Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Replaced convergence ics but now power light blinks 3 times
Hi-I just replaced my convergence ics and when I went to power up my TV the power light just blinked 3 times and there was nothing it wouldn't even come on.Any ideas?Please help.Thanks
  • LEEBEE72 Aug 06, 2008
    I replaced with stk 392-115
    sorry I mean stk392-150
  • Panasonic Master
  • 8,617 Answers
Your model will not work with STK392-115 in fact I have never heard of those ICs.
Posted on Aug 06, 2008
  • Sonny Berry
    Sonny Berry Aug 06, 2008
    ok that IC will work in your model the panasonics are famous for blowing the convergence feed resistors when the Ics go out. They are six 2.2 ohm 2 watt metal film resistors. You can get replacement resistors at the following link.
    http://servicemanuals.vstore.ca/
My panasonic rear projection tv does not turn on the red light blinks 3 times
3 times red light blinking indicates that tv got problem of convergence output ICs failure and need to replace two big black ICs (convergence output) to solve this problem.
IC replacement requires soldering work and good knowledge of electronics stuff repair, please cal local tv repairman if you do not have prior experience of such work to avoid any damage.
Hope this will help.
Thanks.
Feb 28, 2011 | Panasonic PT-53TW53 53" Rear Projection...
I have a 47" projection tv that comes on and then it goes right back off and the light code blinks 3 times
Replace convergence out ICs in A Board to fix this issue.
3 times blink shows convergence problem.
Jan 08, 2010 | Panasonic PT-47WX52 47" Rear Projection...
Blinking power light
Power light blink 3 times shows that convergence out ICs got defective and need to be replaced.
If you are handy with electronics stuff repair and can solder parts in circuit board with proper tools then replace two big black ICs, convergence out, mounted on aluminum heat sink.
Or call local tech to fix it.
Let me know if you have additional question.
Thanks.
Dec 23, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic projuction screen tv.
3 blinks is the error code for the convergence ICs. You need to replace both STK392-110 convergence ICs. You can get replacement ICs at the following link and they provide installation instructions with pictures.
Oct 12, 2008 | Panasonic PT-47WX42 47" Rear Projection...
CONVERCENCE PROBLEMS
did you replace the convergence resistors with the ICs? Often the resistors will need to be replaced also when new ICs are installed. 3 blinks means convergence Failure so its either the solder connections on the ICs or the resistors need replacement. If you need more assistance please let me know.
Sep 27, 2008 | Televison & Video
Panasonic PT-56TWD63 When I turn it on, the power light comes on for about 10 seconds then turns off and blinks 3 times every 3-5 seconds, but no power and light will not stop blinking until TV id...
3 blinks is due to the convergence ICs you need to replace both STK392-110 ICs . you can get replacements at the following link with free installation instructions
Aug 31, 2008 | Televison & Video
Hewhen lp
The convergence ICs need to be replaced. # blinks is the error code for the convergence. You will need two STK392-110 Convergence ICs you can get replacement ICs at the following link with free shipping and free instalation instructions with pictures.
Jul 10, 2008 | Panasonic PT-47WX49 47" Rear Projection...
No sound and the power light is blinking
I had similar issue with power light blinking 3 times and no audio/video.
The problem was a burnt resistor and gone convergence ICs. I replaced both ICs (safer bet unless you know exactly which IC covers what guns in your specific TV) and the burnt resistor by myself and the TV looks good as new.
Apr 06, 2008 | Panasonic PT-56HX41 56" Rear Projection...
Tv repair
My Tv was doing the same thing, and I had to unplug the set in order to get rid of the blinking light. And what i did was to turn the power on and as soon as i saw the picture i turned it off, I did this 5 times and on the 6th time I let it power and tv stayed on, however something did happend to my set, i found that my convergence was wacky. Tried to center convergence but i could not center the blue. Turns out, i think the problem is with my Convergence ICs that went bad. I can still watch tv but the Image has blue color shadows and the picture slightly bows inwards from top and bottom. To sum this up, i will need to replace 2 ICs, IC C5AA00000203, and this should fix my problem. I will do this repair myself, each part is about $41..
Let me know what happened to your problem.
Thanks
Tony
Dec 01, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
64 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
