble The sevice manual will show you how to remove the light engine.
Feb 10, 2010 | Panasonic PT-52LCX66 Projection Television
How do I clean air filter on the Panasonic PT-50LCX64?
I feel bad for you having such problems with the vendor and the technician too.
The location of that filter could be a small window in the back cover itself. could be a plastic window to the left side of the unit and is only a piece of plastic poliuretane kind of black sponge about 5 by 3 inches size .
What im interested telling you about the shut down condition and is maybe even most important than where is the air filter (who is one of the more than ten posibilities why the tv goes to shut down.
Note:
if the air filter is totally obstructed i would give one of ten probabities of suspicious why the tv shuts down:
first because the tv's air duct is not really isolated. The fan can eat air by any side of the air filter base as i said if the filter is totally obstructing which is really extreme. besides maybe the other 2 fans could help to cool down the unit in that case scenario. In my experience Most time the air filter holds tons of dust but is not totally obstructing the air passing, and really some other problems are in the set.
This is the really critical to know: if any of those fans stopped or maybe any sensor is overheated or the lamp is coming to dead or who knows.. a diagnosis is needed for this symptom really common in DLP technology.
Apr 18, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-60LCX64 Air Filter Cleaning
Cleaning filter for the Panansonic PT-501LCX64.
I just had a T.V. tech do this. The filters are located on the two removable filters on the back side of the T.V. They look like the speaker units. He removed those two units, unplugged them & set them on the floor. He took some type of electronic cleaner with a cloth & wiped them down. The filters themselves are plastic. He explained that air flows through some tube connected to these plastic filters for cooling down below. He admitted they didn't look dirty--put everything back together & it is working fine now.
I imagine that dirty or not the timer is automatically set for every 400 hrs. of use to give you the prompt that the filter needs cleaning & will shut off in one minute so you can call a T.V. tech?
So to reset the timer--follow the other detailed prompts listed on this board & or use your owners manual & follow the prompts for replacing the bulb. That should take you somewhere to reset the timer--so you have another 400 hours of operation.
I believe it's with the T.V. turned off--hold down the down volume on your tv itself while holding the swap button on the remote control for 5-7 seconds---then follow the prompts. You should see a prompt for replacing a bulb & then one for filter cleaning. Then just reset the timer.
Hopefully this will help?
Nov 04, 2008 | Panasonic PT-60LCX64 Television
Where is the air filter on my Panasonic PT50LCX64 TV and how can I clean it?
I have the same problem!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 05, 2008 | Panasonic Televison & Video
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
