Cant we use only black cratridge to print B&W page.I m getting error that replace color cartridge.and i dont need to use color cratridge.
  • 75 Answers
Yes you can. which printer do you have???
PLEASE RATE THIS ANSWER, IF YOU GET ANY HELP FROM THIS ANSWER OR LIKE THE ANSWER
Posted on Apr 07, 2011
Installed new cartridges - prints color not black
Hi Colleen,
Try this > open a document (from the computer) and select print from the menu,
- In the print screen window select 'properties' Or 'Preferences' or 'Properties'
- In the next window click 'maintenance'
- In the next window there will be many options to clean, align, nozzle check etc etc... , there click 'Ink cartridge settings'.
- A small windows opens, there select black only. See the image
- try printing, if it fails to print, just return the crtridge to the shop and get a geniune branded one. (dont forget to change the 'inak cratridge settings to normal to 'both black and color')
Hope this help, if you are not able to fix it still, then better come to chat http://www.fixya.com/marketplace/servicepage.aspx?srvid=17981 , thanks!
Oct 22, 2011 | HP Photosmart C6380 All-In-One InkJet...
Error code 1102 comes up on printer every time i try to print
Error 1102
  1. Remove the print cartridges, and close the cartridge carrier lids.
  2. Disconnect the power cord from the electrical outlet.
  3. Reconnect the power cord to the electrical outlet.
  4. If the button_power_0.jpg button is not lit, press button_power_0.jpg.
  5. Reinsert the print cartridges.
If the error does not reappear, the problem has been corrected.
If the problem reappears, one of the cartridges is not working properly. Continue with the following procedure to determine which cartridge is not working properly.
  5. Reinsert the black (or photo) print cartridge.
  6. If the error:
    • Reappears, replace the black (or photo) print cartridge with a new one.
    • Does not reappear, reinsert the color print cartridge.
  7. If the error reappears, replace the color print cartridge with a new one.
I coudn't find your printer model. This is a common solution for Error 1102.
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 27, 2011 | Office Equipment & Supplies
The printing speed slowed to a snail pace. I pressed Setup, 2, and then 6 to print a self-test report. I got a a "cartridge error" message. Then I removed both cartridges and cleaned them. Still...
This is caused by the failure of one of your cartridges. Remove the black cartridge and print a test page. Does the printer print at normal speed? Is so the black cartridge was the issue and should be replaced. If not then put the black cartridge back in and remove the color cartridge and print test page. If the printer now prints normal speed the color cartridge was at fault and needs to be replaced.
please vote for better sharing.. thank you and good luck
Nov 24, 2010 | HP Officejet 5610 All-In-One InkJet...
Printer will not print. New black ink cartridge. Color ink is almost gone. Help.
Printers that execute high quality images cannot (actually will not) allow printing when the other printer cartridges are almost gone or gone. This is a built in defense against the printer heads drying out and much servicing and expense.
You simply do not own a printer of any kind and allow the color cartridges or black cratridges to run out (or even get close) without having th replacement cartridge at hand for immediate installation.
This is how the printer manufacturer protects itself from costly warranty repairs and lawsuits.
Go immediately and buy the color ink cartridge and install it.
Black is the presence of all colors
White is the absence of all color
Your printer must draw in tiny increments from the color certridges to keep the heads functioning when you predominantly use black printed documents.
Science strikes again.
For God's sake, please do NOT leave me 2 thumbs up and trash my rating incrememntally because you aren't happy about this.
Regards,
TheSelkie
Sep 30, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
I was printing several pages & it just stopped working. the ink button & on button flash. Changed the ink cartridges but still get the same blinking with no printing. Turned both the computer...
Press the Ink Cartridge Replacement button and check the flash pattern of the control panel lights:
ERROR and POWER lights flash at the same speed = replace black cartridge
ERROR light flashes twice as fast as the POWER light = replace color cartridge
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
Jun 04, 2010 | Epson Stylus Photo 1280 InkJet Printer
Lexmark Prnter won't recognise color when cartridge refilled.
Hi there
Lexmark and Brother printers, dont have any thing I know of to reset the inks when you refill them your-self sorry.
Pineworks
Mar 07, 2010 | Lexmark X5470 All-In-One InkJet Printer
Black is very bad,
bad means to poor
then check ink supply for black
check cartridge motor by removing black cartridge and inputing component test code 009-011 does it rotate black cratridge moter
similarly for dispense motor 009-031 for lower side gear
Feb 01, 2010 | Xerox DocuColor 12 Printer
Help with error 1401
To print without color ink go to START>control panel>PRINTERS & OTHER HARDWARES>PRINTERS & FAXES>Right click to your printer>PROPERTIES>MAINTAINANCE>INK CARTRIDGE SETTING>then select BLACK ONLY.
I think it fix your problem.
Nov 13, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
HP psc1210 not printing in Black
u better try this ,remove color catridge from the printer,switchoff n switch it again with black catridge only,the printer will give catridge error dont worry ,n try to print any black font document from the printer n see does it print black,n reply
thnx
Jan 28, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP Photosmart C3100 series
I just got off the HP help line.  After changing my black ink cartridge a test page was printing each time I turned the machine on.  This is very costly, in both time and ink as the cartridges themselves for this machine hold very little ink.  I tried to learn from HP tech how to turn off the test-print while keeping my color cartridge empty.  It turns out that you cant do it.  HP requires you to keep buying and using cartridges whether you need them or not.If you buy the color ink it will use it up in its testings.  And if you dont buy the color cartridge it will use up your black ink by printing the test each time you turn on the printer.  The printer was inexpensive sure, but I'm paying for it in wasted ink.
Dec 26, 2007 | HP Photosmart C3180 All-In-One InkJet...
Computers & Internet Logo
112 people viewed this question
David Payne
David Payne
