Windows 2000 setup
To set up Windows 2000 on the selected item, press ENTER is the correct choice
  • 2 more comments
  • Ekse Aug 06, 2008
    after this the setup asks you to format with ntfs or fat32 Quick or fast, the last option is to leave filesystem as is.
    If it asks to delete the existing windows you can select diffrent folder or delete, it doesn't actually delete your files but if you want to be safe, select diffrent folder, Win for example.
    Comment by Ekse, posted on Aug 06, 2008
    Thats Quick or slow, select the last option. no changes.
  • Ekse Aug 06, 2008
    It is the To set up windows 2000 on the selected item, press enter.
    It is the C NTFS local disk 9223MB - Select this and press enter ones. then you should get new questions on the screen.
    Make sure you select NO CHANGE, LEAVE AS IS. Similiar to this direction you can also post the options to me and il point out what is the correct one.
    Thanks,
    Ekse
  • Alex Lee May 11, 2010
    Hi Ekse,
    I created another folder called temp1. Unfortunately many files were unable to be copied. I keep having to press the esc key to fully instal.
    It did not work. Did not boot to windows.
    Any suggestions
    thanks
    WINDOWS 2000 PROFESSIONAL SETUP
    · To set up Windows 2000 on the selected item, press ENTER
    · To create a partition in the unpartitioned space, press C
    · To delete the selected partition, press D
    The options:
    C: NTFS (Local Disk) 9223MB (2671 MB Free)
    Unpartitioned space 8 MB
    Which of the above must I select.
    Many thanks
  • 145 Answers
I need more to help you set 2000 on what
Posted on Dec 13, 2008
How do I set up the answering system on the Vtech?
Try this:
press [menu]
scroll to "Answering Sys"
press [select]
scroll to "Ans Sys Setup"
press [select]
--- ( begin the setup item list )---
==1== as you scroll to each item to be set up,
press [select] to address that item
scroll through that item's choices,
then press [select] to confirm the choice selection
(chirps) and returns to the setup item list
==2==scroll to the next item
==3==scroll to the next item
==4== etc.
when finished, press [OFF] a few times to back up to "Handset #"
Feb 22, 2016 | Vtech CS6629-3 Silver Cordless Phone DECT,...
I deleted the administrator my mistake now i cannot login to windows can I reset to the factory settings
hi, hope this helps,
1. Make sure the computer is turned off.
2. If any peripheral devices, except the optional external CD-ROM drive unit
(CE-CD05), are connected to your computer, disconnect them.
3. Turn on the computer.
4. When the message Press <F2> to enter SETUP appears, press F2. The
Setup Utility opens.
5. Insert the Product Recovery CD-ROM disk 1 into the CD-ROM drive.
6. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
7. In Boot Sequence of the Main menu, set CD-ROM Drive to the top of the list;
then, press ESC.
8. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice.
9. Read the message on the screen, and select the operating system which you
had selected for the first time you use the computer; then, press Enter.
You cannot change the operating system from the first choice.
10. Read the message on the screen, and select the way to recover your system;
then, press Enter.
11. Read the message and select Continue; then, press Enter.
12. Read the message and select Continue again; then, press Enter.
13. If you see the message asking you to insert the Product Recovery CD-ROM
disk 2, remove the disk 1 and insert the disk 2; then, press Enter.
14. If you see the message asking you to insert the Product Recovery CD-ROM
disk 3, remove the disk 2 and insert the disk 3; then, press Enter.
15. If you see the message The Operating System has been recovered
successfully, remove the Product Recovery CD-ROM disk 3. The system will
restart automatically.
16. When the message Press <F2> to enter SETUP appears, press F2. The
17. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
18. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice. The system restarts.
19. Set up Windows, following the instructions on the screen. When you finish
the setup, the recovery is completed.
Jun 02, 2011 | Sharp PC UM20 PC Notebook
Dvr will not record. i get the message, " hard drive full" is there a way to erase what is on the hard drive?
You can erase the contents of the drive or set the drive to overwrite when full. Erasing the drive is the equivalent of reformatting (you will not be able to recover the images easily).
To Erase/Format, enter the Menu system and select Hard Drive Setup (seventh line in the list). Press Enter, then go to HDD Format (fourth item in the list) and press Enter. Then enter your password (set up under System Setup) but the default password is 111111, if it is on. If you entered the correct password, the screen will flash HDD Formatted 3 times. Press Menu to exit the menu. (If the incorrect password was put in, Incorrect Password will flash.)
To overwrite, again go to Hard Drive Setup then select the first item, Drive Full. Press Enter to toggle Overwrite On or Off. You will be able to recover the images until they are overwritten.
I hope this helps.
Oct 13, 2010 | CSi Speco Speco Technologies DVR-4CF...
Fujifilm a230 change language to English (leaving
Press MENU/OK to display the menu. Use up/down to select SET. Press right to display the setup menu. Use left/right to select the wrench with the digit 2 next to it. Press down to enter the menu. The second item on that menu should be Language, so use up/down to select it, then press right to enter. One of the choices should be "English". Highlight it and press MENU/OK.
Jul 09, 2010 | FUJIFILM A170 Digital Camera
I want to install again the WINDOWS 2000 Professional and i can't do it because it shows a blue image and says that i've to put the win 2000 pro disk on the diskdrive and i put. when i go to the...
What is the boot order in the BIOS? Set that to 1=FDD 2=CD-ROM 3=HDD
While the PC is still on, put the Windows CD in the drive
Restart the PC, watch the screen for a prompt to boot from cd - press a key
The installation will start, you will need to choose where to install Windows
If you do not need to save any data, format the C: drive and install window there.
Follow the prompts the rest of the way through the installation.
You will need to enter the Windows License code at some point.
It is a good idea to change the regional settings to match your location and how you want the date and time formatted.
Most things should be detected and installed automatically, so you are safe to accept the defaults.
After about 45 minutes you will need to restart the PC and then you should be ready to enjoy Windows 2000.
Be sure to go to Windows Update and install all of the patches.
Good Luck and let me know how it goes.
~ Spoem
Mar 24, 2009 | Toshiba Portege 3110CT Notebook
After booting process done. Screen goes blank and Keyboard not working only Mouse cursor is dispaly and working on the blank screen in My acer Laptop.
Try booting the system to Safe mode.
To boot to safe mode:
Restart the computer. As soon as the BIOS has finished loading, F8 key on your keyboard. When Windows Options menu appears, scroll to select the Safe mode menu item, and then press Enter.
Select "Last known good configuration" then press Enter.
If that doesn't work reboot again and keep tapping on F8 to Safe Mode and instead of selecting "last known good configuration" select "Repair Your Computer"
Or you can try this:
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
  1. Place your Windows XP set up disk in your CD drive.
  2. Turn off your computer and change your BOOT order to boot from CDs first.
  3. Turn your computer back on.
  4. Press any key on your keyboard when it asks you to.
  5. Press enter when you see a blue screen, one of the options should say, "To setup Windows XP now, press ENTER.".
  6. Press enter to start the windows set up.
  7. Accept the Licence and Agreement and confirm that the setup is searching for current versions on XP.
  8. Press "R" when the set up has found your current version of XP.
  9. Notice that the Set up is deleting all your windows xp files and replacing them. (This will not cause loss of data)
Jan 11, 2009 | Acer Aspire 5610 Notebook
How do I set the time on my Pioneer RT500?
Hi!
Please follow the instructions given below... =)
Setting the clock
The clock is set to the correct time automatically, but it
can also be set manually. The clock can be set for
daylight saving time and time zone.
Preparation:
• Turn ON the TV and set it to the video input mode.
• Select “CLOCK” from “SYSTEM SETUP”. For the
procedure, see steps 1 to 3 in “Using the SETUP
MENU”
1 Press SETUP while the DVD and video tape is
stopped.
The SETUP MENU screen will appear.
TIMER REC SET
SYSTEM SETUP
AV SETUP
REC SETUP
CH SETUP
OTHER
SETUP MENU
ENTER/
SELECT ENTER RETURN BACK SETUP END
SELECT
2 Press  or  to select the desired menu and
press ENTER.
The submenu screen of the selected menu will appear.
TIMER REC SET
SYSTEM SETUP
AV SETUP
REC SETUP
CH SETUP
OTHER
LANGUAGE
PARENTAL
CLOCK
DISC SETUP
OTHER
SETUP MENU
3 Press  or  to select the desired submenu and
press ENTER.
The screen for the selected submenu will appear.
CLOCK (manually)
You can manually set the date, year and present time
with the remote control.
Ex.: Setting the clock to “10:20AM” October, 30th, 2004.
1 Select “CLOCK” and press ENTER.
01/01/04 12:00AM
2 Select the desired items using  or  (month,
date, year, hour, minute and AM/PM) then press
ENTER.
3 Press  or  to set the value of the selected
item.
• For the minutes, press  or  once to set the time
minute by minute, or hold down either of buttons
for several seconds to set the time in 10-minute
intervals.
10/30/04 10:200AM
4 Repeat steps 2 and 3 to set the date, year and
present time, and press ENTER. The SETUP MENU
will close.
This completes clock time setting.
AUTO CLOCK
You can automatically set the clock by turning “ON” the
AUTO CLOCK function.
When you want to set the auto clock function to “OFF”,
select “AUTO CLOCK”, press ENTER and select “OFF”
from the list.
Auto clock setting
Preparation:
You must connect the antenna or cable before connecting
the AC cord to the power source.
Wait 30 minutes with the power turned off, after the
antenna or cable is connected, for the auto clock
feature to activate.
After the clock is set automatically, you may have to set
the time zone and daylight saving time. (See page 26.)
Press STANDBY/ON to turn on the DVD/VCR after the
auto clock operation completed.
• When shipped from the factory, the “AUTO CLOCK”
option is set to “ON” position.
• If you turn the DVD/VCR on during auto clock
setting, the clock is not set.
• After a power failure or disconnection of the power
plug, the clock setting will be lost. In this case, wait
30 minutes before turning the DVD/VCR on.
• With cable box connection, if the auto clock setting
is unsuccessful, select the PBS channel carrying
the XDS information, then turn the DVD/VCR off.
After 30 minutes, turn the DVD/VCR on.
• If the clock is not set automatically, set the clock
manually.
STANDARD TIME (Time zone)
In the rare event that you live within the broadcast range
of two stations in two different time zones, the DVD/VCR
may recognize the wrong station for the auto clock set.
To correct the situation:
Select “STANDARD TIME” and select the time zone from
the list below.
Selectable time zones and correction times
ATLANTIC: GMT – 4 hours
(GMT: Greenwich Mean Time)
EASTERN: GMT – 5 hours
CENTRAL: GMT – 6 hours
MOUNTAIN: GMT – 7 hours
PACIFIC: GMT – 8 hours
ALASKA: GMT – 9 hours
HAWAII: GMT – 10 hours
AUTOMATIC: AUTO SET
Note
• When shipped from the factory, the “TIME ZONE” is
set to “AUTOMATIC”.
• After making the auto clock setting, in some cases
the clock may display another time zone. You can
correct the clock by selecting your time zone
setting above.
• When the clock is not set or you set the clock
manually, the time zone setting is not available.
DAYLIGHT SAVING TIME
You can set the clock to daylight saving time automatically
or manually.
To select daylight saving time, select “DAYLIGHT
SAVING TIME” and select “ON”, while to cancel the
daylight saving time, select “OFF”.
ON: For manual setting (forward 1 hour)
OFF: For manual setting (back 1 hour)
AUTOMATIC: For automatic setting (read XDS in
the signal)
Note
• When you want to set daylight saving time, on the
first Sunday in April you set it to “ON”, and on the
last Sunday in October you set it to “OFF”.
• When shipped from the factory, the “DAYLIGHT
SAVING TIME” option is set to “AUTOMATIC”.
• When the clock is not set, the daylight saving time
• When there is no daylight saving time in your area,
always select “OFF”.
Jan 03, 2009 | Pioneer DVR-RT500 DVD Recorder/VCR
Picture size
This setup can be found in your manual that came with the tv on page 38
you may also download it at the following address for free.
http://media.onecall.com/Image_Products/Sharp/LC_GD6UManual.pdf
Digital Setup
This setting allows you to set the image of Digital
broadcasting.
Video Setup
You can adjust the settings for Digital image.
Screen Size
Set the format of image of Digital broadcasting.
1 Press MENU and the MENU screen displays.
2 Press < > to select “Digital Setup”.
3 Press ^ v to select “Video Setup”, and then
press ENTER.
4 Press ^ v to select “Screen Size”, and then
press ENTER.
Press < > to select “Manual” or “Auto”.
Manual is default auto is optional
since all tv channels do not broadcast in the same definition auto would be recommended
Selected item Description
Manual
Broadcasts in formats other than
480i will be converted and
displayed in the 1080i format.
With 480i broadcasts you can
change the screen size to the
size of your choice.
Auto.
All broadcasts will be converted
and displayed in the 1080i
format.
Nov 27, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
TV:G
1 Press SETUP and the Setup menu will appear.
2 Use ^/v to select the OTHERS item.
3 While the OTHERS item is selected, press > to
move to the second level.
4 Use ^/v to select the TVGuardian item.
5 Press B to move to the third level.
6 Press SELECT/ENTER.
TVGuardian menu appears.
7 Press< > to select On of the TVG mode.
8 Use ^/v/</> to choose a desired setting.
9 Press SELECT/ENTER to confirm your setting,
then press SETUP to exit the menu
Nov 16, 2007 | Sanyo DVW-7000 DVD Player/VCR
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
