Question about Karcher K2.26 Electric Power Washer
My winner 11, has developed a bad leak and has lost pressure, i assume I need a set of O rings, where can i purchase spare parts, i live in Adelaide
  • 2,510 Answers
If there is no Karcher agent near you, most hardware shops and bearing outlets keep a range of o rings in stock. Take samples ot the part with you to get the correct size and thickness of o ring for your needs. Remember to put a bit of lubricant on the o ring when installing it.
Posted on Apr 07, 2011
  • 2 more comments
  • daomingsu69 May 30, 2011
    thats good about the o ring. what about the oil? can i use the engine oil? and this is my model k2.360 thanks! i need ur reply.
  • Hans Pearson
    Hans Pearson May 30, 2011
    The recommended oil for Karcher pumps is a specially prepared SAE 15W-40 oil, but general consensus is that the normal SAE 15W-40 oil can be used without problems
    can i used d synthetic oil?
  • Hans Pearson
    To be honest, I do not know, but my gut feeling is that it would be better to stay with a normal mineral oil. There are the seals to consider and also the possibility of water contamination and I do not know how synthetic oil reacts with water.
Where can I get an online Instruction Maunual for the Karcher Winner 11
http://www.rjbowers.com/machine_list.php Click on blue search list box - type winner in box - hit enter key and the parts list and manual will come up. Or call RJBowers tomorrow and we will email the manual. 800-383-6584
Mar 31, 2012 | Garden
2006 Pacifica 3.5L I have a small coolant leak on the passenger side. The coolant will trickle down and drip from oil pan. The puddle is only 2 inches wide. I did a pressure test at 17PSI and I lost 2PSI...
It is a possibility that the leak may come from bad seals from the water pump or a bad water pump. If you also observe bubble in the coolant inside the radiator when the car is running or water coming out of the exhaust you may have a bad head gasket. The coolant comes out of the bad part of the head gasket near the outside which lets water outside the engine as well.
Aug 03, 2011 | 2004 Chrysler Pacifica
Comperssor runs and there is pressure from the tank gauges won't put out more than 20-30 lbs.
indicates the pump has lost its capacity, assuming the line from the pump to the tank is not leaking,,, a few things could have happened, most likely a valve in the head plate has broken, or head gasket has blown. Third would be he compression ring on the piston has worn out and needs to be replaced. advise you get a parts breakdown on the pump and have at it ad start looking for something broken in the head first.
Feb 12, 2010 | Coleman Powermate 11 Gallon Air Compressor
Karcher/Winner 11 - motor pulses when hose is not operating
Hi, I had the same problem, Replaced the O rings and the rubber seals and cups inside the pressure washer and eventually the hose itself burst. Turns out the hose was leaking, internally between the inner sheath and the outside plastic cover, for quite some time and this caused the pulse. New hose and pressure cleaner is as good as new.
Mar 15, 2009 | Karcher K2.26 Electric Power Washer
Karcher K2.26 Electric Power Washer Logo
665 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
