Question about Brother DCP 165C Compact Color Inkjet Multifunction Printer
I seem to be pushing all the correct buttons but i cant work out how to scan , when i press start its just showing conncetion /connecting to computer and goes no further can you give me in real simple step by step what to do
    Sergeant:
  • 174 Answers
Make sure that no pending jobs exist in the que, Remove the device driver from Add / Remove program of the system and re-load the driver.
Posted on Apr 07, 2011
CODE 162,0,0 ON CANON D1350
This happens across the range of Canon Printers. The fix is to push the right button! Yeh I have a differing model, but the answer is the same. Go to the printer and select remote scan. Then invoke computer program. Some one has to be boss either the printer or the computer for scanning.
I can make the scanner printer the boss and issue a TIFF scan to the computer. Just push scan on the printer and select computer (it does a push data)
I can make the computer the boss by selecting the steps below:
Please choose what option you require. Ignore the model number.
The error codes 162,0,0, or 255,0,0, usually indicate that you have not selected a scan type at the machine. Please follow the steps below to perform a scan from the image I-SENSYS MF8230Cn:
Verify that MF Toolbox is closed on the computer and press the [SCAN] button on the printer.
Highlight [Remote Scanner] and press [OK]. The screen will show, "Remote Scanner. Waiting online...".
On the computer, open the MF Toolbox and select [PDF].
Click the green [START] button on the [PDF] window. The machine will start processing the scan.
If you receive any errors or need further assistance with the I-SENSYS MF8230Cn, we recommend that you contact us at 1-800-OK-CANON (1-800-652-2666).
Sep 29, 2014 | Canon imageCLASS D1350
Cant get the scanner to work - press 'scan' button and black 'start' button, but computer scren does not show the scanning function. FYI - Printer is connecred and works.
Hello
Try this: restart you PC if the problem is still exist, uninstall your driver and install it again. might be the driver is corrupted.
thanks
Mar 11, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Hi i have a dish network universal remote cant seem to get the right code for tv
Turn ON the electronic device you want to program the remote to control.
Press the TV Mode button on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Jun 30, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Hi, I own notebook Aspire 5570. I have problem to turn my NB on. When I push 0/I button, nothing happened. My friend checked adapter and battery, both are OK.
Please try the steps below..
1 Disconnect the battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Conncet the charger (don't connect the battery yet) and try to start by pressing the power button.
Also listen carefully for any beep sounds if you hear beep sound then the rams could be defective otherwise the mother board seems to be defective.
Feb 09, 2010 | Acer Aspire 5500 5570-2609 Laptop
Just purchased a microsoft wireless mobile mouse 3000 & cant seem to get it to work
make sure the reciver sensor usb cable you connaect properly, or if it it is usb dondle install in diffrent port also you can try just remove the battery and installed new one and press the conncet button from mouse as well as the sensor reciver .
Nov 16, 2009 | Microsoft Wireless Optical Mouse
I try to conncet to the wifi and I cant. At times when I do get connected with the wifi I cant do anything. Then it will have a pop-up window saying unable to connect
The first thing that I would advise you to do is,
Uninstall the WiFi Adapter totally from the System first,
Then go to "scan for hardware changes",
This will bring up a prompt to install the new hardware found (Which is your Wifi Adapter).
After this, Press your Wifi button on the system and ensure that it is On, then Scan for wireless networks.
It should connect like that.
(In case you dont know how to uninstall the Adapter, Right-Click on my computer Icon, Properties, Device Manager, then select the Adapter under network adapters, and right click on it, then select uninstall.)
Hope this helps.
Goodluck
Oct 31, 2009 | Toshiba Satellite A100-S8111TD Notebook
Limited or no conncetivity?
Seems to be issue with the switch. If you can get internet after bypassing the switch then it is for sure an issue with the switch. try connecting the cable to other ports of the switch.
If it still does not work then it is time for you to replace the switch.
Rate it,if it helps.
Jun 29, 2009 | NetGear Computers & Internet
System not detecting the player
try this before connecting your sansa turn iit off push the hold the right push and hold the enter button and press the menu button. Sansa should be ready take take the firmware update connect when asked to http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe
Jan 16, 2009 | SanDisk Sansa e260 MP3 Player
Can't Sync to mp3
how to get sync workin
Apr 20, 2008 | Audio Players & Recorders
Lexmark 5400 series
Problem: Lexmark cannot retrieve applications list
I have the Lexmark X3550 with the WiFi option board installed (makes it same as the model X4550) and get the “cannot retrieve applications list” message on one of the five computers connected to my router (Linlsys WRT54G V8) and using wireless printing and scanning. Just like everyone else with a similar Lexmark WiFi printer/scanner, I can print wireless, but cannot get the wireless scanner to work on one of my PCs.
The fix, in my case, was to change the Lexmark network name as follows.
1. Launch Lexmark Imaging Studio.
2. Right-Click on “View or change network settings”.
3. Enter a new network name in the first box shown. (This box contained the correct network name for my PC, but another name was needed to make the scanner work. I simply added “-lex” at the end of the current network name.)
4. Right-Click OK. You should return to the Imaging Studio screen.
5. Close the Lexmark Imaging Studio window. (The tray icon should remain at the screen lower right.)
6. On the printer, press the Scan Mode button.
7. On the printer’s display screen, select the Computer Name that you entered for the new network name. Just use the arrow buttons until the exact name is shown.
8. Press the Check button. The display screen should show “Downloading Applications List”. Within about 10 seconds the message should change to “ *Scan to Computer ”. Wireless scanning should now work.
9.. Press the Start Color or Start Black button. “Requesting Scan” will be shown. After a few seconds scanning will start. The process is a bit slow.
10. After a while you may see an empty small Lexmark window onscreen. Later, the Lexmark Imaging Studio will appear onscreen, then change to show many options and features. An image of the scanned item will appear in a Lexmark window. Save and/or edit the image. Another scan can be done by pressing the printer’s Check button again. Be sure the correct computer name is shown on the printer’s display.
That’s it. A new computer name was the solution. Your PC and printer may require a restart (power off) after changing the “computer name”.
Regards, Fbyrd
Mar 12, 2008 | HP PSC 2210 All-In-One InkJet Printer
Brother DCP 165C Compact Color Inkjet Multifunction Printer Logo
29 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
