Question about Asko W620
Asko W620. Motor not rotating. Have replaced brushes & checked the larger of the pressure sensors - it seems ok. What next?
  • markhc Apr 08, 2011
    Checked cct board - lot of dry joints - desoldered and resoldaered them all. Machine now works ok...
  • 3 Answers
SOURCE: Asko W620 washing machine not spinning
Sounds like the motor brushes need to be cleaned or replaced. Take the back off the washer, remove the motor and gently scrape the excess carbon or debris off the brushes with a pocket knife. I did this and it ran well for about 50 loads before building back up. I am ordering new brushes now because when I checked the brushes last week they were obviously worn more than 4 weeks ago.
Posted on Jan 21, 2008
  • 3 Answers
SOURCE: asko front loader washer w620
Check your motor brushes. They may need to be replaced.
Posted on Aug 05, 2008
SOURCE: asko 620 not spinning and not agitating
Clean armature and replace brushes. When you remove the brushes the shut a small pin like device maybe protruding from the brush tip. this is a sure clue.
Posted on Sep 19, 2008
SOURCE: Fitted new carbon brushes to motor. When looking
He means you would see considerable burning on the commutators where the brushes rub Or burnt windings on the motor.Usually changing of the brushes will fix it .Hope this helps Cheers.
Posted on Jul 30, 2009
  • 8404 Answers
SOURCE: I need new motor (spin) for W620 that is 8 years
Nope
Posted on Oct 27, 2009
No water coming into the washer replaced the motor
YOU REPLACED THE MOTOR? WASTED UR MONEY TRY TESTING THE WATER INLET VALVE
Feb 22, 2014 | Asko W620
My asko w6200 won't start .I checked the fuse and everything is ok. what should i do next?
Hello Alain, welcome to FixYa.
May I ask which fuse you refer to when mentioning you have indeed "checked the fuse" ? Are you alluding to the fuses at the back of the washer ? Let me know and I'll try to assist you in any manner I can going forward.
Regards,
Macmarkus :)
Oct 16, 2011 | Asko W620
When washing, the tub only rotates in the clockwise direction, and seems to rest through the part of the cycle each time it is supposed to rotate counterclockwise. It also seems to work ok on the first...
Welcome to FixYa.
Based on the info you've provided in your post, I'd suggest you have a worn motor brushes problem unfortunately...the manner in which this usually manifest it exactly as you described.
If you can provide a model number, I can likely walk you through the procedure to inspect the brushes, armature and ultimately replace the brushes or motor if necessary.
Let me know what you decide (you may opt to call a pro...but it really isn't too difficult in my opinion) and we'll move forward from here if necessary.
Good luck.
Regards,
Macmarkus :)
Feb 24, 2011 | Asko Washing Machines
Asko 10505 washer will not spin
Hi, 2 things to check for. Obstruction in the drain pump or faulty drain pump, brushes in the motor worn out. The easiest way to determine the pump issue is answer this question. Does it drain ? Next, turn the timer to the drain/spin cycle, obviously it should drain & spin and advance to "off". The next thing with these 10505 asko is to see if the drum rotates in both directions in the wash/agitate portion of the cycle. You can just select the short wash for this (I forget if it's #4 or #5) If not, it's worn brushes. However, you'll have to make sure the armature isn't damaged before simply installimg new brushes. We can cross that bridge when we get there. Let me know. Hope that helps, though those are just the most common problems there could be others. Good Luck
Nov 01, 2009 | Asko W6021 Front Load Washer
Motor not running in Asko 10504 washing machine
The motor might have burned out. Another possibility would be a partially fried control board.
Jan 17, 2009 | Asko Washing Machines
My Asko W620 washer won't spin the first time through.
Try Googling (asko)(W620)(manual) without parens.
Jul 22, 2017 | Asko W620
Asko 620 not spinning and not agitating
Jun 18, 2008 | Asko W620
Asko front loader washer w620
Apr 19, 2008 | Asko W620
Dec 11, 2007 | Asko W620
Washing Machines Logo
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
