Question about Shimano Ultegra CS-6700
I have an Ultegra RD6600 and CS5600 (12/25T) on my new Look bike. I'd like to put a CS6700 11/28T on it for better gearing for the steep climbs around here. Apparently the CS6700 11/28T required the RD6700. Do I also have to get a new ST7900 or ST 6700 instead of my ST6600?? The drivetrain charts are not clear about this (is ST7900 fully compatible with the ST6600? It's in the same box in the diagrams) Thanks for a definitive answer about this.
    Guru:
  • 347 Answers
Derailleurs -
The RD6600 will only handle a 27T gear so no to 11/28.
The RD6700 will handle the 28T gear so yes to 11/28
Shiftlever -
The ST6600 will work fine with the RD6700.
The ST7900 should only be used with other 7900 products (Dura-ace for Dura-ace) it will work but not as nice.
There is no need to change your shiftlevers.
The ST7900 is almost fully compatible, in that any Shimano Derailleur will work with any Shimano Shift lever, However the ST7900 has a slightly different shifting pattern and the shift levers should only be used with other 7900 products to get the best performance.
Side note - If you are using standard cranks now, you could keep your shifting in tact and change your cranks to compacts and get lower gear ratios than moving to the 28T for a similar price to Rear derailleur/ cassette and chain plus labor. This is a common change in my shop.
Posted on Apr 07, 2011
Can anyone tell me what this is. It is on a 2006 Chevy impala. It has something to do with shifting the car. Ithink it makes the box around my gear indicator work. I.E. P R [N] D 1 2
P=park gear position (no gear selected)
R=reverse gear position
N=neutral gear position (no gear selected)
D=top gear
2=fixed highest gear (used for speed when climbing an average incline and to control speed on decent)
1=fixed lowest gear (used for climbing steep incline or descending slowly)
Note-: Never engage Reverse gear when traveling forwards and never put into Park when moving forward or backwards, also towing most autos should be done no more than 10mph, fast towing can damage the gearbox, also make sure gear is in Neutral when towing.
Apr 25, 2016 | Cars & Trucks
Adjust cycle gears
Chain shifter or derailleur is improperly adjusted. Take to nearest bike shop for service
Aug 05, 2014 | Shimano Ultegra BB-6500
Do I have to buy new bikes to get higher range of gears?
Actually no! you can visit your bike shop and ask them for higher range. What they do is change the front wheel ring in order to give you higher range.
Jan 17, 2013 | Cycling
Gear slips after going up hill
Possibly TPS starting to fail. but first have oil level & quality checked
Jun 22, 2012 | 2007 Volkswagen New Beetle Coupe
Hi Everyone! I have a Shimano 5603 Hollowtech 2 triple chainring.......(10 Speed) I want to add a Utlegra 6600 front derailleur and Ultegra 6600 rear derailleur. Also 10 speed cassette, Ultegra...
No -
If you are going to use the front triple crankset, then you need to use the 6603 components. These are for Triple set-ups.
If you intend to keep your bike a triple, then everything in the drivetrain must be the triple designation, hence the XX03.
If you want to change the crankset to a compact, then you can use the 6600 (double) equipment, but you will need to change the left (front shifter) to a double as well. The compact crankset, will give you virtually the same range as the triple and be much lighter and shift better.
The cassette: You can use any 10 spd cassette from Shimano or SRAM as long as the rear cog is no larger than 27. if you want to use a larger cog like a 28, then you will have to use the 6700 group, assuming yoiu want to stay with shimano ultegra.
Final Note: Since you are chainging everything, you may want to consider the SRAM Apex group, this gives you more gear ratio than the Ultegra, is slightly less expensive and around the same weight. Great alternative to Triple bikes.
Parts you will need to convert:
Rear Derailleur
Front Derailleur (if changing to compact double or Apex)
Chain
Shifter set (if Apex)
Crankset (if Apex or compact shimano)
Bottom Bracket (if Apex)
The biggest thing is that Shifters and rear derailleur must be from the same company (shimano, SRAM, etc.) after that just make sure that yoiu use 10spd with 10spd, 9 with 9, and so on. Everything else can mix and match.
Dec 18, 2010 | Shimano Ultegra Triple Front Derailleur Fd...
I'm a 60 year old female. Only just learning to ride a bike. Husband been riding for 60 years and doesn't seem to understand my problem! I have a bike with SI-6KT0B gears. I understand the principles of...
Congratulations on learning to ride the bike. I use the rear gears mainly i.e. the gears on the right hand side. Each rear gear makes a little difference so it makes it a little easier to go uphill. (When the chain is on the back smallest cog wheel it's hardest to pedal and easiest on the largest. The reverse is true of the front cog wheels) If you come to a very steep hill you should use the front gears i.e. the lever on the left hand side. This makes a bigger difference to the effort needed to climb a hill. When you have put the front gear into the easiest position, (on the smallest cog wheel) you can still use your rear gears to make it easier still. For going on flat ground or downhill most people keep both sets of gears on the hardest gear. (The front gears on the largest cog wheel and the rear one on the smallest) However there's no rule that says you have to. Use the one that feels you're using just enough energy to turn the pedals and in time you won't have to even think about the gears. I hope this helps.
Aug 09, 2010 | Cycling
What kind of power should I expect to have, I have no point of reference, as I have never owned a diesel rig before, seems to have lackluster power on the hills, I have to really put my foot into it to...
diesel engines have loads of pulling power(towing/loaded)but you need to use the gears to keep the revs at peak torque.1st is a crawler gear(very low ratio).put car in 3rd going down steep hills saves the gearbox overheating.....
Jun 15, 2010 | 1994 GMC Suburban
Ultegra 6703 skipping shifts:
You might try contacting these guys if you haven't already thought of it:http://www.parktool.com/contactus.asp Hope this helps.
Nov 17, 2009 | Mountain Bike Bmx Fit Gt Haro Chrome...
Ultegra Flight Deck shifter problem
My guess is the shift cable has slipped, only allowing you the top end of the rachet positions. Drop the shifter to the very lowest cog, make sure the cable is tight, and adjust the tension at the derailleur so that on the first single click it climbs one gear, and isn't noisy there. More tension 9 winding the barel out ) causes it to rise, less, to drop down. It should then hopefully select all the gears, unless the upper stop, the L screw is set too low. This screw stops the derailleur hitting the spokes and going past 1st gear. That shouldn't ever change though.
Jun 01, 2009 | Mountain Bike Bmx Fit Gt Haro Chrome...
Hesitation
shift your gear to the left one tap to go into drive 1 when climbing steep hills and it keeps you from hesitating .it works for me i have a 2009 caliber automatic and i climb alot of kentucky hills ,mine only hesitates on the really steep hills after i slow down and take off again but when i shift to d1 its fine
Jul 23, 2008 | 2009 Dodge Caliber
Shimano Ultegra CS-6700 Logo
401 people viewed this question
Top Shimano Cycling Experts
Michial Gueffroy
john h
Paul Bade
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
