I have a problem with the cd/dvd burner of my laptop (ASUS A6000KM). Since 2 years I've been struggling with the damned TS-L632 (Toshiba-Samsung) recoder that coudn't burn any kind of disc.
2 days ago finally I decided to change my driver and I bought a LABEL-FLASH DVD Multi Recoder R DL. But, I can't understand why, my system considers it as a DVD-RAM instead of a normal and usual DVD/CD (RW) recorder; and obviously if I try to record a normal CD or/and a normal DVD the program (Nero) tells me that it cannot support this kind of disc. Ha! The driver cannot even read the music cd and cd-rom.
I'll be glad to receive whatever kind of suggestions and hints. Thank you in advance.
Regards Max
Comments:
Aug 17, 2008
- Hello Fixe_You Thank you very much for the suggestion. But now my problem is that I do not know at all how to flash my bios :-| Could you give me please some basic instructions and/or helpful web links where I can find the procedure? I would appreciate that a lot :-) Thanks again.
i guess the laptops and desktops that ve been maden by companies like acer and hp compaq asus they dont suppoet any other stange parts such as aan burner
there is a trick flash ur bios !!
when putting a cd or dvd into the driver it does nothing. it sounds as if it starts to work but then...
(More)
when putting a cd or dvd into the driver it does nothing. it sounds as if it starts to work but then stops and nothing happens. do i need a new driver?
we are trying to connect sdrw 08dis u to a hp mini 110-1116nr with windows 7 and installing the...
(More)
WE ARE TRYING TO CONNECT SDRW 08DIS U TO A HP MINI 110-1116NR WITH WINDOWS 7 AND INSTALLING THE SOFTWARE. IT WON'T READ A DVD. SO HOW COME?
