Question about Samsung RV510-A02 T3500 2.10G 320GBDVDRW 15.6IN W7HP - NP-RV510-A02US Hard Drive
Hi, I just recently purchased a Samsung notebook (RV510-A02). My system was running great until it did an automatic windows update. Not sure is that caused my problem though. My problem is the following: Sometimes when I turn the machine on, the bios screen appears and it gets stuck there and doesn't move on to starting windows. I then have to turn the machine off again and then on, and only then does the machine startup properly. This issue doesn't happen every-time, but at least half of the time that I start up the machine.Please help. Thanks a lot. Regards Paul
  • 416 Answers
I hate to tell you this, but one of two things is more than likely happening.....Either you have a corrupted windows partition or your Hard Drive is on the fritz
1. **windows partition corrupted A. Boot to recovery and try a full system recovery to before the problem began B. You can try a "clean" install of windows (will erase all saved data but you can back up important documents*****this method will require installing ALL windows updates and software from scratch)
2. Bad Hard Drive A: GO to "start menu" > "run" > type "cmd" > type "chkdsk" (let the process run and it will prompt you will any defects in the HDD B. Replace the drive if necessary
Good LUCK AND REMEMBER!! IF YOUR SYSTEM IS NEW USE YOUR WARRANTY!!! THEY ONLY KNOW IF SOMETHING IS WRONG IF YOU TELL THEM!!!!!!!!
Posted on Apr 07, 2011
    Sergeant:
    Champion:
  • 217 Answers
Not sure which update you did, and some can't be reversed, but you can try a system restore. Pull up the security tab and look to the left for a system restore option. Start system restore and choose a restore point from a date when your computer was working fine.
  • Samsung Master
  • 27,725 Answers
If you recently bought this laptop it should be under warranty you could take it back to be fixed or
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
hope this helps
Download cd rom driver for samsung rv510 laptop
Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8
it might take some time being a freeware driver solution Note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Apr 02, 2013 | Samsung RV510-A02 T3500 2.10G 320GBDVDRW...
Samsung download laPTOP MANUALS
For updates for your samsung laptop, you can go to: http://www.samsung.com/ph/support/download/supportDownloadMain.do
However, it might take time for you to get it done because you need to manually do it. There is actually one software that works the trick in updating your computer's software.
It is called Radar Sync . It is actually a software that you need to download in your computer. Once it's installed, it automatically searches for outdated drivers in your computer, it searches for the available updates and it updates them. Sounds automatic right? You don't need to find any new updates or to stumble from one website to the other because the software does all those things.
I recommend you the software because I understand that you are looking for the right updates for your samsung system.
Nov 14, 2012 | Samsung RV510-A02 T3500 2.10G 320GBDVDRW...
Samsung RV510 notebook won't come on
Ok, then, try this:
1. Unplug your power cord,
2. Remove Battery,
3. Press power on botton for 3 sec.
4. Now plug battery again,
5. Locate F8 key (it is a single key, at top of your keyboard)
6. Press power on boton, and as soon as screen shows manufacturer logo (or memory count), start to press F8 key repeatedly until a menu display,
7. Select "Secure mode"
8. When the system starts, clic on "Start" boton, and type "recovery"
9. At new window click on "Open System Restore"
10. At new window, cick on "next"
11. From list, select a date prior AVG uninstallation.
12. Follow wizard instructions.
System will restart several times, and if you are luky, then your system will work again. And, PLEASE, Do not install Symatec any more. Try Essentials:
http://www.microsoft.com/en-us/download/details.aspx?id=5201
Sep 20, 2012 | Samsung RV510-A02 T3500 2.10G 320GBDVDRW...
I dont have cd rom drivers
Your laptop shipped with windows 7, CDRom drivers are built it. can you explain your issue more?
Thanks.
Feb 08, 2012 | Samsung RV510-A02 T3500 2.10G 320GBDVDRW...
Can you get me the drivers for samsung rv 510, compartible with widows xp service pack3
You can download the device drivers from the Samsung WEBsite. Please click on this link and select your model computer/notebook and theWindows drivers you require :-.http://www.samsung.com/us/support/
Nov 14, 2011 | Samsung RV510-A02 T3500 2.10G 320GBDVDRW...
I dont have samsung recover 5
Have you tried pressing F4 during startup. It shhould take you into recovery mode.
regards
Jul 23, 2011 | Samsung RV510-A02 T3500 2.10G 320GBDVDRW...
CANNOT USE THE WEBCAM AND BLUETOOTH DEVICE
you might need to syncronise the webcam with the bluetooth device
http://download.cnet.com/%7Bvalue=http://www.download.com/microsoft-activesync/3000-2094_4-10031823.html
Microsoft ActiveSync 4.5 is the latest sync software release for Windows Mobile-based devices. ActiveSync provides a great synchronization experience with Windows-based PCs and Microsoft Outlook right out of the box. ActiveSync acts as the gateway between your Windows-based PC and Windows Mobile-based device, enabling the transfer of Outlook information, Office documents, pictures, music, videos and applications to and from your device. In addition to synchronizing with a desktop PC, ActiveSync can synchronize directly with Microsoft Exchange Server 2003 so that you can keep your e-mail, calendar data, tasks and contact information updated wirelessly when youre away from your PC. ActiveSync 4.5 supports PC sync via USB cable, Bluetooth, or infrared connection.
hope this helps
Jun 03, 2011 | Samsung RV510-A02 T3500 2.10G 320GBDVDRW...
Samsung RV510-A02 T3500 2.10G 320GBDVDRW 15.6IN W7HP - NP-RV510-A02US Hard Drive Logo
1,362 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
