Question about HP LaserJet 3055 All-In-One Printer
The LASER JET printer is not functioing. Neither print outs are coming nor xerox.
    Sergeant:
  • 174 Answers
Make sure power is on, check the tonner cartridge, if scan and fax function ok, check the driver
Posted on Apr 07, 2011
How do i adjust heat settings in xerox 6110
If you tried to print on a transparency sheet for ink jet printers, in your laser printer, you could have damaged the heating rolls. The plastic could be molten on the roll and you won't be able to remove it without damaging the roll. As long as there is just a spec of plastic on the roll you will have paper jams. There should be transparency sheets for laser printers to, but always make sure you have those before using in a laser printer.
Jun 21, 2014 | Xerox Phaser 6110 Laser Printer
OUR PRINTER MODEL NO IS HP LASER JET 3055 PROBLEM IS WHEN WE TAKE XEROX COPY OR PRINT COPY ONE SIDE PAPER COMING BLACK SHED TYPE
Firs check toner catridge or else problem with the theflon sheet in the fuser unit need to replace it.
Jun 01, 2011 | HP Office Equipment & Supplies
How to a remove a jet from the substitution list on a xerox 8400 printer.
Select 'Troubleshooting' and press OK. Select 'Print Quality Problems' and press OK. Press and hold the 'Up Arrow Button', and then press the 'Back Button'. Select 'Turn Jet Substitution Mode Off' and press OK. Note, if jet substitution has not been enabled, the option to turn it off will not be available.
Hope this helps.
Jan 20, 2011 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8560 - I have been having print quality issues for a few weeks - what shows as bright blue on my screen or if I am printing a photo comes out very dark blue, purple comes out navy blue. I have...
Since it's a brand new printer it's probably not the printer, but your set up . Not knowing what program you are printing from, I can't advise beyond that 1) check the reference for the program you are printing from about setting up your color to be compatible with your printer (look under color management). Usually it has to do with your file's color profile matching the printer profile.
Oct 18, 2009 | Xerox Phaser 8560DN Laser Printer
Xerox 8550 Light Stripe after Jet Substitution & Muddy Yellow
Time to buy another printer. The Print Head will cost you 800-900 plus the labor to install. This printer is a crime that isn't prosecuted. This should be a $100 part and they make it more expensive than a new machine. Don't even try to make Xerox eat it. It will cost you more in sleep. Look to another manufacturer.
May 10, 2009 | Xerox Phaser 8550DP Printer
Can anyone help I have a Xerox 8400N and im getting 10mm image printing down one side rest of page blank
About a 95 percent chance that you have a bad print head.You can try cleaningn cycles and also jet substuitution but your problem is blocked jets.
You could have a piece of paper between the drum and print head.
Dec 22, 2008 | Xerox Phaser 8400 Laser Printer
Xerox phaser 8400 error code
That code is a jet heater code.The most likely problem is a bad print head, the second most likely bad item is the electronics module that supplies the 40-50 volt source to the print head heater.
Sep 22, 2008 | Xerox Phaser 8400 Laser Printer
Jet substitution
You want to try something different.
1. Go to www.xerox.com
2. Click support and drivers.
3, In the search box type in Phaser 8400.
4. Select Drivers and downloads.
5 Scroll down and find Jetfix snipit, and download that, follow the procedure, maybe more than once.
The price from Xerox is $750 plus labor to replace the print head.
You can also look up service dealers in your area on the xerox website. Most will get you the print head and labor much cheaper. I emphasise the MUCH portion of cheaper...
Jul 08, 2008 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400N Printing Stripes
When you go into the eliminate light stripes there is also a mode called Jet Substitution. You can sometimes bypass the bad jets.
If that does not work then the print head will most likely need to be replaced.
You can replace the printer for less than the cost of a print head normally..
HP LaserJet 3055 All-In-One Printer Logo
20 people viewed this question
Seeker5211
Seeker5211
