Question about Nokia E66 Smartphone
Nokia e66power provlem? - Nokia E66 Smartphone
My nokia headphone (car) provlem soliution
Can you describe the problem? It's hard to provide a solution without knowing the problem.
Jul 09, 2013 | Cell Phones
What's yourSOUN DRIVE PROVLEM problem?
Try installing the latest audio driver.
You can download the audio and device drivers from the NEC WEB site.Please click on this link and select your model computer/notebook and theWindows drivers you require :-.www.nec.com/global/support/downloads/index.html
Jun 06, 2012 | NEC Versa LXi Notebook
Country lock provlem
you can open your country lock for your phone through codes.you can get the codes from Classicunlocking.com
May 05, 2012 | Nokia 6300 Cell Phone
Nokia n97 charging provlem
Please check the charger and the battery seperately on another phone as this is the best way to confirm if either is faulty.
If the battery was not initially charged properly the battery could be weak and needs to be confirmed.
Dec 29, 2011 | iPhone Apps
I Have buy C5-03 and the main problem of this set that "I CANNOT SEND ,RECEIVE AND DELETE MSGS, MUSIC,DATA"
Try to format the phone memory, but this will erase all your data, so, first save the info you need- contacts, photo, etc.
1) Factory defaults-
Type *#7780# on your standby screen.
This will reset all your setting to default factory settings. User data wont be affected. (Default Lock code is 12345)
2) Soft reset-
Type *#7370#
This will reset the phone as well delete user data. Use when want to format the phone.
I think it may Helpful to you
There is a rate option "Was this helpful?" Yes or No.
If you are helped you can rate, that is your choice
Aug 05, 2011 | Nokia C5 Cell Phone
Not starting n72
it is software provlem so flash ur cell phone.
Jun 21, 2009 | Nokia N72 Cellular Phone
Je vue entrer code restriction ;nokia 5310 xpessmusic
Thank You For Choosing FixYa!!! I didnt understant your language, I guess its about phone unlock.
Your service provider will in most cases unlock the phone for you. contact them first.  If they wont unlock it for you, get it unlocked at a website like this http://globalunlock.com/phones/home
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!! PREM
Mar 05, 2009 | Nokia 5310 Cellular Phone
Downloading to computer from MVX250i Mini DV Digital
found proper port at front of camera which solved my provlem. thanks for yourinterest.
Jun 23, 2008 | Canon MVX250I Mini DV Digital Camcorder
Nokia E66 Smartphone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
