Question about JVC GR-DV3 Camcorder
Jvc gr-dv3 camcorder
My camcorder keeps saying error e06 can you tell me what is the matter with it and can it be fixed thanks
  • Anonymous Aug 30, 2008
    I have a similar problem and am getting the E06 error. The mini dv tape is getting stuck as well. It was working fine until somebody dropped the camera.
SOURCE:
SOURCE: JVC CAMCORDER
I have the same problem and I need a solution. Please, can somebody help?
Posted on Dec 27, 2007
SOURCE: JVC Camcorder Model # GR-D270U
I thought this was a camera issue, but it ended up being a tape issue. So it shouldn't matter if you have the same model of the JVC mini camcorder as I did or not. Anyway, the tape has a tab that "locks" the tape to keep from recording over it accidently. I moved that tab and it started working. If your tape is stuck in the camera, you may have lost the tape already. Try to get it out of the camera without damaging the tape or the camera...more importantly the camera. You may have to take it to a professional to prevent damage. If you get it out undamaged, check to see if the tape is locked or not. Move the tab and try the tape in the camera again (unless you're afraid of it getting stuck again). In that case, try it in another camera. That's how I discovered that this was a tape issue rather than a camera issue...because I tried the same tape in a different camera and got the same error message. Don't despair if your tape comes out with part of it sticking out or crumpled, as long as it's not broken, you can salvage it. Even if it's broken, you can probably salvage the majority of the tape by taping it back together (call a professional, you may need special tape for this), just don't touch any of the undamaged tape or pull it out of the cassette too far and all you will lose is the damaged portion. I actually couldn't see the tab well enough to tell if it was in locked or unlocked mode since it's so tiny and my close-up vision is getting blurry, but I moved the tab to opposite of what it was and that seemed to do the trick. My mistake was in trying to save money with the cheaper tapes...next time I'll spend a little extra for the better tapes to avoid all this headache. Hope this helped. Have a great day!
Posted on Apr 08, 2009
  • 44 Answers
SOURCE: JVC GR-D33U Mini DV Digital Camcorder Opened
check with
bestbatt.com about the battery. Thay have been very helpful to me and my JVC Minidv
Posted on Mar 15, 2010
  • 1417 Answers
SOURCE: e06
hello,
this an indication of error detected by the sensor reader meaning that range has fail below 06degree the camcorder will need a resetting programing before you can do this you will have to put off the system for some time remove the battery if any then put it on again and then reset it the problem is solve .
please rate this solution .
thank you and thanks for using fixya.
Posted on Jul 05, 2010
SOURCE: JVC GR-D32 model. Error Indicator notes
Its gonna cost you more $ to fix it than it's worth it. Don't buy Mini DV anymore... save all your videos to your PC, and invest in a different media camera.
In other words... throw it away.
Posted on Jan 09, 2011
JVC GR-DVM55U Error E06
HI,
"E06" it is the carriage mechanism that has failed. and will not carry the tape to the heads and thus is not passing the sensor that tells you if the tape is in position and then telling the unit as it should there is fault.
take it to the nearest dealer and get it fixed.
Aug 23, 2008 | Televison & Video
Jvc gr-d350u. Constant E06 code with either battery or power adapter
if the screen keeps showing e06 device is in safeguard mode """"please remove or reattach the battery""""" If the error continues, please understand that it is a FAULTY BATTERY. This error is very common and results when the battery life has been changed or altered due to time elapsing. There is not a lot that can be done except to request a new battery. I performed more research on this and found that an equivilent may be purchased directly from jvc.com for a fraction of the costs then replacing the entire unit.
Jan 11, 2011 | JVC GR-D347U Camcorder
E06 problem jvc gr-sxm260u
hello,
Jul 05, 2010 | JVC GR-SXM260U Camcorder
GR-DVL320 keep getting E03 error indication. Ejecting and reinsertion of the tape does not seem to be fixing the problem, also says unit in safeguard mode. What do I do to remedy this?
1. The idler gear does not engage with the reel disk well.
2. Though the idler gear and reel disk are engaged with
each other, the tape is not wound because of overload
to the mechanism.
3. No FG pulse is output from the reel sensor.
4. No power is supplied to the reel sensor.
5. Tape transport operation takes place with a cassette
having no tape inside.
6. The tape slackens and no pulse is produced until the
slack is taken up and the tape comes into the normal
Sep 02, 2009 | JVC GR-DVL320 Mini DV Digital Camcorder
Jvc camcorder gr sxm37u
There will be a error code on the screen start from E01 to E06
Oct 16, 2008 | JVC COMPACT VHS-C CAMCORDER
E06
E06 is a capstan motor problem.The capstan motor needs replacing.
Sep 02, 2008 | JVC GR-D20EK Camcorder
SAFEGUARD MODE ERROR CODE E06
Why not do what the manual says ? They're printed to assist you.
Jul 14, 2017 | JVC GR-D201U Mini DV Digital Camcorder
E04 Error
Eject tape leaving cover open and remove battery. Re-insert battery and re-insert tape also leaving cover open. Keep repeating this process until eo4 message disappears. This worked for my GR-DVL100e after about four repeats. After getting your camcorder operational, they say it is good practice not to leave tape in camcorder when not in use.
Jun 26, 2008 | JVC GR-DVF21 Mini DV Digital Camcorder
JVC GR-DV3 Camcorder Logo
79 people viewed this question
Top JVC Video Cameras Experts
Ekse
Larry Stiles
Larry Stiles
Al Rush
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
