Question about Vulcan Heating & Cooling
We cannot get our vulcan gas fire to ignite! The pilot is on, it is set to manual, turning the control knob to 1, 2 or max does not result in gas flow or heating !
    Brigadier General:
  • 4,736 Answers
Has the Gas Control Knob been turned from the Pilot position to the ON position? If not, it won't light the burners.
Posted on Apr 07, 2011
Pilot light blew out by a fan..I turned the control off..How do I Ignite Please
First locate where to light pilot. You can do this by following thin aluminum colored tubing from control valve to inside heater.In general on top of your gas control valve is a knob. Turn indicator of this knob to pilot and depress knob. This will start gas flow to pilot at end of thin tube. Hold this knob in the depressed position and light pilot. DO NOT release knob for 30 -45 seconds. Then release knob and pilot will remain lit. Then turn knob to on position. If pilot will not stay lit you may need a new thermo coupler, which senses heat from flame to keep pilot gas flow open.
Good luck
Mar 10, 2015 | Heating & Cooling
My wall mount propane heater sputters and won't fire up when I turn the knob to on
this quote is taken from site below under Problem Identification.
If the burner sputters on ignition or takes more time to ignite, there is definitely a blockage of the pilot orifice by dirt and dust. Set the pilot at a higher level and clean the orifice along with the burner ports.
Read more at Buzzle: http://www.buzzle.com/articles/how-to-repair-a-gas-furnace.html
Jan 09, 2015 | Heating & Cooling
American range fryer will not light...the knob you turn to light the pilot light will not turn.you can push it in but won't turn.please help
From the Owners' manual:
LIGHTING
1. Before attempting to light this appliance, the door if so equipped, shall be open.
2. Turn the appliance manual gas shut-off valve to the OFF position.
3. Turn the combination gas control knob to the OFF position.
4. Turn the thermostat control to the OFF position.
5. Wait 5 minutes.
6. Turn the appliance manual gas shut-off valve to the ON position.
7. Turn the combination gas control knob to the PILOT position.
8. Light the pilot with a match while depressing and holding the combination gas control knob until the pilot remains
lit upon releasing the gas control knob.
9. Turn the combination gas control knob to the ON position.
10. Turn the thermostat control knob to the desired temperature to turn burners ON.
11. Ensure that the door is closed during operation.
12. For complete shut-down, repeat steps 2, 3, and 4.
It won't turn any further until the pilot is lit and stays lit.
Jun 14, 2014 | Kitchen Appliances - Others
Need to light pilot light
You need to turn the knob on the gas valve (inside the heater) to the "pilot" position. Then, while holding a flame over the pilot assembly push down on the knob.
Gas should come out of the pilot and ignite. Continue holding the knob down for 10-15 seconds. Release the knob and the pilot should stay lit. If not the pilot generator may need to be replaced.
Turn the knob to the "on" position, close the heater and turn the heater on and turn the thermostat to hot. The heater should fire. If it does not fire and the pilot goes out, that may also indicate a pilot generator problem.
Nov 20, 2013 | Teledyne Laars Pool & Spa
I have a Valor Eminence Gas Fire which does not ignite when i try to put it on. Pilot light seems to be going but no gas. Can anyone help? I habe dusted the interior as per instructions but to no succes....
Be sure that after lighting the Pilot, that you turn the gas control knob to ON. Just lighting the pilot will not turn the burners ON. Once the control knob is turned to ON, you can turn the burners ON.
Hope this helped you and thanks for choosing FixYa.
Sep 16, 2011 | Heating & Cooling
Can't locate pilot on vulcan lg300
TO LIGHT THE PILOT
1.Open the door. 2. Turn the thermostat OFF The thermostat is located behind the door. 3. Push the gas control valve knob and turn to OFF. Wait 5 minutes for unburned gas to vent. 4. Push and turn gas control valve knob to the "L" in PILOT. 5. While still holding the knob in, light the pilot with a lit flame. Continue to depress the knob until pilot remains lit when knob is released. If the pilot does not remain lit, repeat step 3 through 5. 6. Depress and turn gas control knob to ON
Jun 02, 2011 | Frymaster FPEL217 Deep Fryer
Vulcan express gas continuous flow/model # 230010N0/serial # 66669/ Date 19-08-98. I can hear and smell gas when trying to ignite the pilot light and the igniter spark, "sparks", but pilot light...
VULCAN water heater continnous model number 23001ono. im looking for a brass nut that sits on with a very small hole, with a number on it (25)
Mar 10, 2011 | Heating & Cooling
Lighting pilot light
Pilot assembly is located inside the bottom compartment, between the the two middle burners while the gas valve is located under the burner manifold. Make sure that the gas line where the unit is connected is open. You need to turn the gas valve knob to "Pilot" position and depress it (to allow the gas to flow on pilot) then light the pilot assembly using a lighter with extended nozzle ( burner igniter). Once the flame is present at the pilot assembly, wait for about 15 seconds (allowing thermopile to heat up) the gradually release the gas valve knob. If the pilot flame is stable, turn the gas valve knob to "ON" position and set the thermostat to desired temperature setting. This will ignite the burners and heat up the oil to set temperature. Just remember, do not do this if there is no oil on fry tank.
Feb 18, 2011 | Pitco Frialator 35CS Deep Fryer
No flow of gas to fire after pilot light is lit and turned on.
i have had a legend vantage slide control gas fire for about 5 years.this problem is i believe a blocked oxy get which is a failsafe device to prevent a gas leak.can be remedied easily by a gas safe engineer.
Jan 07, 2010 | Vantage Televison & Video
Lighting the pilot light
The steps involved can vary slightly depending on your furnace model and pilot valve type, so if possible try and find the instructions inside the furnace door cover or in the instruction manual. This is for a gas fired furnace, but applies to any gas-fueled appliance including water heater. Two of the most common types of pilot valve body assemblies either have a red reset button and a gas valve or no reset button and a valve knob that can be depressed. But whichever type you've got, if you have an older model furnace with a standing pilot (flame is lit all the time) then this is the basic procedure.
  • Turn you thermostat to 80 degrees or to a setting that will demand heat. Make sure the thermostat is in "Heat" mode.
  • Go to the furnace and find the pilot valve. The pilot valve body is a box shaped device into which the main gas line will run and is located near the gas burners. It will usually have a gas **** or valve knob that reads "On, "Pilot" and "Off." Locate this gas **** or knob.
  • Turn the knob or gas **** to the "Off" position and wait about 3 minutes for any residual gas to clear away.
  • Find the pilot. It's located near the gas burner tube assembly in the furnace.
  • Get your match or lighter ready. Sometimes the pilot is hard to reach. If possible, try and use a long fireplace match when you light it. If you don't have a fireplace match then a butane BBQ grill lighter works well too. If you don't have that, then you can fasten a match to the end of a stick when you light the pilot
  • If you have a pilot with a red Reset button, turn the gas valve from "Off," to "Pilot."
  • If you have a pilot with no red button, turn the knob from "Off" to "Pilot."
  • Place the lit match or ignited lighter tip at the pilot and depress and hold the button or depress the knob as appropriate. Depress the button or knob for about 30 seconds. This maintains gas flow to the pilot until the thermocouple gets hot enough to open the main gas valve.
  • Once the pilot stays lit, slowly release the button or knob and turn the gas **** or knob from the "Pilot" position to the "On" position. This will ignite the burners and keep the flow of gas supplied as required for the burners as called for by the thermostat.
  • If the burners fail to ignite then it may be because the thermocouple did not get hot enough to open the gas valve. Wait a few minutes and then repeat the above procedure. This time hold the red reset button or depress the knob for about 45-60 seconds.
  • Once the main furnace burners ignite, adjust the thermostat to the desired setting.
  • If you've followed the previous steps on lighting the pilot and it still does not light after, or will not stay lit, then you probably have a problem with the thermocouple or an adjustment needs to be made to the pilot. You'll need a furnace service technician to replace or repair these parts. You may find that the pilot lights, but it is an anemic looking flame. That's a different problem we'll look at in the next section.
  • If the pilot lights but the flame is a weak yellow flame, it will not get hot enough to heat the thermocouple to its set point allowing the gas valve to open.
    A natural gas flame should be a bright blue with the tip of the flame having just a tinge of yellow. A propane flame should have a bluish green flame with a tinge of yellow at the tip. The flame should be strong enough to hit the thermocouple tip about 1/2 inch from the tip end. If the flame is weak or shaky looking, check to see that a breeze or draft is not blowing on it. Adjusting the Flame
    There is usually a small screw on the pilot valve body that will adjust the flame. You may have to refer to the manufacturer's instructions to find the screw. Turn the screw as needed to adjust the flame throw. Yellow Flame
    A yellow flame is caused by lack of air and incomplete combustion. It can be caused by a dirty pilot tube tip. Split Flame
    This is caused by dirt in the pilot tube. Take a needle or small nail and gently clean the tube. Flickering or Wavering Flame
    A flame that flickers is usually caused by a draft.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 18, 2009 | Water Heaters
Heating & Cooling Logo
735 people viewed this question
Top Vulcan Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Vulcan Heating and Cooling Expert? Answer questions, earn points and help others
