Question about HP Pavilion m7580n PC Desktop
"HP Pavilion m7580" is not
    Guru:
  • 571 Answers
To verify whether it's a no POST issue, press NUM LOCK or CAPS LOCK key and check whether the CAPS LOCK or NUM LOCK lights are lit or changes when you press on it. If it doesn't then it's a No POST problem.
However, if the computer screen shows the HP logo or a display then it's POSTING and is experiencing a No BOOT issue.
If the NUM LOCK or CAPS LOCK responds when you press it but there is no display, check the connection between the monitor and the CHASSIS or CPU.
If you have verified that it's a No POST issue because CAPS lock is not responding, you need to open up the chassis to do a troubleshooting procedure. Be sure to unplug the chassis to all the connections especially the power cord. Drain the power by pressing and holding the power button from 8-10 seconds.
Here are the things that you need to do after you open up the chassis.
1. Reset the Memory sticks. Connect the CHassis to the power and monitor. If no go, try turning on the computer without the memory sticks. The aim of this troubleshooting is to see a display on the screen. Any display would be a good sign. If no go. Put the memory stick back in.
2. Remove the CD drive. Turn on the computer, check for development. If no go, proceed to step 3. Just leave the cd drive removed
3. Do the same thing with the other devices like the hard drive and other devices inside. Your aim is to see a display.
Let me know if what happens and I'll get back to you.
Once you see a display. Let me know by replying to this thread.
Posted on Apr 07, 2011
Hp pavilion m7580
What's the problem of your computer?
Jun 08, 2014 | HP Pavilion a1410n (ER890AA) PC Desktop
Wireless is stuck on off
The restore is a life saver when drivers have been corrupted, proceed with care you may have a conflict with both wireless devices.
Sep 16, 2012 | HP Pavilion NV023UA dv7-2185DX Notebook -...
Green power supply light is flashing so power is getting to the computer, however the computer will not start from start button. Have removed case and tried ***** start button. Didn't work. Comput
Power getting to the computer/Power Supply?
Yeah.
Power Supply good? -> NO
A) IF ALL of the LED lights were on at once, they would use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts of power.
C) A typical Processor can use from 51 to 125 Watts of power.
Just depends on what Processor it is.
HP Pavilion a810n Desktop PC?
Uses an AMD Athlon 64 3300+ processor,
(Operates Up To a frequency rate of 2.4GHz)
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00280647
http://en.wikipedia.org/wiki/List_of_amd_athlon_64_microprocessors#.22Newcastle.22_.28CG.2C_130_nm.29
Can use up to 89 Watts of power.
Your Power Supply doesn't even have enough power to spin fans, much less start the Processor.
Want to test the Power Supply? Have a multimeter?
No? Have a power supply you can borrow for a test unit?
KNOWN to be good, and Compatible?
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 05, 2012 | HP Computers & Internet
Power supply unit starts (fan running) but computer does not....
Try swapping out the ram 1 at a time, making sure there is one memory piece there while testing. If no! check hard drive for activity.
Mar 14, 2012 | HP Pavilion a1102n PC Desktop
Post Test card reads 43 what does it mean?
when was it manufactured . it has possibly went past it's life expectancy
Mar 01, 2017 | StarTech.com PCI Post Diagnostics Test...
I have a hp pavilion 6370Z. i lost my windows 98 CD, and my hard drive was formatted. When i try to boot the computer it just says "invalid system disc replace the disc, and then press any key."...
You can dump the windows98 setup to your usb flash drive using wintoflash software and boot your system using usb flash drive. Proceed with the installation steps for win98.
Regards,
Sreejith
Aug 12, 2011 | Microsoft Windows 98 for PC
HP Pavilion a735w will not power up Green light flashing.
check the light at the rear panel of the tower ... if it is solid green then reseat the cables coming out of the smps and going to the motherboard and other device drives(Hard Drive and CD/DVD drive).... if there is no light smps might have gone bad
Jan 27, 2010 | HP Pavilion a735w (PL308AAR) PC Desktop
On my HP Pavilion I set the BIOS to change the boot order from the CD drive first. Then I intalled Fedora 9 and when I tried to reboot the machine will not boot. I have tried booting with the Win XP cd in...
try resetting all the connections and also disconnect the power cable from the back of the computer and hold down the button for 10 seconds and start the system that should work
Feb 01, 2009 | HP Pavilion 753n (P9852AR#ABA) PC Desktop
I have a BRAND NEW HP Pavilion Notebook which I just switched on for the FIRST time. It has come up with an error message, ie: "The computer restarted unexpectedly or encountered an unexpected error....
Your windows installation CD might have become corrupt. Use a fresh CD and enter into BIOS settings to set Default Settings before installation.
Try & reply.
Sep 11, 2008 | HP Computers & Internet
HP Pavillion ZT1170 CD Activity Light on Solid
Try with a CD/DVD lens cleaner CD. This will rectify any static charge or dust in the lens.
If any heavy phisical impact happend, may be the drive contacts are improper. Conform there is a DVD-RAM Icon presents in the My Computer window. If not found try the following steps.
1. Load CMOS default valus and give a proper start up and check the DVD-RAM drive in your system.
2. Shutdown the system
3. Gently push the drive inside the laptop's base cabinet. Remember apply a gentle force.
4. Turn on the system and check it out.
5. If the above steps failed, Shutdown the system, and remove the drive from the motherboard. Clean the electronic contacts using a pancil eraser or with a nice cloath. Insert the drive again, then verify.
Note: In all the above steps, try with more than 2 CD/DVDs 'cause laptop drives are too sensitive and can not read some CD/DVDs even thay have a little scratch.
Nov 26, 2007 | HP Pavilion zt1170 Notebook
HP Pavilion m7580n  PC Desktop Logo
374 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
