Question about Nokia 6030 Cellular Phone
Display connector is broked and right hand 2 track is broked
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 108 Answers
Goto google image serch and type 6030 display ways .ull get the track ways
Posted on Apr 07, 2011
How can I r/r broken USB connector?
depends on if you broke circuit board tracks you may be able to solder the connector back onto the copper tracks on the cct board. Without blowing up via electro static discharge
Sep 04, 2015 | Seagate Expansion 1 TB USB 2.0 Portable...
Tip
Lock and Track your Stolen Mobile Hand Set Through IMEI Number
Do you know your mobile’s IMEI number? Just press * # 0 6 # in your mobile hand set, IMEI number will be displayed in your mobile hand set.
Keep the IMEI number safely at other place. This IMEI number is unique number for each mobile hand set. In case your mobile hand set will get stolen, you can track or unlock your mobile hand set through IMEI number.
First track your mobile through IMIE number here www.trackimei.com and report theft or loss.
If your mobile hand set got stolen, you need to do following things.
1. Submit FIR for your mobile loss, give details of hand set model, color, IMEI number etc.
2. Ask your service provider to track the mobile phone, your mobile phone will be tracked only if the thief are using your mobile hand set with any sim card. If the thief is keeping your mobile switched off, your service provider can not track the mobile hand set location. You should not expect muck cooperation from service provider or police to locate your phone.
3. If you are unable to find your mobile number, insure that at least your mobile handset is locked. The thief can not use (misuse) your mobile with any sim card. You should ask mobile service provider to lock your mobile through IMEI number.
on Jul 13, 2010 | Cell Phones
Machine well not turn on it has f 70
NOTE: I do not recommend checking voltages unless you have experience and feel safe and confident in doing so, otherwise I recommend calling a service technician to diagnose and repair your washer.
QUICK TEST
  1. Lock the control by pressing and holding the cycle signal button.
  2. Press the Power button.
  3. If the lock light flashes when you press the power button it indicates the center interface was able to take the input and the Right hand User Interface received the DCV signal from the Center User Interface but since the display did not light. This indicates an issue with the Right hand user Interface.
NOTE: This is a quick test you can try to get to a quick resolution, but remember if the Lock Light does not blink once the power button is pressed you will need to follow the standard checks below.
  1. First try to put the washer into the Diagnostic Test Mode per the Tech Sheet by pressing any key except Stop/Cancel and the Control Lock for 2-5 seconds on and 2-5 seconds off 5 times as outlined on the tech sheet; at this point the Right Hand Interface should light up.
  2. IF the Right Hand Interface did not light up in Step 1 check for 5 VDC on the UIP3 wire connector coming off of the control board to the Right Hand Interface from (Pin 1 to Pin 2) and from (Pin 1 to Pin 3). If you do not have the 5 VDC then replace the Machine Control Board.
  3. IF the Right Hand Interface did light up then remove the J003 connector. This is the 9 pin connector that goes between the Right Hand Interface and Center Interface.
  4. Short across (Pin 7 to Pin 8) on the Right Hand Interface.
  5. IF the Right Hand Interface did light up then replace the Center Interface due to a failed "Power" key.
  6. IF the Right Hand Interface did not light up then check from (Pin 1 to Pin 7) and (Pin 1 to Pin 8) on the right hand interface at the J003 connector you should have between 1.2vdc to 1.5vdc.
  7. Also check for DC voltage on the J004 (10 Pin connector) on the Right Hand Interface from (Pin 1 to Pin 2) and from (Pin 1 to Pin 10. You should have between 1.5vdc to 5.5vdc.
  8. IF you do not have the DC voltage at either of the checks above replace the Right Hand Interface.
NOTE 1: The #1 Pin on both the J003 and the J004 is identified by the white wire. NOTE 2: The picture below is the J004 connector that goes from the Center Interface to the Right Hand Interface and the red arrows are pointing to the check points for the 4 to 5 VDC and the J003 connector.
Image 1 Image 2
Post back your findings and your model number.
Nov 02, 2012 | Kenmore Elite HE5t Washer
The sharp corousel microwave ( Model R-308 JW) was working . There was a small roach nest in the lighted digital display and the display was hardly to read . This was the only issue. After...
Look into the connector and see the point of contact which is visible of the metal contacts. Now the carbon tracks must be on the side of the metal contacts of the connector. In this case it is possible that while you pulled out the flexible stip cord there is damage on the strip , can be that the carbon tracks were damaged and so it does not contact. if so use a carbon track pen to line the tracks so as to contact.
Reversing the cord will not do any damage as there will not be any contact.
finally make sure that the PCB( printed circuit board) was washed with petrol and brushed properly and then DRIED before the unit was powered or else it can damage the processor.
Check the connection leads that were removed and make sure that it went to the correct postion.
Sometimes the touch pads refuse to work once it is disturbed as it might get damaged in the carbon tracks within.
Sep 21, 2011 | Microwave Ovens
How to remove door handle on 99 oldsmobile aurora
unscrew the 2 screws on the bottom of the inside panel, then unscrew the large phillips head right behind the interior handle and remove the plastic cover next, you need something stiff and wide and flat, like a large meal file with a t-shirt wrapped around it so it doesnt **** up the leather pry it UP and a little bit outward and it will pop off, I was going on the fly and broke the little brackets and I had to us 1minute gasket to seal them back on really well. the connectors come off by the little clips on the side, stick a flathead along he side of the connectors and they will click out, you will feel them slip loose. not the panel should come free from the coor. next you need to remove the flat metal cover that has 2 bolts in it, basically right in the middle with the right side bolt touching the lock mechanism as well. it will unbolt then slide the tabs down and out...easy. the door handle is held on by 2 bolts, youll have to squeeze your hands to the right of the metal slider for the window and over the metal bars for the lock. I got the left one with a wrench and the right one I had to stick my left hand where I mentioned and m right hand had the wrench. the handle will be free by then, and you can slide the left side out first. then gently pull the bottom of the handle housing out and to the left at the same time and it will pop out. un-screw the two bolts to remove the bars from the lock on the bottom and the top elbow comes off as one piece with the metal bar going downward.
and there you go buddy...I just had to fix my door handle and it reuied removing it, just did it today. took about 2 hours, but I had no idea what was doing and had to figure out the mechanism by myself...computer broke conveniently enough!
Jan 27, 2011 | 1999 Oldsmobile Aurora
The only button on the panel that will light up is the 4 hr delay nothing else happens
This type of diagnosis will require taking voltage readings at the control board with a meter to find the root cause of the failure. Please see the rest of the information provided & the images below for the accessing, testing & replacement instructions.
1). Put the washer into the Diagnostic Test Mode per the Tech Sheet. 2). Did the Right Hand Interface light up? 3). IF the Right Hand Interface did not light up in Step 2 check for 5 VDC on the UIP3 wire connector coming off of the control board to the Right Hand Interface from (Pin 1 to Pin 2) and from (Pin 1 to Pin 3). 4). IF you do not have the 5 VDC then remove the MI3 connector from the Machine Control board. IF the display lights; replace the Motor Control board. IF the display does not light; replace the Machine Control Board. 5). IF you do have the 5 VDC then replace the Right Hand User Interface. 6). IF the Right Hand Interface does light up. Lock the controls by pressing the control lock button for 3 seconds. 7). Once the control has been locked press the power pad. IF the control lock light blinks when the power button is pressed it tells us the power button is sending the output from being pressed to the right hand interface but the right hand interface is not responding and will need to be replaced. 8). IF the control lock light does not blink when the power button is pressed replace the center user interface.
Jan 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The bulb in my left headlight is burned out. How do I change it?
FIRST OF ALL YOU HAVE HALOGEN BULBS YOU NEED TO WEAR CLEAN DRY GLOVES ON HANDS WHEN HANDLING HALOGEN BULBS.OIL FROM HANDS WILL CAUSE THEM TO BURN OUT.OKAY TO REPLACE HEAD LIGHT BULB.OPEN HOOD AND PULL UP THE RELEASE LEVER AT THE BACK OF THE HEADLIGHT HOUSING.THE HEADLIGHT HOUSING SLIDES IN AND OUT OF THE BODY IN TRACKS.PULL THE HEADLIGHT HOUSING FAR ENOUGH FORWARD TO DISCONNECT THE ELECTRICAL CONNECTORS THEN SLIDE THE HEADLIGHT HOUSING AT THE WAY OUT.TO INSTALL THE HOUSING SLIDE IT BACK IN ALIGNING THE RIDGES ON EACH SIDE WITH THE TWO TRACKS IN THE BODY.WHEN THE HOUSING IS IN FAR ENOUGH REACH THROUGH FROM THE INSIDE THE ENGINE COMPARTMENT TO REATTACH THE ELECTRICAL CONNECTORS.
Aug 19, 2010 | 2000 Volkswagen Beetle
Lines on laptop
If the lines are like static black stains, then that is a faulty LCD panel, with a liquid crystal leak.
If the lines are colored , and come on when you turn on the laptop, that is a problem with LCD ribbon cable or connector, or a broken connector on motherboard or LCD display.
Either the LCD display, or the ribbon connector must be replaced.
To do that you need to take apart the laptop, the repair should be done by a technician.
Jan 22, 2009 | Compaq Presario M2000 Notebook
Backlight solution
replace the small ic on the bottom of the board . and there may even be a track cut. display connector right hand 1st point to bottom to the coil
Aug 01, 2007 | Nokia N70 Cellular Phone
Nokia 6030 Cellular Phone Logo
55 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
