Question about RTO 150cc Touring Gas Motor Scooter with the lowest price, Free Parts Warranty
Bug bandit 50cc 2 stroke bogs down
My bug bandit 50cc 2 stroke bogs down and stops on hills or under load, does anyone know what could cause this? thought it might be air but it's not.@
  • Johannus FS Oort
    Johannus FS Oort Oct 22, 2017
    have you checked if ur 2 stroke oil - fuel mixture is correct
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 47,204 Answers
Hi, Anonymous engine "BOG" is mainly caused by a rich air and lean fuel condition but it can also be caused by a lean air and rich fuel condition this situation rarely occurs and is only caused by the misinformed weekend warrior that owns a toolbox.
The more you open your throttle the more vacuum you are creating in your carburetor venturi and your intake manifold. When you are operating at higher RPM any unmetered air that leaks into your system can become more obvious.
Unmetered air is air that is getting into your system after the fuel has been delivered. If you have unmetered air getting into your system between the butterfly/slide of the carburetor and the cylinder head this will create a lean condition.
All of the rubber components of the fuel system like vacuum hoses and intake manifold that you mount the carburetor to are made of rubber. If none of these components have been changed they are more than likely highly degraded and probably cracked in places to allow unwanted-unmetered-contaminated air into the combustion chamber. Check all of your vacuum lines and vacuum plugs for carburetor synchronization. The vacuum plugs are in the head just after the rubber intake manifolds. The petcock has a vacuum line as well as part of the emission system.
1. Check the intake manifold for fissures.
2. Ensure the bands used to tighten the manifolds down on the intake are secure and have not bound up the manifold.
3. Make sure air box fittings are not warped and fit completely over the carburetor.
Your airbox is metering air and is the first step in a process of consuming air and fuel. The system requires the resistance of the air filter in order to get the proper vacuum to "SUCK" the fuel out of the float bowl and create the proper venturi effect.
Improper mounting and sealing of the airbox will create a small lean effect. This might seem like no big deal but you are inviting dust and debris in your engine that is doing slow damage by not having proper fitment. Fix it so you know it's not contributing to your issue. Pick the low-hanging fruit first.
Do not go and start adjusting anything at this point. It ran fine before. There is something wrong with the assembly or a component. Do not adjust your floats. Get it back to where it was. The moment you start tweaking everything is the moment you lose OEM settings which are a must-have for fine-tuning and maximum performance.
Fine-tuning your carburetor and multi carb syncing come at the very end following the proper procedure established by the Carburetor Gods.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Why is the engine bogging under acceleration Suzuki FA50 Moped
How To Fix Bogging On Scooter Or Moped
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
Bug Bandit 50 Scooter News and Reviews Scootersales
http://absolutelyscooterparts.net/pdf/CGEN_dawg_scooter_manual.pdf
Posted on Oct 23, 2017
4 Suggested Answers
  • 3567 Answers
SOURCE: i have a piaggio zip
The valves are probably in need of re-seating. It is easy to do but a valve spring compression tool is likely to be needed. Most any lawnmower shop would be willing to re-seat the valves for cheap if you bring them the cylinder head. Motorcycle dealer will likely be more expensive. Check around. A compression check should tell the story for sure. Please rate my answer. Thanks.
Posted on Aug 03, 2010
nitro650
  • 93 Answers
SOURCE: Jonway speedy 50cc moped....2 stroke or 4?
What year is it ? Is the cylinder-head height or shape capable of holding a rocker shaft and valve ?
Posted on Sep 19, 2009
  • 747 Answers
SOURCE: 5 hp honda on a pressure washer. Bogs down and cuts off under load.
sounds like the pump has an issue check for restrictions in the hose as well as the filters look for any oil leak at the pump itself
Posted on Sep 04, 2012
Installed new Nikki carb but now it's like my bike doesn't have any power it's revving up nice but when driving it has no power
Hi, Sarel and the usual suspects are:
1. Idle speed improperly adjusted.
2. Inlet system air leak.
3. Damaged or restricted fuel tank venting system.
4. Dirty or damaged air cleaner element.
5. The accelerator pump is inoperative.
6. Vacuum piston assembly malfunction.
7. Enrichener valve is not seated or leaking.
8. Restricted fuel supply tract.
9. Plugged bowl vent.
10. Loose or plugged fuel and air jets or passages.
11. Improper float level.
12. Worn or damaged needle or needle jet.
13. Loose or plugged main jets or passages.
For more information about your issue and valuable "FREE" downloads that you will need please click on the websites below. Good luck and have a nice day.
http://www.scootertherapy.com/runslowpage.html
50cc 2005 Scooter bogs no power GY6 engine It Is The Ride
2 stroke scooter engine suddenly lacks power when going up hill
Oct 09, 2016 | Power Motorcycles
Atv has no power, 50cc two stroke Dinli. It will start and idle, but when you give it more gas to move, it wants to bogged down and stall.
Check the air filter for cleanliness and blockages. Remove and clean the carburettor jets and float bowl. Clean spark plug and check the gap.
Jul 18, 2016 | GAS Motorcycles
Hi, anyone know what the factory carb settings are for an aeon mini kolt 50cc. Having problems with getting it started, changed spark plug and battery
Two-Stroke Scooter / ATV Carburetor Settings And ...
? 4:37
https://www.youtube.com/watch?v=A1vRMERs4RQ
Jun 2, 2012 - Uploaded by 90GTVert
Part 2 of a 4 part video detailing all of the basic settings and ... Two-Stroke Scooter / ATV Carburetor Settings ...
Fix your Mini bike Carb - bogging, cutting out etc - YouTube
? 4:51
https://www.youtube.com/watch?v=lbtDMFUiD0k
Aug 15, 2011 - Uploaded by Cpt MishMash VonRandom
If you are having trouble with your mini bike/quad whereby its difficult to ... Two-Stroke Scooter / ATV ...
quad 50cc carb Questions & Answers - Fixya
www.fixya.com > Forum > Tags
50cc carb wondering what the factory setting is for a 2002 50cc Kawasaki kid's ...aeon mini kolt 50cc quad will rev a little then cuts out no power Likely a lean ...
Aeon mini kolt 50cc quad will rev a little then cuts out no ...
Jan 05, 2016 | Factory Motorcycles
Engine bogs down under load it starts first kick and idles nicely and will free rev crisp. Riding up a hill with load it bogs down
Is the machine a two stroke? Because if it is a blocked exhaust (full of carbon deposits) will cause exactly this symptom. The best way to clean it is to stand it on its end and fill it with oven cleaner and leave it for a day. In the old days it was just a case of heating the exhaust with a blow lamp and tapping the pipe gently to loosen the deposits
Mar 20, 2014 | Gas Gas Motorcycles
YQ50 loses power when going up any sort of hill
Hi, Anonymous for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2008 50cc Super Battle The Scooter Review
Yamaha YQ50 Service Manual
OEM parts for Yamaha
YAMAHA AEROX YQ50 Owner Manual
Feb 05, 2014 | 2006 Yamaha yQ 50 Aerox R
I rode my 50cc scooter in the rain, with no air filter.
If you allowed water to get into the air inlet, if a 2stroke, I suspect the crankcase seals are damaged. If 4 stroke check compression for damaged piston.
May 28, 2017 | Star 50cc MOTOR SCOOTER
2004 Polaris Sportsman 400 - Engine cuts out when climbing hills or when pulling a heavy load? The engine wont shut down on me but it looses its power and sputters until it gets to level ground. I had a...
well there are a couple of things that can cause this to happen. first check your oil and coolent. odd sounding i know but this can cause it. second check and make sure your cluchs are working correctly. next if all that fails then i would check the air intake for blockages and then service the carb.
reply if you need more help :)
Aug 03, 2010 | Polaris ATV
Engines dies when going up hill
It isn't a fuel problem, it is a power problem. Any bike will slow down on a hill. The bigger the engine, the more power is available to maintain speed. 50cc just isn't much power to pull a 150 pound man up a hill.
I am assuming the scooter has a two stroke engine. If it is a four stroke the valves may be needing attention. But even with good valves, 50cc just isn't a powerhouse of an engine. If you want to be happy, trade the scooter in on something 125cc to 200cc. You will feel better about your ride and be more respected on the roadway.
May 02, 2009 | Peugeot 405 Cars & Trucks
Took out air filter on piaggio zip sp 50cc forgot how it goes back in can u help thx u expert or experts p.s they dont show up on select motorcycles no vespa or piaggio categories any pic u can send ov how...
recently my piaggio zip sp has been loosing power wen under load going up hill and sumtimes when on full throtle it seems like the fuel is serging instead of feeding through smoothly anyone know wat could be wrong
Mar 14, 2009 | 1977 Moto Guzzi V 50 I
RTO 150cc Touring Gas Motor Scooter with the lowest price, Free Parts Warranty Logo
323 people viewed this question
Top RTO Toys Experts
The Scrivener
Pete Bruk
rostit
Are you a RTO Toy Expert? Answer questions, earn points and help others
