Question about Whirlpool Refrigerators
Hi,i just bought a new ref, a WST85SS 8.5CF 2DRNF,i just turned in on,and i found that there's styrofoam inside the back of the fast chiller and inside the cooling tower,i dont know if it should be removed,and if yes,how? I hope you can reply asap,thanks. sincerely, jo flores
SOURCE: HELP!! I dont know how to remove the Anti-Static solder point!!!
http://forums.psxforum.com/viewtopic.php?t=31439
Posted on Dec 14, 2007
SOURCE: Styrofoam inside
There is a piece of styrofoam used in the construction of the air filter that is visible inside the unit. I think its there for noise reduction/insulation purposes and I wouldn't touch it if I were you. Unless you're talking about little styrofoam pieces that may have fallen in during packaging and shipping, I'd leave it alone.
Hope this helps.
Posted on Apr 15, 2008
SOURCE: CHILD LOCK Help needed
Hello i recently had a problem that my tv just locked itself which i think is the same type of problem, i contacted Daewoo and they gave me the following code to try and it worked, not sure if it will do the same for your set, but it might be worth a try.
press the following buttons in the remote in sequence
BLUE
YELLOW
GREEN
RED
STANDBY TO TURN OFF
STANDBY TO TURN BACK ON.
Hope this might help, if not try contacting Daewoo Electronics website and put in your model number.
Regards
H wilson
Posted on Apr 21, 2008
22yooper
  • 828 Answers
SOURCE: whirlpool american fridge
You have a problem in you automatic defrost system. It could be one of the following that is causing it. The defrost timer could be bad, Locate it and rotate the dial Clockwise SLOWLY until you hear one click. The refrigerator will be in the defrost cycle. Wait about 20-30 minutes and if it defrosts and does not restart rotate the dial a little more and it will start. This tells you that the defrost timer is bad. If it does not defrost and restarts after 18-22 minutes the heater or defrost thermostat is bad.
Posted on May 30, 2008
22yooper
  • 828 Answers
SOURCE: s20b rsb21 whirlpool
Your freezer section has a defrost system problem. A device (Timer) schedules defrosts, energizes electric heaters which melt the frost, when the temperature of the coil gets above the point where all ice is melted a thermostat opens cutting the electrical circuit for the heater(s). The defrost cycle continues until the time expires (18-22 minutes). Therefore your problem could be any one of the three elements. Timer, heater, or thermostat.
Posted on May 31, 2008
Tru mug chiller won't get cold
Is the compressor running? Is the condenser clean and the fan running? Is the fan inside running? Is there ice on the coil? Those are the first things I would check after I check to see that the plug has power and the temperature control is turned on.
Mar 29, 2014 | True Glass Chiller T-24-GC
My sharp freezer model SJ-229S-SL , UPPER IS WELL BUT BOTTOM NO COLD
Checked Damper in Ref its working or not. You can checked open Ref door press Door Switch and hold your hand near chiller tray Duct
Dec 27, 2013 | Sharp Refrigerators
I thought the styrofoam inside the dehumidifier float was packing material & threw it away. Now my dehumidifier gets too full before the "full" sensor comes on. Can I replace the styrofoam?
Hi Kim - I understand that you removed the styrofoam inside the dehumidifier float thinking it was packing material, however I would recommend contacting the manufacturer to verify if it the part is available and can be replaced.
Sep 05, 2012 | Frigidaire FDL50R1 Dehumidifier
Kitchen selectives rechargeable wine chiller bc-10r 8 minute chill
For the KITCHEN SELECTIVES WINE CHILLER...A box on ebay says: Put bottle inside, add ice to neck of bottle, add water, plug in and set timer for 10-20 minutes. It chills from 77* to 55*or 33* (can't read numbers clearly) in 10 minutes. Can also be used on other drinks and canned drinks. Can be used as an ice bucket as well to keep the opened bottle chilled.
I just bought one at Goodwill for $4 today and was looking for the instructions as well. Hope this helps! 8d55b92a-9870-497d-a9c6-7cda8d40c58a.jpg 11a83201-002b-4f0c-b811-810f4cf0046e.jpg
Dec 16, 2011 | Refrigerators
I have a whirlpool refrigerator, model GR9FHMXPQ. I got it about 4 years ago. When it was delivered, it had several pieces of styrofoam lodged in the inside ceiling of the fridge section (below the freezer...
You need to remove all of the styrofoam packing material.
Any insulation material would be installed inside the body of the fridge/freezer. The packing material is there so anything inside the compartment (like metal shelves, plastic holders, etc. don't bounce around during shipping and either scratch up the interior, or break. That is all that it is there for.
Apr 25, 2017 | Whirlpool GR9FHMXPS Stainless Steel Top...
Honywell whine chiller model 88058 not working
Hello friend, i had the same problem and it was solved replacing largest capacitors on board, they are 2 x 120uF(120V). You must to check that both original capacitors be damaged, you can to see it if they are inflated on the top
Jul 23, 2010 | Honeywell Consumer Products Model...
My refrigerator is't cooling & my freezer is
Pull down plastic panel inside which covers the temp adjustment. In center there is small panel and under neath is computer chip board R&R board. This should fix your problem but be sure to turn ref off and defrost the chiller tubed on freezer side before starting back up
Denny
Jun 24, 2009 | Jenn-Air JCD2389G Side by Side...
Fill Water tank - Ventilate
Hi Mike,
Make sure the magnet flow up, if it flow up and you still get fill water tank then you have to replace the magnet.
If you get ventilate all time, try to remove the filter and try again.
/Mirran
Aug 23, 2008 | Saeco Incanto Classic Espresso Machine
Styrofoam inside
you may open and remove foam not included in unit , be sure return make align everything.
Jan 01, 2008 | Kenmore 335 CADR Air Purifier
Refrigerators Logo
97 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
