I need a wiring diagram for this unit - Heating & Cooling
    Genius:
  • 1,622 Answers
Hi, if you need a wired diagram for an air condition,you will need to give a specific information about the air condition.Like what type and manufacturers of air condition and model of the air conditioner , so we can be able to help you out...
Hope you understand..Thanks awaits you.
Posted on Apr 07, 2011
Need wiring diagram for Emerson MW8992RD microwave.
Try google make model images wire diagram. you may find a diagram or perhaps images of.
Apr 09, 2015 | Emerson Heating & Cooling
Hello i want to conect a trane condensator 2twb0036a1000ba to a trane evaporator mww536k10raa i need a wiring diagram
Your wiring concerns may be more with the thermostat wiring connections than the condensor connections. if you look inside the cover of the evaporator unit (usually called air handler) there should be a wiring diagram glued to the panel cover. This diagram will show all 3 units (stat,cndsr, airhndlr) and the wiring needed between them. Trane and Lennox are notorious for having the most wiring between components. You also need to be sure the stat is the correct type for the system (i assume this is a heat pump system) and there can be as many as 9 wires from stat to system and 6 wires from inside to outside units. Also, the stat will have a wiring diagram with it that shows most typical system wiring including the wiring between in and out units. Your best bet (if you have no diagram on the unit or with the stat) is to call trane and have their tech division fax a diagram to you. Goodluck,Macgivor
Jan 27, 2010 | Heating & Cooling
No heat need a wireing diagram 1997 package unit
impossible to get wiring diagram without model or manufacturer
Nov 21, 2009 | Heating & Cooling
Need wiring diagram for Hayward dual Super 2 speed pump. Old unit had 3 wires and new unit has 5 wires.
You need 4 wires to wire the 2 speed pump. You will also need a 2 speed time clock.. Tightwatt or intermatic. The wiring diagram is on the motor.
Aug 29, 2009 | Hayward 1.5hp 230v 2 Speed Uprated Super...
I order a new burn switch, i forgot the wire set up. i need the wiring diagram
look on and inside the unit there should be a schematic diagram for the unit that will show you the wiring diagram
Jul 28, 2009 | Kitchen Ranges
Need a wiring diagram for mastercool evap 2 stage unit
I have the wiring diagram in the cooler. I can photograph and send it to you. Do you still need it?
May 12, 2009 | Heating & Cooling
Have a whirlpool MH3184XPS-3 and need a shematic wiring diagram
Found a "schematic " diagram of electrical lay out and repaired the associated problem of being mis wired.
May 01, 2009 | Whirlpool MH3184XP Microwave Oven
Panasonic cs-pw9gke i need wiring diagram
Split A/C-Cold:
You need four wires(two #10 and two #12) to the outdoor unit, leaving you house, and three wires(#10) coming from the breaker to tye indoor unit inside your house.
Split A/C-Cold and Hot:
You need five wires(two #10 and three #12) to the outdoor unit, leaving your house, and thee wires(#10) coming from the breaker to your indoor unit inside your house.
This ypical arrangment(all of them use three wires fro the breaker), yet there are other units which may require 6-7 wires connected to the the outdoor unit depends on the added features to the unit.
Regards,
Gulftecheng
Dec 05, 2008 | GE Quiet-Aire Ductless Split System Air...
Wiring diagram
i need a air conditioner wiring diagram
Apr 25, 2008 | Intertherm P3RC-030K Air Conditioner
Heating & Cooling Logo
74 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
