Question about Mitsubishi VS-50603 50" Rear Projection Television
My Ant A Input Not Working
When I went to bed last night, my system was working fine. I don't know if there was a power-outage last night or what, but we turned on the TV this morning and none of our channels are showing on our normal ANT A input, it is just static. I tried the "Home Theatre, Locked to Input 1" quick fix, and I made sure that it was off. I tried to re-memorize the channels in setup, adn the only two options that I have to memorize, are Ant-B Cable and Ant-B Air, it doesn't let me get to Ant A options, like that manual says that I should be able to. Please help!
  • Anonymous Dec 21, 2008
    Mitsu stuck on down loading tv guide. I unpluged, nothing. Help
  • 927 Answers
Good Day, babt;
TRY THIS:
MAY ONLY BE ABLE TO SELECT ANTENNA A AND B. WITH THE REMOTE CONTROL PRESS MENU, SELECT "SET UP" AND THEN "AV CONNECTION HOME THEATER" SET "AV NETWORK" TO "OFF" AND "TV LOCKED TO INPUT 1" TO "NO" THEN EXIT THE CUSTOMER''S MENU, TURN THE UNIT OFF UNPLUG IT AND THEN PLUG IT BACK IN, IF THE PROBLEM RETURNS AN E2 RESET IS NEEDED. ACCESS THE OPTION MENU BY PRESSING "MENU 1, 3, 7, 0", USE THE ADJUST BUTTON TO SELECT "E2 RESET" AND PRESS "QV". IF THIS IS NOT RESOLVED BY THE E2 RESET REPLACE THE EEPROM, IC701 PART # 275P163010. THE E2 RESET IS ALSO NECESSARY AFTER REPLACEMENT OF IC701.
Good Luck, big IRISH.
Posted on Aug 28, 2008
    New Friend:
After power outage, had similar issue. Simply set AV NETWORK to "OFF" and "TV LOCKED TO INPUT 1" to "NO". Worked wonderfully. Thanks a lot.
Posted on Jun 27, 2010
SOURCE:
How do i get my kodisolutions to work when i try to login it keep saying not connect to the server it was working fine yesterday and last night before i went to bed it was working fine dis morning it want...
Unplug the power from the modem and the router, wait about 30 seconds and plug both in.This will reboot the server and your device should resume function
Aug 31, 2018 | Televison & Video
Kenmore coldspot not working properly after power outage
I am glad you made it thru the storm OK. I am in New Orleans and I am no stranger to what you guys went thru.
First, are you sure the compressor is running?
Post back to me.
Nov 02, 2012 | Refrigerators
The tv shows it turned on the green light is on, but there is no picture, when we went to bed last night it was working and when we woke up to turn on this is what happened
First check all the cables make sure they are plugged in Second make sure the input is set to tv or whatever input goes to your cable box
Feb 28, 2011 | Maxent Televison & Video
My monitor doesn't display anything, though it's receiving input from the CPU. I know that input is being received because the monitor status light is green, and times out (turns orange).
Same thing happened to me! Went to bed last night, everything was fine. Woke up today, orange light came on, no display, slight flickering seen, but that's it. Cables and cords are fine, tried unplugging and plugging it back in, NOTHING. Totally dead. I'm guess off to buy a new one today. Typical made-in-China JUNK.
Jan 03, 2010 | Acer AL1916W 19" LCD Monitor
How to replace power supply?
Toshiba model 57H93 worked perfectly last night. Turned off and went to bed. Turned on this morning, and nothing, it won't turn on. Checked all cords and cables, pushed reset button, and still won't turn on. What could cause this to happen?
Dec 14, 2009 | Toshiba 57H93 57" Rear Projection HDTV
Lost entire picture, sound and everything else OK
check the invertor boards resistors they power the back lights
also check for any capactors that have blown (raised tops) they look little bateries
Dec 12, 2009 | Element Electronics FLX3220F 32 in. LCD TV
My coffee pot died during the night
It had nothing to do with the coffee pot. I blew a breaker!
Aug 30, 2009 | GE Coffee Makers & Espresso Machines
Power went off last night and our phone stopped working
I had power outage last night now corder at&t 1855 led's keep flashing keeps telling me about power outage before every new message. How do I get rid of the flashing?
Apr 14, 2007 | Uniden CLX485 Cordless Phone
Televison & Video Logo
395 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
