Screen for the menu flashes on constantly while viewing also volume sometimes can't be controlled by remote or tv but other times goes up and down without touching anything
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 177 Answers
that problem because switch tack are dirty. Open your TV, pull out pcb than replace all switch or clean up them with WD40 or contact cleaner.
good luck.
Posted on Apr 07, 2011
FPA turned on and I have only a universal remote
In most ceases, you might have its original remote control to unlock it. Anyway, try this.
1.Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2.Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3.Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
4.Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
5.Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
If you wish to get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 21, 2013 | RCA TruFlat 27F520T 27" TV
TV volume increases by itself and doesn't decrease or respond to the remote control
Connect all A / V sources to the Home Theater Receiver then Video-Out from the receiver and totally mute) the TV.
Sep 30, 2008 | Soyo DYLT032D 32 in. LCD Television
Volume pegs to max. Turns itself on. Goes to menu. Intermittent
This is becoz your Internal Remote control response program chip needs to be replaced! You need it to get repaired at nearest service station. Or it may be due to Your keys pressed continously from remote control. Check both the causes! then decide. It will help you!
Dec 23, 2007 | RCA F38310 38" TV
Why does my 26 insignia do the following without touching the remote: volume up and down, changes channels and menu screen pops up
It could well be your remote control has a problem. Try removing the batteries from the remote control and see if the problem goes away, if it does, try new bateries on the remote controller, if that does not work you may have to get a new remote controller
Mar 24, 2010 | Insignia LCDTV26 26 in. Television
Menu keeps flashing remote control wont work, cant change channel or volume.when i hold down channel up andmess with remote sometimes it changes channel. channel down button is only one that doesnt change...
U have 2 situations:
1st U have a tv Key stucked or internal control board defective.
2nd U have a broken tv remote control.
Note: Check for stuck pressed keys on TV, if not send to repair shop, for checkup.
Nov 29, 2009 | Insignia IS-LCDTV32 32 in. Television
TV does note respond to remote. Volume and menu flashes on screen
interference from flourecent lights, maybe the front panel buttons are stuck.
Aug 30, 2009 | Philips 32PFL6704D 32 in. LCD TV
RCA HDTV MENU AND VOLUME CONTROL POPS ON AND OFF SCREEN.
My TV was doing the same thing. Someone told me to disconnect the front menu buttons and this worked for me. The board goes haywire. You have to take off the front black panel on the bottom first then the grey front panel where the controls are. Once you do this you will see where there is a plug from tv to the panel where the control buttons are. Just disconnect. You will only be able to use your remote for TV. Its a cheap and easy fix. Just lots of screws to get the panels off and on. Good luck!
Apr 09, 2009 | RCA HD52W58 52" TV
No Remote - Need to access Menu
We had the same problem - this worked for us:
1. Unplug TV
2. Press Channel up and Volume up at same time, while plugging TV back in (two person job - it will pull up a service screen)
3. Press Channel up and Chanel down at same time. (Access to menu screen)
4. Use Volume up and Volume down to switch between menu options. We finally found the EZ set up screen.
Somehow in the process we muted the TV and are now working on getting the sound back. :)
Good luck to you!
Apr 28, 2008 | Sharp 25N-M100 25" TV
HOW CAN I GET PROTECTED PROGRAM TV-PG OFF MY TV?
This problem is caused by your TV's V-chip setting.
To fix the problem:
Push the "Menu" button (on either the remote or the TV's fromt panel).
Use the "Channel Down" button to go to "V-CHIP SETUP"
Use the "Volume Up" button to select it.
In the V-chip setup screen, the rating that is selected by the user as viewable will allow that rating and only lower ratings to be viewed on that TV. (If TV-G) is selected, then any programs rated higher than TV-G will be blocked.
So, the easistway to get rid of any blocking is to set the rating to TV-MA (mature), and then any and all programs will be viewable on that set. Select "TV-MA" by hitting the "Volume Up" button after you have scrolled down to that rating with the "Channel Down" button.
Then hit "Menu" to exit out of the settings and saave your changes.
Jan 27, 2008 | Sylvania 6432TE 32" TV
Sony 36' TV Volume Goes up on own/Stuck on Video 2
There's a setting in the menu. I think it's called "smart audio". It's supposed to adjust the volume automatically for commercials. But I don't think it works that well. Give that a try.
Jan 09, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
