Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Wtw6600 washer has UL code and has trouble agitating and spinning.
    Master:
  • 324 Answers
The UL code means Unbalanced Load. Open the lid and move your clothes around so they are distributed evenly. Your spin cycle will then work normally.
Posted on Apr 07, 2011
The tub continues to go off balance in spin cycle. Starts out smooth then starts to wobble terribly til the UL shows and shuts down. Support rods are good
There is a little device inside the washer that allows the agitator to spin independent of the drum. If this gets stuck, the washer will try to spin the whole drum instead of just the agitator. This will cause the washer to think the load is too large or out of balance, causing the error code. On some Whirlpools this device is just a washer.
Jan 07, 2015 | Whirlpool WTW8800YC 4.6 cu. ft. Cabrio...
Duty heavy stackable
Hello Tabatha,
I see that you are having trouble with your washer portion agitating and spinning out. I suggest to give your appliance a hard reset. You will do this by either unplugging it switching the circuit breaker it is attached to, off for 3-5 minutes. Once the 3-5 minutes has passed, switch the circuit breaker back on. Turn the washer on. If you are still having trouble with it not agitating or spinning out, I suggest you contact your local authorized technician to come and diagnose the washer, to see why it will not agitate or spin.
-Best Regards-
Jan 24, 2014 | Frigidaire FEX831CS Top Load Stacked...
Kenmore Elite Oasis washer does not lock
First, OL/UL stands for "Overload", so in other words, the washer things the tub is too hard to move because it's overloaded and the motor is struggling or the unit is way out of balance causing the washer to struggle. The most common problem is a nut below the inner tub that needs to "float". Floating is when the tub fills up with water to a certain level the inner basket will rise about 1 inch from the center agitator. What this does is disengage the basket from the motor so that the agitator can rotate independently from the basket. If the basket does not float then when it tries to agitate the whole basket will turn back and forth at the same speed as the agitator and this will cause the OL/UL error code.
Nov 22, 2012 | Kenmore Oasis 4.6 cu. ft. Canyon Capacity...
Tub does not move during wash cycle;just keeps filling;timer jumps from 25 to 4:then drains;flashes OL(small loads)
Nov 21, 2012 | Maytag Bravos MTW6600T Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer won't aggitate
My Whirlpool WTW6600 had the same problem. The tub no longer floated up and down on the center shaft, so it only spun, not agitated. You must remove the tub (with some effort) and lightly sand / clean the center shaft. Lube it lightly with wheel bearing grease so that after it is reassembled, you can pull the tub upward and feel about 1/2" movement. This will enable the proper gear assembly to engage. It can spin when it rests at the bottom of its travel, but once you fill the tub, it floats, moving upward, and engaging the agitation gear. Good Luck!
Nov 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a cabrio wtw6600 that makes a clicking or grinding noise when agitating. It only makes it when the basket spins to the left and in silent when it spins to the right. The spin cycle is the normal...
This is usuallty caused by the hub assembly. You will need to remove the agitator and the hub assembly is located under it. This is very inexpensive $10 and easy to fix. Here is your part and a link to diagrams and illustrations AP3892170
www.appliancehelponline.com
Sep 30, 2010 | Washing Machines
Ul code about 10 to 15 seconds into spin cycle machine is level code comes up even if i run it empty
Hi
Thanks for using FixYa. UL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
• Display clears if mini-cycle successfully rebalanced the load.
• If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Code ul appears shortly after start up
I think ul is unbalanced load, not unlocked lid.
Jul 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
1,051 people viewed this question
Dan Webster
Dan Webster
Sal De
