Question about Braun KSM 2 Electric Blades Grinder
My grinder has been working fine until this morning I did the usual plugged it in and it did not work. could the engine be burnt out. it is my favorite appliance for coffee grinding. please help. I would like to repair it.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 78 Answers
If you ground for a long time...20-30 seconds, you may have burned out the thermal control protection that keeps it from catching fire. It is a guess without more history.
Posted on Mar 13, 2013
How often should you need to clean the bean grinder? We seem to be cleaning it every 3 days which seems excessive
No brand or model? Okay, general reasons why grinders clog up. Most common I've found is worn out burrs. The plates, depends on composition and usage. Metal plates last longer but not forever. If your grinding thousand pounds of beans don't expect it to last. I've seen massive grinders fail within a month. It all depends on two factors; How much and how fine. Large grind size will increase life and fine grinds wear the burrs out very fast. Especially Turkish settings. Fine grinds also generate a lot of heat. This can cook the coffee again and make it change in flavor. Heat also forces the oils in the bean to coat the burrs and make them dull out which causes more heat. Prolong grinding will also burn out motor.
* Worse case senario; Very oily beans ground to espresso fine. This is usually the case with 'local' roasters. Poor quality beans, extreme roasting (pushing the max on toasting limits), and extreme fine grinds for a particular roast. Fine grinding tends to work on dryer beans. Heavy moisture (under roasted or beans not aged enough to outgas and dry out) will gum up any grinder. Let your roaster know what your trying to do. Otherwise go with a name brand and correct bean for the flavor profile your looking for. Don't expect 5 star espresso from a cheap roast.
* Final, most likely worn burrs needs to be changed out. Off chance the motor is burnt out or starter capacitor needs replacement. If it is the motor or cap, then you need to review your grinding methods as grinder motors are usually tough enough to handle the range of grinds listed in the specs. burning the motor is a clear sign of abuse.
* Have your vendor look at the grinder. They will know right away what's wrong.
Aloha, ukeboy57
Apr 17, 2018 | Coffee Makers & Espresso Machines
DCC-1150 Coffee Maker does not have power
Talked to Cuisinart tech support and they told me to unplug and leave it for 2 hours... that resets it to the factory defaults.
It looks like a thermal fuse might have blown inside your appliance.
If a thermal fuse has failed, there is probably another problem inside.
If the appliance is 4 months old, still cover under manufacturers warranty, Call the Cuisinart customer service to ask them where to find an authorized service center.
Hope this works for you.
Mar 12, 2008 | Cuisinart DCC-1200 Coffee Maker
Is there a fuse or circuit braker in a sunline SM-G31 grinder?
Hate to say it but I fear the windings have burnt and is in need of repair. Any burning smell or smell of heating is most of the time directly related to armature or burnt brushes. If this grinder suits your needs having it rewound would be profitable.
Mar 26, 2016 | Vacuums
I have a 2006 Toyota solara. low and high beam and turn signal work fine on left side, on right side the high beam doesn't work I already changed headlamp relay and bulb, any idea what can be wrong?
check ground(s) usually coming out of the harness trace back from headlight plug (on problem side ) until you find a ground coming out of harness and bolted to sheet metal in engine bay make sure there are no loose,corroded, broken ,or burnt wires
Apr 21, 2015 | 2006 Toyota Solara
We have had our grinder 3 years. About 6 months ago it started leaking lots of ground coffee on the counter but still worked fine. Two weeks ago it just completely stopped working. It does not make a...
Hello Darla, if the grinder will not run or make a sound, it usually means that the motor isn't getting power. Make sure it plugged in of course but your main switch may have gone bad and needs to be replaced. As far as leaking grinds; you must have a bad seal between the doser and the mill housing. Feel free to give me an email if you need more info or parts.
Thanks, Mike Wall mikey@espressomachineexperts.com
Sep 15, 2010 | Rancilio Rocky Doser Espresso Grinder...
My mazzer coffee grinder brings out medium to almost a whole bean grinds ,,,am trying to get a fine grind(for the espresso) but it's not working ,,, i've tried to move the scale to all the numbers but the...
Lets do this, remove the bean hopper, and make sure there are no beans in the burr chamber. Then looking down at the collar with the numbers back up screw if there is one on it. Now if memory serves me right clockwise is coarse and counter is fine. Look down in the burr chamber, notice the nut in the middle, turn it with your fingers that will move the bottom burr, if burr turns freely we will move on if not plug in grinder and let it grind out remaining beans. With beans gone unplug grinder, then turn collar towards fine until you cannot go no more, now try turning nut it will be hard if not impossible to move, turn collar towards coarse until you can barely move bottom burr with fingers, you will hear and feel the burrs touching, that will be our bottom setting. Now pick a spot on the grinder you can use the small notch in the middle, count out 16 notches towards coarse and turn collar to that point. Use the notches around the collar not the ones on the top next to the numbers. Your grind should be almost perfect, depending on blend and machine you might have to adjust 1 notch to the left or right after testing.
Aug 11, 2010 | Mazzer Coffee-grinder SUPER JOLLY Electric
F-350 turbo-diesel hard starting
Imagine the white smoke is unburnt diesel. Anybody standing in the middle of it will be able to tell you soon enough.
Most likely culprit is that one or two of the glow plugs aren't getting hot enough. Usually just that the plugs need replacing, but worth checking first that the busbar which runs between them all is getting +12V at the appropriate stage of the process.
A.
Jul 20, 2008 | 1995 Ford F350
Braun KSM 2 Electric Blades Grinder Logo
348 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
ellipse0904
Level 1 Expert
Jim Thurston
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
