Question about Samsung BD-P1600 Blu-ray Disc Player
Ive had this bluray player for 2 years and it was working fine, then one day i tried to turn it on and nothing happened. i checked if the fuse was blown but i appears to be fine. so there is no power either getting to the device or there is something internally wrong is there any solutions
  • Samsung Master
  • 6,694 Answers
there is possibility of two complaints.
1, The SMPS power supply fault
2. the mother board fault.
if the SMPS is faulty the you can rectify the problem. If it is with the mother board the you have to contact the manufacturer .
First of all you have to check the SMPS ( switch mode power supply). you have to check the voltages at it secondary stage. 5v, 12v, etc
switched-mode power supply (switching-mode power supply, SMPS, or simply switcher) is an electronic power supply that incorporates a switching regulator in order to be highly efficient in the conversion of electrical power. Like other types of power supplies, an SMPS transfers power from a source like the electrical power grid to a load (e.g., a personal computer) while converting voltage and current characteristics. An SMPS is usually employed to efficiently provide a regulated output voltage, typically at a level different from the input voltage
for checkin the SMPS voltaes you need a multimeter. And check the voltages at it secondary stage
Added the inside view of BD 1600
if there is no outputs from the smps then you have to replace the SMPS drive STR ic near the big capacitor. Also ty to replace the OPTO coupler ic. y have to check the all resistors near the ic.
Remember one important thing that the capacitor can hold charge for some time even if you disconnect the power. so after removing the power. remove the SMPS very carefully. discharged the capacitor using a bulb.
i have also added a video for SMPS working for you reference will hep you for repairing your one
ok
Posted on Apr 07, 2011
Radio won't power up
Check the power wire to radio. and check the fuse for radio also. If ok, The radio may have gotten moisture etc, from sitting for 2 years. Good-Day!
Aug 21, 2014 | Cars & Trucks
No power to my 1210 MK2s
HI,
Open the turntable. It sounds like the on/off switch is bad. Remove the platter and screws with a phillips screw driver and just make sure the connections are in place. make sure you disconnect the power first.
Jun 12, 2008 | Technics SL-1210 Turntable
My Samsung BDC6900XXA 3D BLUE RAY PLAYER DOSEN'T WORK, IT WAS WORKING GREAT THEN MY INTERNET WAS INTERRUPTED FOR 1 DAY THEN THE INTERNET WAS CONNECTED AND NOW THE BLUE RAY PLAYER TURNS ON BUT...
I have seen this happen before when an update went bad right in the middle of an Internet outage. If you bought this recently, try to return it for a replacement. Otherwise, you will have to contact Samsung's support line to see if there is a Factory hard reset.
Aug 25, 2011 | Samsung BDC6900 3D Bluray Disc Player
Player turns on ok,display shows menu that disc is playing but tv says there is no signal, not seeing home screen with net flixs or the other apps.player has been working great we used it 2 day earlier...
The "handshake" between the television and the blu ray player has been lost. This happens a lot when connecting with hdmi. Sometimes a hot swap will work to remedy this. That is turning off and unplugging both your television and bluray player while removing the hdmi cable from both for 30 seconds to one minute. Reconnect the bluray player to the hdmi cable and then to the television. Plug them both back in and turn the television on first then the bluray player. Your television may need a factory reset going into the service menu or the board the hdmi ports are located on might need to be replaced if all of the hdmi ports are not responding. You can connect with component if possible in the meantime.
Apr 14, 2011 | LG BD390 Blu-Ray Player
My BDP S550 was working playing most blurays. The other day I put the original release avatar bluray in and it came up as disc unknown, which had worked before. Now no blurays work in my bluray player...
If nothing is playing, you either have a dirty lens or it's out of alignment and will need service. Try a DVD lens cleaner that uses fluid, they usually cost 20 or so and can be purchased just about anywhere these days. If it still won't play, it's a service issue and needs repair/replacement, depending on cost. Get an estimate first. Hope the cleaner works!!!
Jan 24, 2011 | Sony BDP-S550 Blu-Ray Player
My air and heat controls do not work (no power)
I had the same problem check out this sight for a possible solution:
http://www.wjjeeps.com/blower_motor.htm
May 23, 2009 | 1999 Jeep Grand Cherokee
Battery went dead alpine cd stop working
Sometimes when you jump off a truck the CD player fuse will blow because it was trying to turn on each time you turned over the engine. Check all the fuses.
Mar 22, 2009 | Alpine CDA-7892 CD Player
My RCA TH1161-A mp3 player wont work at all
Ensure the key lock is not activated by sliding
"Power on/off ( )/Hold" towards the center
position. If your player isn’t already on, turn it on by
sliding "Power on/off ( )/Hold" to the left
and holding until the player turns on.
-Tha Mp3 Doctor
Jan 06, 2009 | RCA TH1101 MP3 Player
Ahh
Sounds like the firmware is corrupt.
Install (if you haven't already) and run the Device Manager or Firmware Upgrade (dependant on model) software from the product CD.
Connect the player to the PC and follow the on-screen prompts.
If this doesn't help let me know the model number for more assistance. Should be PSA{XXX}
Feb 25, 2008 | Philips GoGear HDD6330 MP3 Player
No lit up screen or music
Even I had same problem. When showed it to technical person, he told me that battery has fused off due to water.
Oct 26, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Samsung BD-P1600 Blu-ray Disc Player Logo
333 people viewed this question
Henry  Thomas
Henry Thomas
