Question about Dell Inspiron 1525 Notebook
Hi i have had my dell inspiron 1525 for over 15 months, i have been experiencing problems since day 2 in which the lcd inverter has been changed it seems that the laptop keeps on defaulting... i have in total probably used the computer for 3 months straight and then left it... i want to be running for daily use now. please tell me where in kathmandu nepal can i get this fixed and not have to decide against buying another dell product..
If your laptop has warranty in it then you need to check these information
http://www.dell.com/downloads/ap/services/indirect.pdf
If laptop is out of warranty then you can check with any local technician in your area.
Just a suggestion. If you plan to get another laptop in the future try read some article in forums and discussions about which best laptop can be used and with less issues.
Hope this helps.
Posted on May 22, 2011
Hi i recently started having problems with my dell inspiron 1545 screen. At first it started to freeze and fade to bright white, eventually after a few days it became stuck white even after booting the...
Hi lewis haywar,
Try to replace the LCD inverter in your laptop. Most common issues on LCD are due to failing LCD inverter. It fails more often than LCD cable or LCD backlight does.
Please let me know if this solution helped to resolve your issue.
May 11, 2011 | Dell Inspiron 1545 Notebook
I purchased a replacement inverter for my husband's Dell Inspiron 1300 Laptop (14.1" screen) on Ebay. I noticed when I got it that the little screw hole on the left was on the bottom left while the hole on...
The inverter simply converts DC power from the adapter into high voltage AC power for the backlight in the LCD....if you are having distortion problems or anything else other than the brightness of the LCD, you are either looking at a cable issue or a bad LCD panel.
Mar 26, 2010 | Dell Inspiron 1300 Notebook
Dell inspiron 5160 labtop backlight
It seems to me the inverter is busted. That is why the backlight just went out. If you are still covered by your warranty Dell technical support will replace the inverter and i believe they will also include the LCD kit.
Hope this helps
Jan 16, 2010 | Dell Inspiron 5160 Notebook
How do you replace the LCD inverter
Follow the below guide :-
http://www.laptoprepair101.com/laptop/2007/01/31/replace-screen-inverter-fix-backlight/comment-page-5/
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 07, 2009 | Dell Inspiron 6400 Notebook
New inverter in Dell Inspiron 1501 now the LCD screen gets hot!
I've had the same problem with a Dell Lattitude D531. I've been told that it's the screen itself (which may have led to the original inverter going bad) but that one should also check to make sure none of the screws are making contact with any wires back there.
Sep 10, 2009 | Dell InspironTM 1501 Notebook
My Dell Inspirion6400 screen wont come on. I attached it to an external monitor, and it came up with the error code:0326 LCD Inverter Error, unable to turn lamp on. If I replace the LCD inverter, will...
Check out http://www.ccfldirect.com. they have a wide variety of inverters and backlight tubes for LCD panels and laptops. I'd change out the tubes at the same time you replace the inverter. The cost is minimal, and will increase the likelihood that you'll be successful
Jul 13, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron B130 was black when turned on. Holding flashlight to screen, could see desktop and all icons. Was able to open programs, etc., while looking with flashlight. Replaced LCD Inverter listed for...
yes your lucky thing is this problem is LCD CCFL lamp worn, change a new lamp should be fixed.
hwo to change CCFL lamp, step by step:
1) buy a CCFL lamp from eBay, reference:
http://shop.ebay.ca/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Dell+Inspiron+B130+CCFL+lamp&_sacat=See-All-Categories
2) take out LCD panel
3) open the back light cover and change the CCFL lamp, reference:
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/comment-page-3/
hope help you fix it, please feedback any question any time, pleaae take a rating let me know how much helped you thanks!
May 28, 2009 | Dell Inspiron B130 Notebook
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Dell Inspiron B130 Notebook
Where is the LCD backlight inverter on an Inspiron
The inverter is in the LCD, below the actual screen. It controls the brightness and the contrast on the laptop. Here is a link where I purchase them:
http://www.smartmicrousa.com/dell-inspiron-e1705-laptop-inverter-board.aspx
It is easy to replace. Here is a link that will guide you:
http://www.ehow.com/how_4841734_dell-laptop-inspiron-e-backlight.html
Apr 21, 2009 | Dell Inspiron E1705 Notebook
Dell Inspiron 1525 Notebook Logo
49 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
